path: root/include/configs/p1_p2_rdb_pc.h
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-14powerpc/85xx: enable some P1/P2 boards mtdparts for nor flashYangbo Lu
Enable these boards mtdparts for nor flash: p1020rdb-pd, p1021rdb-pc, p1022ds, p1025twr, and p2020rdb-pc. Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Scott Wood <scottwood@freescale.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-05-16mpc85xx/p1020:Define number of USB controllers used on P1020RDB-PD platformramneek mehresh
P1020 SoC which has two USB controllers, but only first one is used on this platform. Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-13powerpc/freescale: Convert selected boards to generic board architectureYork Sun
This patch converts the following boards to use generic board: MPC8536DS, MPC8572DS, MPC8641HPCN, p1_p2_rdb_pc, corenet_ds, t4qds, B4860QDS. It has been tested on NOR boot on MPC8536DS, MPC8572DS, P1021RDB, P4080DS, P5020DS, P5040DS, P3041DS, T4240QDS, B4860QDS. Signed-off-by: York Sun <yorksun@freescale.com> CC: Ying Zhang <b40530@freescale.com> CC: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Haijun.Zhang <Haijun.Zhang@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Shaohui Xie <Shaohui.Xie@freescale.com>
2014-04-22powerpc/mpc85xx:Update MONITOR_LEN for 768KB u-boot sizePrabhakar Kushwaha
U-boot binary size has been increased from 512KB to 768KB. So update CONFIG_SYS_MONITOR_LEN to reflect the same. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and ↵Zhao Qiang
CONFIG_SYS_QE_FW_ADDR CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-02-24SPL: P2020RDB: fix the problem booting from spi flashYing Zhang
There was no enough stack in SPL, so the buffer needed in SPL is to malloc from memory pool and to repalce the temporary variable. Signed-off-by: Ying Zhang <b40530@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-02-24SPL: powerpc: expand SPL's length to 128KYing Zhang
1. The SPL's length of SDCARD boot has not enough,expand the SPL's length to 128K. 2. deleted unused symbol: CONFIG_SYS_RUN_INDDR Signed-off-by: Ying Zhang <b40530@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-16powerpc: p1_p2_rdb_pc: add TPL for p1_p2_rdb_pc nand bootYing Zhang
Enable TPL for p1_p2_rdb_pc nand boot. Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-10-16powerpc : p1_p2_rdb_pc : Enable p1_p2_rdb_pc to start from eSPI with SPLYing Zhang
Enable p1_p2_rdb_pc to start from eSPI with SPL. Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-10-16powerpc: p1_p2_rdb_pc: Enable p1_p2_rdb_pc to boot from SD Card with SPLYing Zhang
Enable p1_p2_rdb_pc to start from eSDHC with SPL. Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-08-20powerpc: deleted unused symbol CONFIG_SPL_NAND_MINIMAL and enabled some ↵Ying Zhang
functionality for common SPL 1. The symbol CONFIG_SPL_NAND_MINIMAL is unused, so deleted it. 2. Some functions were unused in the minimal SPL, but it is useful in the common SPL. So, enabled some functionality for common SPL. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-09p1020rdb-pd: platform supportHaijun.Zhang
Add new board p1020RDB-PD. P1020RDB-PD board was update from P1020RDB. DDR changed from DDR2 1G to DDR3 2G. NAND: 128 MiB Flash: 64 MiB Also change P1020RDB to P1020RDB-PC to distinguish from P1020RDB board. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com> CC: Scott Wood <scottwood@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-04-12Makefile: Change CONFIG_SPL_PAD_TO to image offsetBenoît Thébaudeau
Change CONFIG_SPL_PAD_TO from a link address to an image offset since this is more handy and closer to the purpose of this config. Automatically define CONFIG_SPL_PAD_TO to CONFIG_SPL_MAX_SIZE (or 0 without CONFIG_SPL_MAX_SIZE). Test that CONFIG_SPL_PAD_TO >= CONFIG_SPL_MAX_SIZE if CONFIG_SPL_PAD_TO is non-zero. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2012-11-26powerpc/mpc85xx/p2020rdb-pca: Use L2 SRAM for SPL bootScott Wood
This allows DDR configuration to be deferred to the final U-Boot image, which is able to make use of SPD data. The SPL itself cannot use SPD due to code size constraints. It previously used fixed register values for DDR configuration, and those values did not work on the p2020rdb-pca board I tested with. It's possible that different revisions of the board require different settings. Using SPD eliminates that problem. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2012-11-26powerpc/mpc85xx/p1_p2_rdb_pc: clean up memory mapScott Wood
- Sort by address, and fix column alignment - Don't label things as localbus that aren't. Instead, put chipselect info at the end of the description for localbus windows. Note that NAND/NOR have their chipselects swapped when booting from NAND, and CS2 can be either PMC or VSC7385 depending on hwconfig. - Shrink NAND to the 32K that's actually mapped in the localbus - Assign an address and size to L2 SRAM. Remove the similarly named but unintelligible "L2 SDRAM(REV.)". - Remove the untrue comment about L1 stack being mapped with TLB0. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2012-11-26powerpc/mpc85xx/p1_p2_rdb_pc: convert from nand_spl to new splScott Wood
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-08-23powerpc/p1_p2_rdb_pc: print -PC suffix in board nameScott Wood
Currently the -PC variants of the P1/P2 RDB boards do not print it on boot -- e.g. a P2020RDB-PC will claim to be a plain P2020RDB. Besides being incorrect, this can confuse a user into building U-Boot for P2020RDB rather than P2020RDB-PC, resulting in a board that does not boot. P1024RDB and P1025RDB are not included, as these boards apparently do not have -PC as part of their name, even though they are supported by p1_p2_rdb_pc. The P2020RDB variant covered by this is apparently P2020RDB-PCA rather than P2020RDB-PC. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-08powerpc/85xx: improve definition of BR_PHYS_ADDR macroTimur Tabi
The BR_PHYS_ADDR(x) macro was missing parentheses around "x" in the macro definition, so callers had to supply their own parenthesis. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_STRTOULTom Rini
This define does not control anything, remove it. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_VSPRINTFTom Rini
2012-04-24PowerPC: correct the SATA for p1/p2 rdb-pc platformJerry Huang
For p1/p2 rdb-pc platform, use the PCIe-SATA Silicon Image SATA controller. Therefore, the SATA driver will use sata_sil, instead sata_sil3114. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> CC: Andy Fleming <afleming@gmail.com>
