path: root/include/configs/openrd.h
2018-01-10ARM: Drop unreferenced CONFIG_MACH_* definesTuomas Tynkkynen
These macros are all defined once and never checked or used anywhere: CONFIG_MACH_ASPENITE CONFIG_MACH_DAVINCI_CALIMAIN CONFIG_MACH_DOCKSTAR CONFIG_MACH_EDMINIV2 CONFIG_MACH_GOFLEXHOME CONFIG_MACH_GONI CONFIG_MACH_GURUPLUG CONFIG_MACH_KM_KIRKWOOD CONFIG_MACH_OPENRD_BASE CONFIG_MACH_SHEEVAPLUG Almost all of them were only used for the mach_is_foo() logic in arch/arm/asm/mach-types.h that were dropped in commit f9dadaef8b75fa ("arm: Re-sync asm/mach-types.h with Linux Kernel v4.9") Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-10Revive OpenRD targetsAlbert ARIBAUD
Revert commit 7a2c1b13 which dropped OpenRD boards. Assume maintainership of OpenRD. Remove OpenRD from scrapyard. Switch OpenRD to generic board. Switch to Thumb build. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-09-11arm: Remove openrd boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-08-14openrd: fail build if U-Boot would overlap with environment in flashSascha Silbe
Set CONFIG_BOARD_SIZE_LIMIT so we'll notice at build time if U-Boot has grown so large that it would overlap with the environment area in flash, rather than bricking the device at run-time on first saveenv. Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
2014-08-01ARM: kirkwood: add mvsdio driverDrEagle
This patch add Marvell kirkwood MVSDIO/MMC driver and enable it for Sheevaplugs and OpenRD boards. Signed-off-by: Gerald Kerma <drEagle@doukki.net> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2011-05-31Kirkwood: boards cleanup for deprecated CONFIG_CMD_AUTOSCRIPTAlbert ARIBAUD
2011-05-11Enable multiple fs options for Marvell SoC family on OpenRD boardsClint Adams
Signed-off-by: Clint Adams <clint@debian.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Julian Pidancet <julian.pidancet@citrix.com>
2011-05-11Initialize second PHY on OpenRD-Client and OpenRD-UltimateClint Adams
Though the OpenRD-Base only has one gigabit Ethernet port, both the OpenRD-Client and OpenRD-Ultimate each have two. On the Ultimate, the PHY addresses are consecutive, but on the Client they are not. (based on <62a0952ce368acc725063a00a5ec680a639d6c27.1301040318.git.julian.pidancet@citrix.com> <ad0a2dc1e422698b005d6f0ceb6dd6f75a87e00a.1301040318.git.julian.pidancet@citrix.com> ) Signed-off-by: Clint Adams <clint@debian.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Julian Pidancet <julian.pidancet@citrix.com>
2011-05-11Add definitions for OpenRD-Client and OpenRD-UltimateClint Adams
2011-05-11Rename openrd_base files to openrdClint Adams
