CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
- In most of the codebase, we reference CONFIG_SYS_LOAD_ADDR and not
CONFIG_LOADADDR.
- Generally, CONFIG_SYS_LOADADDR is set to CONFIG_LOADADDR and then as
noted, we use CONFIG_SYS_LOADADDR.
- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
As this symbol can either be a fixed value or the function
get_board_ddr_clk, migration is tricky. Introduce a choice of DYNAMIC
or STATIC_DDR_CLK_FREQ. If DYNAMIC, we continue to use the board
defined get_board_ddr_clk function. If STATIC, set CONFIG_DDR_CLK_FREQ
to that value and now include/clock_legacy.h contains the function
prototype or defines get_board_ddr_clk() to that static value. Update
callers to test for DYNAMIC or STATIC.
There are an assortment of hard-coded CONFIG_BOOTCOMMAND options in some
board headers. Rework these so that they do not add to the CONFIG
namespace.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
- As there are no boards that use different values for speed / slave on
different buses, use a single option.
- Switch to using the common SYS_I2C_SPEED / SYS_I2C_SLAVE options.
- Introduce _HAS_ options for additional buses as only the first one is
common to all users.
- Convert all remaining symbols to Kconfig.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
CONFIG_ID_EEPROM
Now that DM_PCI is always enabled we don't need to check it. Drop this
old code.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
Use CONFIG_IS_ENABLED() macro, which provides more convenient
way to check $(SPL)DM_I2C/$(SPL)DM_I2C_GPIO configs
for both SPL and U-Boot proper.
CONFIG_IS_ENABLED(DM_I2C) expands to:
- 1 if CONFIG_SPL_BUILD is undefined and CONFIG_DM_I2C is set to 'y',
- 1 if CONFIG_SPL_BUILD is defined and CONFIG_SPL_DM_I2C is set to 'y',
- 0 otherwise.
All occurences were replaced automatically using these bash cmds:
$ find . -type f -exec sed -i
's/ifndef CONFIG_DM_I2C/if !CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifdef CONFIG_DM_I2C/if CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/defined(CONFIG_DM_I2C)/CONFIG_IS_ENABLED(DM_I2C)/g' {} +
's/ifndef CONFIG_DM_I2C_GPIO/if !CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/ifdef CONFIG_DM_I2C_GPIO/if CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
's/defined(CONFIG_DM_I2C_GPIO)/CONFIG_IS_ENABLED(DM_I2C_GPIO)/g' {} +
Signed-off-by: Igor Opaniuk <igor.opaniuk@foundries.io>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Remove NXP powerpc P1024RDB board support as it is no
longer maintained.
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Remove NXP powerpc P1021RDB board support as it is no
longer maintained.
Remove NXP powerpc P1020MBG board support as it is no
longer maintained.
Remove NXP powerpc P1020UTM board support as it is no
longer maintained.
Remove NXP powerpc P1025RDB board support as it is no
longer maintained.
Add the environment 'vscfw_addr' to assign a default address for
vsc7385 firmware uploading.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Move ADDR_MAP related config options from include/configs/*.h to the
proper place in lib/Kconfig. This has been done using
./tools/moveconfig.py and manual inspection of the generated changes.
This is a preparation to use ADDR_MAP helper on ARM 32bit Raspberry Pi4
board for mapping the PCIe XHCI MMIO, which is above the 4GiB identity
mapping limit.
This variable is unset anywhere and only unset on a number of platforms.
Remove all relevant code.
Move this uncommon header out of the common header.
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
This supports i2c DM for SoC P1020
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Add more clarity by changing the Kconfig entry name.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
[trini: Re-run migration, update a few more cases]
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled
for P1020, P1021, P1024, P1025 and P2020 RDB boards.
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Use the Kconfig option to select the PCIe reset errata.
In order to migrate this symbol to Kconfig introduce a new symbol to
guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then
provide the exact final location o the script.
A number of boards set CONFIG_SYS_LDSCRIPT and then end up using one of
the default searched LDSCRIPT paths. Remove these customizations.
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a
choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and
CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_ENV_SPI_BUS
CONFIG_ENV_SPI_CS
CONFIG_ENV_SPI_MAX_HZ
CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT
with same value is used, so I introduced CONFIG_USE_ENV_SPI_*
to force the associated value for the environment.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Moves below DDR specific defines to Kconfig:
CONFIG_FSL_DDR_BIST
CONFIG_FSL_DDR_FIRST_SLOT_QUAD_CAPABLE
CONFIG_FSL_DDR_INTERACTIVE
CONFIG_FSL_DDR_SYNC_REFRESH
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Rather than checking for CONFIG_TPL_BUILD and then re-defining
CONFIG_SPL_TEXT_BASE make use of CONFIG_TPL_TEXT_BASE directly.
Cc: York Sun <york.sun@nxp.com>
Cc: Po Liu <po.liu@nxp.com>
Cc: Qiang Zhao <qiang.zhao@nxp.com>
Cc: Timur Tabi <timur@tabi.org>
In legacy CONFIG_HARD_SPI initalizing spi_init code, which
was removed during dm conversion cleanup.
So remove the dead instances of CONFIG_HARD_SPI, and related
code.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
There was an EHCI endian accessor issue. Now it's fixed by commit
9829ce2ff25c ("usb: ehci: Fix accessors for big-endian platforms and
descriptors"). Revert commit 0f2296bab141 ("powerpc/p1_p2_rdb_pc:
Fix endian access issue on EHCI intinalization"). On P1 P2 platforms,
USB EHCI register use little endian.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
[YS: revised commit message]
Symbol CONFIG_SPL_RELOC_STACK_SIZE is not used anywhere. So remove it.
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every
use is couched by __stringify(...).
Hence, convert it to a proper string option.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
