path: root/include/configs/omap730.h
2010-10-13arch/arm/include/asm/sizes.h: cleanupsAndreas Bießmann
Merge several sizes.h in asm/arch subdirectories into a single asm/sizes.h file. Fixup usage of asm/arch/sizes.h in some files to use the merged file. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2008-09-12ARM OMAP : Correct Invalid Timer Register Field Declaration in omap1510.h & ↵Gururaja Hebbar K R
omap730.h - Correct Invalid #define of MPUTIM_PTV_MASK for omap1510 & omap730 register definition MPUTIM_PTV_MASK is defined as #define MPUTIM_PTV_MASK (0x7<<PTV_BIT) while it should have been #define MPUTIM_PTV_MASK (0x7<<MPUTIM_PTV_BIT) - Below Patch corrects the same Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
2004-06-08* Patch by Rishi Bhattacharya, 08 May 2004:wdenk
Add support for TI OMAP5912 OSK Board * Patch by Sam Song May, 07 May 2004: Fix typo of UPM table for rmu board
2004-06-06* Patch by Dave Peverley, 30 Apr 2004:wdenk
Add support for OMAP730 Perseus2 Development board * Patch by Alan J. Luse, 29 Apr 2004: Fix flash chip-select (OR0) option register setting on FADS boards. * Patch by Alan J. Luse, 29 Apr 2004: Report MII network speed and duplex setting properly when auto-negotiate is not enabled. * Patch by Jarrett Redd, 29 Apr 2004: Fix hang on reset on Ocotea board due to flash in wrong mode.
