path: root/include/configs/omap3_zoom1.h
2014-03-04mtd: nand: omap: remove unused #defines from common omap_gpmc.hpekon gupta
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI params or nand_id[] table. And based on that it defines ECC layout. This patch 1) removes following board configs used for defining NAND ECC layout - GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND) - GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND) - GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND) - GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND) 2) removes unused #defines in common omap_gpmc.h depending on above configs Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-08-15ARM: OMAP: Add CONFIG_OMAP_COMMONLokesh Vutla
Adding a new CONFIG_OMAP_COMMON which is included by all boards that needs to build cpu/armv7/omap-common folder. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-01-29Remove unused CONFIG_SYS_I2C_BUS[_SELECT]Michael Jones
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere outside of config files. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-10OMAP3: Remove unused PHYS_SDRAM_1_SIZEThomas Weber
Remove the unused PHYS_SDRAM_1_SIZE from OMAP3 config files. Signed-off-by: Thomas Weber <thomas@tomweber.eu>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-01-16OMAP3: Remove unused define CONFIG_OMAP3_*_DDRThomas Weber
This patch removes the unused definitions: CONFIG_OMAP3_MICRON_DDR CONFIG_OMAP3_NUMONYX_DDR CONFIG_OMAP3_INFINEON_DDR Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unusedThomas Weber
This patch removes the definition of stack sizes for irq and fiq if the CONFIG_USE_IRQ is undefined before. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP3: Remove unused define SDRC_R_C_BThomas Weber
This patch removes the unused definition of SDRC_R_C_B from the config files. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it> Acked-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP3: Remove unused define CONFIG_OMAP3430Thomas Weber
This patch removes the CONFIG_OMAP3430, because it is unused. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06omap: fix cache line size for omap3/omap4 boardsAneesh V
Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-09-04OMAP3: Zoom1: Use generic MMC driverTom Rini
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3/4: Increase console I/O buffer sizeVaibhav Hiremath
Increase the console I/O buffer size (SYS_CBSIZE) to 512 (from 256) required especially for bootargs string, as multiple options (e.g Video settings) are passed to the kernel through bootargs. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-04-28Add CONFIG_OF_LIBFDT to more boards.Grant Likely
The following boards gain device tree support with this patch: ca9x4_ct_vxp - Versatile Express i.mx5 boards: efikamx mx51evk mx53evk OMAP boards: devkit8000 igep0020 igep0030 omap3_overo omap3_pandora omap4_sdp3430 omap3_zoom1 omap3_zoom2 omap4_panda omap4_sdp4430 Tegra boards: Harmony Signed-off-by: Grant Likely <grant.likely@linaro.org>
2011-04-27ARMV7: OMAP3: Cleanup extern variables in mem.cLuca Ceresoli
Removed boot_flash_* extern variables. boot_flash_type was totally unused. The other ones were actually constants, so they have been replaced with #defines in the board config files. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30OMAP3: Zoom1: Fix ARM relocation supportDirk Behme
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-19OMAP3: remove unused config macrosGrazvydas Ignotas
Most OMAP3 boards have various flash related macros in their configs that are either not referenced anywhere in the code or are used by drivers that are not enabled. Remove them. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08omap3: Consolidate SDRC related operationsVaibhav Hiremath
Consolidated SDRC related functions into one file - sdrc.c And also replaced sdrc_init with generic memory init function (mem_init), this generalization of omap memory setup is necessary to support the new emif4 interface introduced in AM3517. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12OMAP3 Move declaration of gpmc_cfg.Tom Rix
Every omap3 board config file declared the global variable gpmc_cfg. This changes moves the declaration to a better location in the arch dependent header file cpu.h. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-01-04Remove superfluous uses of V_PROMPT macro.Robert P. J. Day
A number of config files define the V_PROMPT macro for the command-line prompt, only to immediately use that macro to define CONFIG_SYS_PROMPT, making V_PROMPT entirely superfluous. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2009-12-20OMAP3 zoom1 Add usbtty configurationTom Rix
The primary console of zoom1 is the serial out from the jumpers accessed by removing the back panel. A secondary console is to use the usbtty. The user can set this manually by doing setenv stdout usbtty; setenv stdin usbtty; setenv stderr usbtty saveenv usbtty will be usable by accessing the /dev/ttyACM0 on a linux host. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-11-27OMAP3:SDRC: introduce DDR typesNishanth Menon
Micron DDR timings based on: http://www.sakoman.net/cgi-bin/gitweb.cgi?p=x-load-omap3.git;a=blob;f=include/asm/arch-omap3/mem.h;h=e6fbfe3947f5d0d85fea776e30821d4017316d86;hb=HEAD Introduce Micron DDR timings and provide CONFIG_OMAP3_INFINEON_DDR and CONFIG_OMAP3_MICRON_DDR config options to allow for platform files to setup their timings as per the type of DDR selected Reported-by: Steve Sakoman in http://www.nabble.com/forum/Permalink.jtp?root=25779518&post=25959734&page=y Signed-off-by: Nishanth Menon <nm@ti.com>
2009-10-18TI: OMAP3: Remove SZ_xx referencesSandeep Paulraj
This patch removes dependency on the sizes.h header file and removes all references to SZ_xx. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-13TI OMAP3 Use arm init sequence to initialize i2cTom Rix
This changes fixes an early i2c error. It appears that I2C is working because once a read or write error is detected, the omap24xx_i2c driver calls i2c_init inside its error handling check. While it is ok to attempt error handling this way, the boards must not depend on this side effect to initialize it's i2c. Instead of explicitly calling i2c_init for every board, use the generic arm initialization in lib_arm/board.c. By defining the config variable CONFIG_HARD_I2C, the omap3 i2c initialization is included in the init_sequence table. Run tested on Beagle. Compile tested on the omap3's Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-08omap3: remove typedefs for configuration structsDirk Behme
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-08-07omap3: embedd gpmc_cs into gpmc config structMatthias Ludwig
Embedd chip select configuration into struct for gpmc config instead of having it completely separated as suggested by Wolfgang Denk on http://lists.denx.de/pipermail/u-boot/2009-May/052247.html Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
2009-07-29OMAP3 Move twl4030 power and led functionsTom Rix
Because twl4030 now has its own device files, move exiting omap3 power_init_r to a new location. power_init_r is the only function in board/omap3/common. It initializes the twl4030 power for the board and enables the led. The power part of the the function is moved to twl4030_power_init in drivers/power/twl4030.c The power compilation is conditional on the existing config variable CONFIG_TWL4030_POWER. The led part is moved to twl4030_led_init in the new file drivers/misc/twl4030_led.c The led compilation is conditional on the new config variable CONFIG_TWL4030_LED The directory board/omap3/common was removed because power_init_r was the only function in it. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Heiko Schocher <hs@denx.de>
2009-07-28TWL4030 Add power reset buttonTom Rix
The Zoom2 power reset button is on the top right side of the main board. Press and hold for about to 8 seconds to completely reset the board. Some of the beta boards have a hardware problem that prevents using this feature. If is difficult to further characterize the boards that fail. So disable resetting for all beta boards. The Zoom1 reset button is the red circle on the top right, front of the board. Press and hold the button for 8 seconds to completely reset the board. After analyzing beagle, it was determined that other boards that use the twl4030 for power managment can also make use this function. The resetting is done by the power management part of the twl4030. Since there is no existing drivers/power, add one. The compilation of power/twl4030.h is controlled by the config variable CONFIG_TWL4030_POWER Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Heiko Schocher <hs@denx.de>
2009-07-18NAND: Part 2: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. This patch covers the non-PPC boards that were missed in the previous patch (commit 170c1972). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12ZOOM1 Remove more legacy NAND defines.Tom Rix
These legacy NAND defines are no longer needed by this target. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-04-30OMAP3: Fix timer handling to 1ms and CONFIG_SYS_HZ to 1000Manikandan Pillai
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
2009-04-29OMAP3: Use functions print_cpuinfo() and checkboard()Sanjeev Premi
Use the functions print_cpuinfo() and checkboard() to display the cpu and board specific information. These functions reuse content from the existing function display_board_info() - which has been removed. Also, updated the existig OMAP3 configurations to define: - CONFIG_DISPLAY_CPUINFO - CONFIG_DISPLAY_BOARDINFO Signed-off-by: Sanjeev Premi <premi@ti.com>
2009-04-26OMAP3: Fix changed mmc init commandDirk Behme
In recent U-Boot mmcinit changed to mmc init. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-04-05ZOOM1 Remove legacy NAND definesTom Rix
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-30OMAP: rename timer divisorLadislav Michl
Divisor field is called PTV not PVT. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
2009-02-06ARM:OMAP3:Zoom1: Add nand unlock optionNishanth Menon
Enable NAND_UNLOCK option for unlocking nand for erase/write operations Signed-off-by: Nishanth Menon <nm@ti.com>
2009-01-28OMAP3: Add Zoom1 board supportDirk Behme
Support for Zoom MDK with OMAP3430. Details of Zoom MDK available here: http://www.logicpd.com/products/devkit/ti/zoom_mobile_development_kit Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
