path: root/include/configs/omap4_panda.h
2015-03-28ARM: omap4_panda: enable saveenv commandmaxin.john@enea.com
Enable saveenv command and the configs to store environment persistently in the SD card. Tested on OMAP4 Panda (OMAP4460 ES1.1) Signed-off-by: Maxin B. John <maxin.john@enea.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-01-24ARM: OMAP4: Rename to ti_omap4_common.hEnric Balletbò i Serra
Follow the pattern ti_<processor family>_common.h used by other TI processors to be coherent. So just rename omap4_common.h to ti_omap4_common.h. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-12-06omap4_panda: Don't use ulpi_resetRoger Quadros
Fixes this error message when USB is started. "ULPI: ulpi_reset: failed writing reset bit" It is pointless to manually reset the ULPI as the USB Host Reset and PHY RESET line should take care of that. Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Roger Quadros <rogerq@ti.com>
2013-11-01ARM: OMAP4: Convert to ti_armv7_common.hLokesh Vutla
Update omap4_common.h to use ti_armv7_common.h Testing: * Boot tested on OMAP4430 ES2.1 OMAP4460 ES1.1 SDP, OMAP4 PANDA/PANDA ES * Verified ./MAKEALL -s omap Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-05-10ARM: Panda: Add flag to allow runtime enviroment varibale modsDan Murphy
Add the flag to allow runtime enviroment variable modifications. This is being added so that the board-name can be modified at runtime to indicate either a panda(4430) or a panda-es(4460) Signed-off-by: Dan Murphy <dmurphy@ti.com>
2012-10-01omap4_panda: remove CONFIG_PANDA, not usedPeter Meerwald
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net>
2012-02-12OMAP4: ehci-omap: enable ehci-omap for panda boardsGovindraj.R
For panda initialise the mux pins for ehci usage and enable ehci in omap4_panda config file. Signed-off-by: Govindraj.R <govindraj.raja@ti.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12usb: ulpi: Add omap-ulpi-view port supportGovindraj.R
Based on discussion from this thread [1]. Adding omap-view port that helps us in using the generic ulpi framework for any ulpi phy ops using the INSNREG05_ULPI viewport reg available on omap platform. Currently ehci ports are available on omap3/4 platforms so enable the same for beagle and panda, patch is tested on the same boards. Thanks to Igor Grinberg <grinberg@compulab.co.il> for reviewing the omap-ehci patches and suggesting this approach. [1]: http://www.mail-archive.com/u-boot@lists.denx.de/msg76076.html Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2011-10-27omap4_panda: Build in cmd_gpio support on pandaJoe Hershberger
Enable the gpio command Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-22Minor Coding Style CleanupWolfgang Denk
2011-09-13omap4: factor out common part from board config headersAneesh V
Factor out common parts from omap4_sdp4430.h and omap4_panda.h into a new file omap4_common.h Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3/4: Increase console I/O buffer sizeVaibhav Hiremath
Increase the console I/O buffer size (SYS_CBSIZE) to 512 (from 256) required especially for bootargs string, as multiple options (e.g Video settings) are passed to the kernel through bootargs. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04omap4: increase SRAM budget to fix build errorAneesh V
Signed-off-by: Aneesh V <aneesh@ti.com> Cc: Dirk Behme <dirk.behme@googlemail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Acked-by: Dirk Behme<dirk.behme@googlemail.com>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-08-03omap: add MMC and FAT support to SPLAneesh V
- Add MMC raw and FAT mode boot support for OMAP - Provide a means by which parameters passed by ROM-code can be saved in u-boot. - Save boot mode related information passed by OMAP4 ROM-code and use it to determine where to load the u-boot from - Assumes that the image has a mkimage header. Gets the payload size and load address from this header. If the header is not detected assume u-boot.bin as payload Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03omap: add basic SPL supportAneesh V
- Provide alternate implementations of board_init_f() board_init_r() for OMAP spl. - Provide linker script - Initialize global data - Add serial console support - Update CONFIG_SYS_TEXT_BASE to allow for SPL's bss and move it to board config header from config.mk Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03omap4: automatic sdram detectionAneesh V
Identify SDRAM devices connected to EMIF automatically: LPDDR2 devices have some Mode Registers that provide details about the device such as the type, density, bus width etc. EMIF has the capability to read these registers. If there are no devices connected to a given chip-select reading mode registers will return junk values. After reading as many such registers as possible and matching with expected ranges of values the driver can identify if there is a device connected to the respective CS. If we identify that a device is connected the values read give us complete details about the device. This along with the base AC timings specified by JESD209-2 allows us to do a complete automatic initialization of SDRAM that works on all boards. Please note that the default AC timings specified by JESD209-2 will be safe for all devices but not necessarily optimal. However, for the Elpida devices used on Panda and SDP the default timings are both safe and optimal. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-03omap4: calculate EMIF register valuesAneesh V
Calculate EMIF register values based on AC timing parameters from the SDRAM datasheet and the DDR frequency rather than using the hard-coded values. For a new board the user doen't have to go through the tedious process of calculating the register values. Instead, just provide the AC timings from the device data sheet as input and the driver will automatically calculate the register values. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-04armv7: adapt omap4 to the new cache maintenance frameworkAneesh V
adapt omap4 to the new layered cache maintenance framework Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-04-28Add CONFIG_OF_LIBFDT to more boards.Grant Likely
The following boards gain device tree support with this patch: ca9x4_ct_vxp - Versatile Express i.mx5 boards: efikamx mx51evk mx53evk OMAP boards: devkit8000 igep0020 igep0030 omap3_overo omap3_pandora omap4_sdp3430 omap3_zoom1 omap3_zoom2 omap4_panda omap4_sdp4430 Tegra boards: Harmony Signed-off-by: Grant Likely <grant.likely@linaro.org>
2010-11-19OMAP4: Panda: Disable CMD_NFSSteve Sakoman
This patch fixes the Panda build after commit 6d8962e814c15807dd6ac5757904be2a02d187b8 by explicitly disabling CMD_NFS >From the commit message for "Switch from archive libraries to partial linking": This commit reveals board configurations that exclude some features but include source files that depend these disabled features in the build, resulting in undefined symbols. Known such cases include: - disabling CMD_NET but not CMD_NFS; - enabling CONFIG_OF_LIBFDT but not CONFIG_QE. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP: Fix build after introduction of GENERATED_GBL_DATA_SIZESteve Sakoman
This patch fixes the issue by defining and using CONFIG_SYS_INIT_RAM_SIZE and CONFIG_SYS_INIT_RAM_ADDR. Based on an email discussion with Wolfgang Denk and Heiko Schocher. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17ARMV7: OMAP4: Implement relocation for Panda and OMAP4430SDPSteve Sakoman
This patch fixes the build breakage introduced by the recent relocation changes for ARMV7 Signed-off-by: Steve Sakoman <steve@sakoman.com>
2010-10-17ARMV7: OMAP4: Use generic mmc driver on PandaSukumar Ghorai
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Sukumar Ghorai <s-ghorai@ti.com> Tested-by: Steve Sakoman <steve@sakoman.com>
2010-10-17ARMV7: OMAP: Use default vendor/product ID for USB gadgetSteve Sakoman
TI hasn't reserved a USB Product ID for gadgets, so use the default vendor and product ID to avoid confusion. Signed-off-by: Steve Sakoman <steve@sakoman.com>
2010-08-05ARMV7: Update default environment for OMAP4 boardsSteve Sakoman
Specify vram on command line, remove erroneous call to nandboot in the boot script, add CONFIG_BOOTDELAY Signed-off-by: Steve Sakoman <steve@sakoman.com> Acked-by: Nishanth Menon <menon.nishanth@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Enable musb driver and usbtty on OMAP4 PandaSteve Sakoman
Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Add support for the TWL6030 I2C power chip used in OMAP4 systemsSteve Sakoman
This patch add the basic infrastructure for the TWL6030 driver and enables support in the two existing OMAP4 boards, Panda and OMAP4430 SDP Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Fix udelay for OMAP4Steve Sakoman
The OMAP4 x-load code sets gptimer1 clock source to 32Khz. This isn't acceptable for udelay. This patch changes from gptimer1 to gptimer2, which uses sys_clk at 38.4 Mhz. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-08-05ARMV7: Add pad mux support for OMAP4Steve Sakoman
Add functional multiplexing support for OMAP4 pads. Configure all the pads for the OMAP4430 SDP and OMAP4 Panda boards Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARMV7: Add support for TI OMAP4 PandaSteve Sakoman
OMAP4 Panda is a reference board based on OMAP4430, an ARMV7 Cortex A9 CPU This patch adds basic support for booting the board. It includes i2c and mmc support. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. U-boot currently relies on x-load for clock, mux, and SDRAM initialization Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
