Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
This option is no longer used now that DM_USB is enabled.
Fixes: 534f9d3feffd ("dm: tegra: usb: Move USB to driver model")
Signed-off-by: Tom Warren <twarren@nvidia.com>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
The counter frequency is derived from clk_m on Tegra, but that clock can
be configured by the primary bootloader to run at the same frequency as
the oscillator (38.4 MHz on Tegra210) or a divided down frequency (most
typically 19.2 MHz). Remove the hard-coded frequency and allow the timer
setup code to query the correct value at runtime.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Commit 181bd9dc61d2 "kconfig: add config option for shell prompt" replaced
define V_PROMPT with Kconfig option SYS_PROMPT. This crossed with patches
adding Tegra T210 boards. Migrate the boards to the new scheme.
While T210 boards all have 38.4MHz crystals, per the TRM, the only
supported configuration is to divide the crystal frequency by 2 to
generate clk_m, which is what feeds the ARM generic timers amongst other
things. Fix the value of COUNTER_FREQUENCY to reflect this divide-by-2.
When I queried the 19.2 value in Tom's original T210 patches, I wasn't
aware of this extra divide-by-2, and didn't notice any effect from the
incorrect value, since its only used if U-Boot is booted in EL3, whereas
I'm booting it in EL2.
Reported-by: Thierry Reding <treding@nvidia.com>
P2371-0000 is a P2581 or P2530 CPU board married to a P2595 I/O
board. The combination contains SoC, DRAM, eMMC, SD card slot,
HDMI, USB micro-B port, Ethernet via USB3, USB3 host port, SATA,
a GPIO expansion header, and an analog audio jack.
