path: root/include/configs/omap3_zoom1.h
2015-08-12ti: drop value from CONFIG_SYS_NAND_BUSWIDTH_16BITStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-03-13ARM: OMAP3: Rename omap3.h to omap.h to be generic as all SoCsNishanth Menon
This is in preperation of using generic cross OMAP code. Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-25ARM: omap: move board specific NAND configs out from ti_armv7_common.hpekon gupta
This patch moves some board specific NAND configs: - FROM: generic config file 'ti_armv7_common.h' - TO: individual board config files using these configs. So that each board can independently set the value as per its design. Following configs are affected in this patch: CONFIG_SYS_NAND_U_BOOT_OFFS: <refer doc/README.nand> CONFIG_CMD_SPL_NAND_OFS: <refer doc/README.falcon> CONFIG_SYS_NAND_SPL_KERNEL_OFFS: <refer doc/README.falcon> CONFIG_CMD_SPL_WRITE_SIZE: <refer doc/README.falcon> This patch also updates documentation for few of above NAND configs. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-07-25ARM: omap: clean redundant PISMO_xx macros used in OMAP3pekon gupta
PISMO_xx macros were used to define 'Platform Independent Storage MOdule' related GPMC configurations. This patch - Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided by current u-boot infrastructure. - Removes unused redundant macros, which are no longer required after merging of common platform code in following commit commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform +-----------------+-----------------------------------------------------------+ | Macro | Reason for removal | +-----------------+-----------------------------------------------------------+ | PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so | | | configuring GPMC chip-select for smallest allowable | | | segment (GPMC_SIZE_16M) is enough. | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of | | | 128MB (GPMC_SIZE_128M) | +-----------------+-----------------------------------------------------------+ +-----------------+-----------------------------------------------------------+ | PISMO1_NOR | Unused Macros | | PISMO1_NAND | | | PISMO2_CS0 | | | PISMO2_CS1 | | | PISMO1_ONENAND | | | PISMO2_NAND_CS0 | | | PISMO2_NAND_CS1 | | | PISMO1_NOR_BASE | | | PISMO1_NAND_BASE| | | PISMO2_CS0_BASE | | +-----------------+-----------------------------------------------------------+ Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-06mtd: nand: omap: add CONFIG_SYS_NAND_BUSWIDTH_16BIT to indicate NAND device ↵pekon gupta
bus-width GPMC controller needs to be configured based on bus-width of the NAND device connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI parameters is not possible in following situations: SPL: SPL NAND drivers does not support ONFI parameter reading. U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init() which is called before probing for devices, hence any ONFI parameter information is not available during GPMC initialization. Thus, OMAP NAND driver expected board developers to explicitely write GPMC configurations specific to NAND device attached on board in board files itself. But this was troublesome for board manufacturers as they need to dive into lengthy platform & SoC documents to find details of GPMC registers and appropriate configurations to get NAND device working. This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config hich indicates that connected NAND device has x16 bus-width. And then based on this config GPMC driver itself initializes itself based on NAND bus-width. This keeps board developers free from knowing GPMC controller specific internals. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-04-17omap3: zoom1: switch to generic ti_omap3_common config headerNishanth Menon
ti_omap3_common contains a lot of common header definitions that help reduce the size of the zoom1 config file. So, use the generic header and customize as needed for the platform (example: no spl). Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: fix default consoleNishanth Menon
We do not use ttyS2 anymore in Linux, it changed to ttyO2 a few years back. never too late to update. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: enable bootzNishanth Menon
Boot from zImage and fdt_file if uImage is not available to maintain the legacy behavior. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: disable JFFS2 and enable FS_GENERICNishanth Menon
This is more in line with commits 664979a2a9f764b63b8094458b87247d254b0cc1(omap3_beagle: remove JFFS2 support.) and 102ce9ea7afdda80fe25aa786975e1722196bdb9 (omap3_beagle: enable CMD_FS_GENERIC and simplify load of image/ramdisk) CMD_FS_GENERIC allows us to simplify where we load up our image from either from ext2/fat etc. So, lets use that instead of cumbersome options we'd have to use. Sticking with existing conventions, defaults will be: bootfile=uImage bootpart=0:1 (first partition) bootdir=/ (/ in first partition) Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: enable common network commandsNishanth Menon
Basic networking commands for usability. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17OMAP3: zoom1: enable LAN9211Nishanth Menon
Zoom1 was wrongly setup for LAN91C96. Fix it by enabling LAN9211. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: enable CONFIG_SYS_GENERIC_BOARDNishanth Menon
CONFIG_SYS_GENERIC_BOARD should now be enabled for generic functionality Further information in doc/README.generic-board Signed-off-by: Nishanth Menon <nm@ti.com>
2014-03-04mtd: nand: omap: remove unused #defines from common omap_gpmc.hpekon gupta
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI params or nand_id[] table. And based on that it defines ECC layout. This patch 1) removes following board configs used for defining NAND ECC layout - GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND) - GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND) - GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND) - GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND) 2) removes unused #defines in common omap_gpmc.h depending on above configs Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-08-15ARM: OMAP: Add CONFIG_OMAP_COMMONLokesh Vutla
Adding a new CONFIG_OMAP_COMMON which is included by all boards that needs to build cpu/armv7/omap-common folder. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-01-29Remove unused CONFIG_SYS_I2C_BUS[_SELECT]Michael Jones
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere outside of config files. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-10OMAP3: Remove unused PHYS_SDRAM_1_SIZEThomas Weber
Remove the unused PHYS_SDRAM_1_SIZE from OMAP3 config files. Signed-off-by: Thomas Weber <thomas@tomweber.eu>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-01-16OMAP3: Remove unused define CONFIG_OMAP3_*_DDRThomas Weber
This patch removes the unused definitions: CONFIG_OMAP3_MICRON_DDR CONFIG_OMAP3_NUMONYX_DDR CONFIG_OMAP3_INFINEON_DDR Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unusedThomas Weber
This patch removes the definition of stack sizes for irq and fiq if the CONFIG_USE_IRQ is undefined before. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP3: Remove unused define SDRC_R_C_BThomas Weber
This patch removes the unused definition of SDRC_R_C_B from the config files. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it> Acked-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP3: Remove unused define CONFIG_OMAP3430Thomas Weber
This patch removes the CONFIG_OMAP3430, because it is unused. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06omap: fix cache line size for omap3/omap4 boardsAneesh V
Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-09-04OMAP3: Zoom1: Use generic MMC driverTom Rini
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3/4: Increase console I/O buffer sizeVaibhav Hiremath
Increase the console I/O buffer size (SYS_CBSIZE) to 512 (from 256) required especially for bootargs string, as multiple options (e.g Video settings) are passed to the kernel through bootargs. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-04-28Add CONFIG_OF_LIBFDT to more boards.Grant Likely
The following boards gain device tree support with this patch: ca9x4_ct_vxp - Versatile Express i.mx5 boards: efikamx mx51evk mx53evk OMAP boards: devkit8000 igep0020 igep0030 omap3_overo omap3_pandora omap4_sdp3430 omap3_zoom1 omap3_zoom2 omap4_panda omap4_sdp4430 Tegra boards: Harmony Signed-off-by: Grant Likely <grant.likely@linaro.org>
2011-04-27ARMV7: OMAP3: Cleanup extern variables in mem.cLuca Ceresoli
Removed boot_flash_* extern variables. boot_flash_type was totally unused. The other ones were actually constants, so they have been replaced with #defines in the board config files. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-30OMAP3: Zoom1: Fix ARM relocation supportDirk Behme
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-19OMAP3: remove unused config macrosGrazvydas Ignotas
Most OMAP3 boards have various flash related macros in their configs that are either not referenced anywhere in the code or are used by drivers that are not enabled. Remove them. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08omap3: Consolidate SDRC related operationsVaibhav Hiremath
Consolidated SDRC related functions into one file - sdrc.c And also replaced sdrc_init with generic memory init function (mem_init), this generalization of omap memory setup is necessary to support the new emif4 interface introduced in AM3517. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12OMAP3 Move declaration of gpmc_cfg.Tom Rix
Every omap3 board config file declared the global variable gpmc_cfg. This changes moves the declaration to a better location in the arch dependent header file cpu.h. Signed-off-by: Tom Rix <Tom.Rix@windriver.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-01-04Remove superfluous uses of V_PROMPT macro.Robert P. J. Day
A number of config files define the V_PROMPT macro for the command-line prompt, only to immediately use that macro to define CONFIG_SYS_PROMPT, making V_PROMPT entirely superfluous. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2009-12-20OMAP3 zoom1 Add usbtty configurationTom Rix
The primary console of zoom1 is the serial out from the jumpers accessed by removing the back panel. A secondary console is to use the usbtty. The user can set this manually by doing setenv stdout usbtty; setenv stdin usbtty; setenv stderr usbtty saveenv usbtty will be usable by accessing the /dev/ttyACM0 on a linux host. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-11-27OMAP3:SDRC: introduce DDR typesNishanth Menon
Micron DDR timings based on: http://www.sakoman.net/cgi-bin/gitweb.cgi?p=x-load-omap3.git;a=blob;f=include/asm/arch-omap3/mem.h;h=e6fbfe3947f5d0d85fea776e30821d4017316d86;hb=HEAD Introduce Micron DDR timings and provide CONFIG_OMAP3_INFINEON_DDR and CONFIG_OMAP3_MICRON_DDR config options to allow for platform files to setup their timings as per the type of DDR selected Reported-by: Steve Sakoman in http://www.nabble.com/forum/Permalink.jtp?root=25779518&post=25959734&page=y Signed-off-by: Nishanth Menon <nm@ti.com>
2009-10-18TI: OMAP3: Remove SZ_xx referencesSandeep Paulraj
This patch removes dependency on the sizes.h header file and removes all references to SZ_xx. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
