path: root/include/configs/p3mx.h
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-08-18lib_ppc: make board_add_ram_info weakKim Phillips
platforms wishing to display RAM diagnostics in addition to size, can do so, on one line, in their own board_add_ram_info() implementation. this consequently eliminates CONFIG_ADD_RAM_INFO. Thanks to Stefan for the hint. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various p* named board config files.Jon Loeliger
2007-01-18[PATCH] Update Prodrive P3Mx supportStefan Roese
2006-11-29[PATCH] Add support for Prodrive P3M750 & P3M7448 (P3Mx) boardsStefan Roese
This patch adds support for the Prodrive P3M750 (PPC750 & MV64460) and the P3M7448 (MPC7448 & MV64460) PMC modules. Both modules are quite similar and share the same board directory "prodrive/p3mx" and the same config file "p3mx.h". Signed-off-by: Stefan Roese <sr@denx.de>
