path: root/include/configs/omap5_uevm.h
2015-01-05TI: armv7: enable UUID and PARTNishanth Menon
Enable UUID and partition support for scripted handling platforms with MMC and eMMC and varied partitioning schemes And remove it from headers that end up redefining it. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-12-04arm: omap5: don't enable misc_init_r by defaultFelipe Balbi
Out of all OMAP5-like boards, only one of them needs CONFIG_MISC_INIT_R, so it's best to enable that for that particular board only, instead of enabling for all boards unconditionally. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-10OMAP5+: sata/scsi: Implement scsi_init()Roger Quadros
On OMAP platforms, SATA controller provides the SCSI subsystem so implement scsi_init(). Get rid of the unnecessary sata_init() call from dra7xx-evm and omap5-uevm board files. Signed-off-by: Roger Quadros <rogerq@ti.com>
2014-04-17TI:omap5: Move CONFIG_ENV_SIZE to board config filesTom Rini
The size of the environment depends on the backing store, move this to the board config files. Signed-off-by: Tom Rini <trini@ti.com>
2014-02-17Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-02-07omap5_uevm: Add CONFIG_SUPPORT_EMMC_BOOT, document usageTom Rini
Add a README to the board which lists the commands required to enable booting from the eMMC boot partitions found on the board. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-01-24ARM: OMAP5: Rename to ti_omap5_common.hEnric Balletbò i Serra
Follow the pattern ti_<processor family>_common.h used by other TI processors to be coherent. So just rename omap5_common.h to ti_omap5_common.h. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-01-08ARM: omap5_uevm: Enable 8-bit eMMC accessLubomir Popov
All prerequisites are already available, so why not enable 8-bit access - it is a matter of a define in the board file only. Signed-off-by: Lubomir Popov <l-popov@ti.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-12-04ARM: omap5_uevm: Add SATA supportRoger Quadros
The uevm has a SATA port. Inititialize the SATA controller. Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-09-04Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-08-28omap5_uevm: Better comment why we have TCA642X and the reset timeTom Rini
2013-08-27omap5: Correct include order, drop CONFIG_SYS_PROMPT defineTom Rini
With the new include structure for TI platforms, we need to not define our own CONFIG_SYS_PROMPT and also need to include <configs/omap5_common.h> much sooner, so do both of these. Also drop the unused CONFIG_NET_MULTI Signed-off-by: Tom Rini <trini@ti.com>
2013-08-26ARM: OMAP5-uevm: Add USB ehci support for the uEVMDan Murphy
Add the USB ehci support for the OMAP5 uEVM. Configure the uEVM mux data Add the flags to build the appropriate modules Add the usb call backs to initialize the EHCI controller Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-08-15TI:omap5/dra7xx: Convert to ti_armv7_common.hTom Rini
Update omap5_common.h to use ti_armv7_common.h, and in turn update dra7xx_evm.h and omap5_uevm.h slightly. The biggest changes here are that IP blocks which exist on the platform, and had clocks enabled, now have the drivers being built as well. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-30gpio: omap5-uevm: Configure the tca6424 gpio expanderDan Murphy
Configure the tca6424 gpio expander This allows use of the debug and tri color LEDs. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-06-18arm: dra7xx: Update the EXTRA_ENV_SETTINGSDan Murphy
Update the EXTRA_ENV_SETTING for the dra7xx. The console needs to be set to ttyO0 and the findfdt needs to be updated to load the dra7xx-evm.dtb file. Signed-off-by: Dan Murphy <dmurphy@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-06-18arm: omap5_uevm: Correct the console sys prompt for 5432Dan Murphy
Correct the console sys prompt to display the correct processor and the corrent board Signed-off-by: Dan Murphy <dmurphy@ti.com> Reported-by: Lubomir Popov <lpopov@mm-sol.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-06-10mmc: omap_hsmmc: Update pbias programmingBalaji T K
Update pbias programming sequence for OMAP5 ES2.0/DRA7 Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-06-10ARM: DRA7xx: Change the Debug UART to UART1Sricharan R
Serial UART is connected to UART1. So add the change for the same. Signed-off-by: Sricharan R <r.sricharan@ti.com>
2013-05-11Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-05-10ARM: OMAP5: Fix warm reset with USB cable connectedLokesh Vutla
Warm reset on OMAP5 freezes when USB cable is connected. Fix requires PRM_RSTTIME.RSTTIME1 to be programmed with the time for which reset should be held low for the voltages and the oscillator to reach stable state. There are 3 parameters to be considered for calculating the time, which are mostly board and PMIC dependent. -1- Time taken by the Oscillator to shut + restart -2- PMIC OTP times -3- Voltage rail ramp times, which inturn depends on the PMIC slew rate and value of the voltage ramp needed. In order to keep the code in u-boot simple, have a way for boards to specify a pre computed time directly using the 'CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC' option. If boards fail to specify the time, use a default as specified by 'CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC' instead. Using the default value translates into some ~22ms and should work in all cases. However in order to avoid this large delay hiding other bugs, its recommended that all boards look at their respective data sheets and specify a pre computed and optimal value using 'CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC' In order to help future board additions to compute this config option value, add a README at doc/README.omap-reset-time which explains how to compute the value. Also update the toplevel README with the additional option and pointers to doc/README.omap-reset-time. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [rnayak@ti.com: Updated changelog and added the README] Signed-off-by: Rajendra Nayak <rnayak@ti.com>
2013-05-10twl6035: rename to palmasNishanth Menon
TPS659038/TWL6035/TWL6037 all belong to palmas family of TI PMICs Rename twl6035 to palmas to allow reuse across multiple current and future platforms As part of this change, change the CONFIG_TWL6035_POWER to CONFIG_PALMAS_POWER and update usage of header file accordingly. Signed-off-by: Nishanth Menon <nm@ti.com>
2013-05-01omap5_uevm: Enable redundant MMC environmentTom Rini
Cc: Sricharan R <r.sricharan@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-10omap5_uevm: Correct to 2MiB aligned partitions on eMMCTom Rini
This has a 2MiB erase block size eMMC, so make sure we align on that for best possible performance. Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08omap5_uevm.h: Move uEVM-specific choices to omap5_uevm.hTom Rini
The omap5_uevm platform has eMMC, and it makes sense to say that our default env storage shall reside there. Other platforms may not, so move this choice to the EVM config. In addition, we should provide some way to partition the flash for later usage, so take advantage of the GPT partition table support code and allow that to be setup with some reasonable defaults. Cc: Sricharan R <r.sricharan@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08ARM: OMAP5: Rename omap5_evm to omap5_uevmSRICHARAN R
The omap5-uevm is the reference board name for OMAP5 soc based platform. So rename it accordingly. Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Tested-by: Nishanth Menon <nm@ti.com>
