path: root/include/configs/p2571.h
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-02-18ARM: tegra: don't set CONFIG_USB_MAX_CONTROLLER_COUNTStephen Warren
This option is no longer used now that DM_USB is enabled. Fixes: 534f9d3feffd ("dm: tegra: usb: Move USB to driver model") Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-11-12ARM: tegra: simplify GPU setupAlexandre Courbot
Enable the GPU node in the system-wide ft_system_setup() hook instead of the board-specific ft_board_hook(). This allows us to enable GPU per SoC generation instead of per-board as we did initially. Reported-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-09-16p2571: Remove hard-coded counter frequencyThierry Reding
The counter frequency is derived from clk_m on Tegra, but that clock can be configured by the primary bootloader to run at the same frequency as the oscillator (38.4 MHz on Tegra210) or a divided down frequency (most typically 19.2 MHz). Remove the hard-coded frequency and allow the timer setup code to query the correct value at runtime. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-09-16ARM: tegra: replace V_PROMPT define with kconfigStephen Warren
Commit 181bd9dc61d2 "kconfig: add config option for shell prompt" replaced define V_PROMPT with Kconfig option SYS_PROMPT. This crossed with patches adding Tegra T210 boards. Migrate the boards to the new scheme. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-09-16ARM: tegra: fix COUNTER_FREQUENCY for T210Stephen Warren
While T210 boards all have 38.4MHz crystals, per the TRM, the only supported configuration is to divide the crystal frequency by 2 to generate clk_m, which is what feeds the ARM generic timers amongst other things. Fix the value of COUNTER_FREQUENCY to reflect this divide-by-2. When I queried the 19.2 value in Tom's original T210 patches, I wasn't aware of this extra divide-by-2, and didn't notice any effect from the incorrect value, since its only used if U-Boot is booted in EL3, whereas I'm booting it in EL2. Reported-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: p2571: remove another unused defineStephen Warren
CONFIG_MAX77620_POWER isn't used anywhere. Don't define it in p2571.h. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: enable GPU DT node when appropriateAlexandre Courbot
T124/210 requires some specific configuration (VPR setup) to be performed by the bootloader before the GPU can be used. For this reason, the GPU node in the device tree is disabled by default. This patch enables the node if U-boot has performed VPR configuration. Boards enabled by this patch are T124's Jetson TK1 and Venice2 and T210's P2571. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05Tegra: P2571: Clean up config fileTom Warren
Removed NS16550_COM1 #define, not used since there's no SPL for T210 Also changed the number of USB controllers to 1 as only USBD is used. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05Tegra: spi: Move TEGRA114_SPI switch to defconfigsTom Warren
All T114+ Tegra boards should be using the Kconfig TEGRA114_SPI switch. Remove it from include/config and put it into defconfig. Also removed unused TEGRA114_SPI_CTRLS from T114+ configs. All Tegra SoCs build OK with this change. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05T210: P2571: Restore USB gadget mode (ums)Tom Warren
The tegra-common-usb-gadget.h include was causing some build problems in ci_udc.c with a 64-bit gcc in an earlier version of the T210 patches, but it is working fine now, so restore it. Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-28T210: Add support for 64-bit T210-based P2571 boardTom Warren
Based on Venice2, incorporates Stephen Warren's latest P2571 pinmux table. With Thierry Reding's 64-bit build fixes, this will build and and boot in 64-bit on my P2571 (when used with a 32-bit AVP loader). Signed-off-by: Tom Warren <twarren@nvidia.com>
