path: root/include/configs/omap3_zoom1.h
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SPL_WRITE_SIZE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL_WRITE_SIZE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SPL_NAND_OFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL_NAND_OFS Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-10Convert CONFIG_SYS_I2C_OMAP24XX to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_SYS_I2C_OMAP24XX Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-08-09Configs: Migrate CONFIG_SYS_I2C_OMAP34XX to CONFIG_SYS_I2C_OMAP24XXAdam Ford
The driver is for all boards 24XX and up, so let's eliminate the extra option called CONFIG_SYS_I2C_OMAP34XX since the driver checks for CONFIG_OMAP34XX we don't need CONFIG_SYS_I2C_OMAP34XX. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-05-15omap3: Drop unused CONFIG_OMAP3_xxx board definesTom Rini
We no longer have a need for a per-board CONFIG_OMAP3_xxx define (we have CONFIG_TARGET_xxx when this is required), so drop these unused references. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12ti: drop value from CONFIG_SYS_NAND_BUSWIDTH_16BITStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-03-13ARM: OMAP3: Rename omap3.h to omap.h to be generic as all SoCsNishanth Menon
This is in preperation of using generic cross OMAP code. Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-25ARM: omap: move board specific NAND configs out from ti_armv7_common.hpekon gupta
This patch moves some board specific NAND configs: - FROM: generic config file 'ti_armv7_common.h' - TO: individual board config files using these configs. So that each board can independently set the value as per its design. Following configs are affected in this patch: CONFIG_SYS_NAND_U_BOOT_OFFS: <refer doc/README.nand> CONFIG_CMD_SPL_NAND_OFS: <refer doc/README.falcon> CONFIG_SYS_NAND_SPL_KERNEL_OFFS: <refer doc/README.falcon> CONFIG_CMD_SPL_WRITE_SIZE: <refer doc/README.falcon> This patch also updates documentation for few of above NAND configs. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-07-25ARM: omap: clean redundant PISMO_xx macros used in OMAP3pekon gupta
PISMO_xx macros were used to define 'Platform Independent Storage MOdule' related GPMC configurations. This patch - Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided by current u-boot infrastructure. - Removes unused redundant macros, which are no longer required after merging of common platform code in following commit commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform +-----------------+-----------------------------------------------------------+ | Macro | Reason for removal | +-----------------+-----------------------------------------------------------+ | PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so | | | configuring GPMC chip-select for smallest allowable | | | segment (GPMC_SIZE_16M) is enough. | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of | | | 128MB (GPMC_SIZE_128M) | +-----------------+-----------------------------------------------------------+ +-----------------+-----------------------------------------------------------+ | PISMO1_NOR | Unused Macros | | PISMO1_NAND | | | PISMO2_CS0 | | | PISMO2_CS1 | | | PISMO1_ONENAND | | | PISMO2_NAND_CS0 | | | PISMO2_NAND_CS1 | | | PISMO1_NOR_BASE | | | PISMO1_NAND_BASE| | | PISMO2_CS0_BASE | | +-----------------+-----------------------------------------------------------+ Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-06-06mtd: nand: omap: add CONFIG_SYS_NAND_BUSWIDTH_16BIT to indicate NAND device ↵pekon gupta
bus-width GPMC controller needs to be configured based on bus-width of the NAND device connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI parameters is not possible in following situations: SPL: SPL NAND drivers does not support ONFI parameter reading. U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init() which is called before probing for devices, hence any ONFI parameter information is not available during GPMC initialization. Thus, OMAP NAND driver expected board developers to explicitely write GPMC configurations specific to NAND device attached on board in board files itself. But this was troublesome for board manufacturers as they need to dive into lengthy platform & SoC documents to find details of GPMC registers and appropriate configurations to get NAND device working. This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config hich indicates that connected NAND device has x16 bus-width. And then based on this config GPMC driver itself initializes itself based on NAND bus-width. This keeps board developers free from knowing GPMC controller specific internals. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-04-17omap3: zoom1: switch to generic ti_omap3_common config headerNishanth Menon
ti_omap3_common contains a lot of common header definitions that help reduce the size of the zoom1 config file. So, use the generic header and customize as needed for the platform (example: no spl). Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: fix default consoleNishanth Menon
We do not use ttyS2 anymore in Linux, it changed to ttyO2 a few years back. never too late to update. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: enable bootzNishanth Menon
Boot from zImage and fdt_file if uImage is not available to maintain the legacy behavior. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: disable JFFS2 and enable FS_GENERICNishanth Menon
This is more in line with commits 664979a2a9f764b63b8094458b87247d254b0cc1(omap3_beagle: remove JFFS2 support.) and 102ce9ea7afdda80fe25aa786975e1722196bdb9 (omap3_beagle: enable CMD_FS_GENERIC and simplify load of image/ramdisk) CMD_FS_GENERIC allows us to simplify where we load up our image from either from ext2/fat etc. So, lets use that instead of cumbersome options we'd have to use. Sticking with existing conventions, defaults will be: bootfile=uImage bootpart=0:1 (first partition) bootdir=/ (/ in first partition) Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: enable common network commandsNishanth Menon
Basic networking commands for usability. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17OMAP3: zoom1: enable LAN9211Nishanth Menon
Zoom1 was wrongly setup for LAN91C96. Fix it by enabling LAN9211. Signed-off-by: Nishanth Menon <nm@ti.com>
2014-04-17omap3: zoom1: enable CONFIG_SYS_GENERIC_BOARDNishanth Menon
CONFIG_SYS_GENERIC_BOARD should now be enabled for generic functionality Further information in doc/README.generic-board Signed-off-by: Nishanth Menon <nm@ti.com>
2014-03-04mtd: nand: omap: remove unused #defines from common omap_gpmc.hpekon gupta
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI params or nand_id[] table. And based on that it defines ECC layout. This patch 1) removes following board configs used for defining NAND ECC layout - GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND) - GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND) - GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND) - GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND) 2) removes unused #defines in common omap_gpmc.h depending on above configs Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-08-15ARM: OMAP: Add CONFIG_OMAP_COMMONLokesh Vutla
Adding a new CONFIG_OMAP_COMMON which is included by all boards that needs to build cpu/armv7/omap-common folder. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-01-29Remove unused CONFIG_SYS_I2C_BUS[_SELECT]Michael Jones
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere outside of config files. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-10OMAP3: Remove unused PHYS_SDRAM_1_SIZEThomas Weber
Remove the unused PHYS_SDRAM_1_SIZE from OMAP3 config files. Signed-off-by: Thomas Weber <thomas@tomweber.eu>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-01-16OMAP3: Remove unused define CONFIG_OMAP3_*_DDRThomas Weber
This patch removes the unused definitions: CONFIG_OMAP3_MICRON_DDR CONFIG_OMAP3_NUMONYX_DDR CONFIG_OMAP3_INFINEON_DDR Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unusedThomas Weber
This patch removes the definition of stack sizes for irq and fiq if the CONFIG_USE_IRQ is undefined before. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP3: Remove unused define SDRC_R_C_BThomas Weber
This patch removes the unused definition of SDRC_R_C_B from the config files. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it> Acked-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP3: Remove unused define CONFIG_OMAP3430Thomas Weber
This patch removes the CONFIG_OMAP3430, because it is unused. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06omap: fix cache line size for omap3/omap4 boardsAneesh V
Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-09-04OMAP3: Zoom1: Use generic MMC driverTom Rini
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3/4: Increase console I/O buffer sizeVaibhav Hiremath
Increase the console I/O buffer size (SYS_CBSIZE) to 512 (from 256) required especially for bootargs string, as multiple options (e.g Video settings) are passed to the kernel through bootargs. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
