The USB Ethernet gadget option has not yet been moved to Kconfig, let's
deal with that.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
In mancy cases both CONFIG_ENV_OFFSET and CONFIG_ENV_ADDR point
to an otherwise-unused SMNAND_ENV_OFFSET.
This patch will set both CONFIG_ENV_OFFSET and CONFIG_ENV_ADDR to
whatever value was defined by SMNAND_ENV_OFFSET.
This is not a valid option. Drop it.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Manually enable SYS_NAND_U_BOOT_LOCATIONS.
Set CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 and remove it from header
CONFIG_BCH
CONFIG_SPL_OMAP3_ID_NAND
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
All boards which use DM_MMC have now been converted to use DM_MMC_OPS.
Drop the option and good riddance.
CONFIG_CMD_SPL_WRITE_SIZE
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_CMD_SPL_NAND_OFS
CONFIG_SYS_I2C_OMAP24XX
The driver is for all boards 24XX and up, so let's eliminate the
extra option called CONFIG_SYS_I2C_OMAP34XX since the driver checks
for CONFIG_OMAP34XX we don't need CONFIG_SYS_I2C_OMAP34XX.
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
Tested-by: Adam Ford <aford173@gmail.com>
CONFIG_TWL4030_PWM is not being used by any source, so let's remove the #define
and the whitelist entry
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
- Add #undef CONFIG_DM_MMC_OPS to omap3_logic in the SPL build case, to
match other TI platforms in the same situation.
The symbols CONFIG_OMAP3_GPIO_X control if we enable the clocks for a
given GPIO bank in U-Boot. select the required banks for each target.
In some cases we need to also migrate from CONFIG_USB_EHCI (deprecated,
in include/configs/) to CONFIG_USB_EHCI_HCD as we only require the GPIO
bank to be enabled if USB is also enabled.
This patch also removes all the excessive code for NS16550 intiailization
as the device tree can do that now. This also adds DM_I2C and DM_MMC
since the overlying drivers have the built-in support already. The
corresponding include/config/omap3_logic.h also reduced in size
due to the new device tree support.
Changes in V2:
Retain Auto-detect ability between SOM-LV and Torpedo
Split this off from the device sub submissions
Signed-off-by: Jagan Teki <jagan@openedev.com>
Some scripts are calling the same functions, so these changes consolidate
common scripts together to reduce redundancy and shrink size a bit. This
also keeps the 'bootargs' variable from growing if manually called more
than one time. This also adds NAND booting scripts based on newly consolidated
scripts.
Since we're including ti_armv7_common, let's pull in DEFAULT_LINUX_BOOT_ENV
and remove unnecessary duplicative definitions. This patch also renames a
few environmental variables to match what is inside ti_armv7_common. This
should help future-proof any subsequent memory or memory location changes.
The display is done in the device tree now, and there is no need
to pass 'display' kernel parameter any longer.
These boards do not and never have had ONENAND support, so let's remove it.
The previous partition table did not support a separate device tree
and the kernel size was limited to 4MB. This update shows the
location of the device tree (labeled as spl-os) for those who
want to use Falcon Mode or use U-Boot to store the Flattened
Device Tree (FDT) to NAND without appending it to the kernel.
This also grows the kernel to 6MB since 4MB was becomming tight
The memory map defined in commit ("49c7303f0e52: OMAP3: Enable SPL
on omap3_logic) was used by a copy-paste of another board without
fully understanding how the map works in Falcon mode. This patch
undoes the customization and uses the default SPL Memory Map
for OMAP3.
When building the uImage, set LOADADDR=0x82000000 and Falcon
mode should properly load.
Not all networks have a DHCP server configured properly, so these
scripts make it easier to boot in that scenario.
The LCD isn't supported in U-Boot and the LCD is now configured in
the device tree, so this code is pointless.
V2: Eliminiate erroneous newline.
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
move the UBI config options into Kconfig.
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
On all TI platforms the ROM defines a "downloaded image" area at or near
the start of SRAM which is followed by a reserved area. As it is at
best bad form and at worst possibly harmful in corner cases to write in
this reserved area, we stop doing that by adding in the define
NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image
area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this.
At current we define the end of scratch space at 0x228 bytes past the
start of scratch space this this gives us a lot of room to grow. As
these scratch uses are non-optional today, all targets are modified to
respect this boundary.
Tested on OMAP4 Pandaboard, OMAP3 Beagle xM
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Weber <weber@corscience.de>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: "B, Ravi" <ravibabu@ti.com>
Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: "Kipisz, Steven" <s-kipisz2@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all
cases we are mirroring the values used by the Linux Kernel here. Also,
so long as (and in this case, it is true) we implement flushes in hunks
that are no larger than the smallest implementation (and given that we
mirror the Linux Kernel, again we are fine) it is OK to align higher.
The biggest changes here are that we always use 64 bytes for CPU_V7 even
if for example the underlying core is only 32 bytes (this mirrors
Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the
Linux Kernel) as we do not need multi-platform support (to this degree)
and only the Cavium ThunderX 88xx series has a use for such large
alignment.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Stefan Agner <stefan.agner@toradex.com>
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: "Pali Rohár" <pali.rohar@gmail.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: David Feng <fenghua@phytium.com.cn>
Cc: Alison Wang <b18965@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Cc: Mingkai Hu <mingkai.hu@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Aneesh Bansal <aneesh.bansal@freescale.com>
Cc: Saksham Jain <saksham.jain@nxp.com>
Cc: Qianyu Gong <qianyu.gong@nxp.com>
Cc: Wang Dongsheng <dongsheng.wang@nxp.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
Cc: Hongbo Zhang <hongbo.zhang@nxp.com>
Cc: tang yuantian <Yuantian.Tang@freescale.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Cc: Anand Moon <linux.amoon@gmail.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Carlo Caione <carlo@endlessm.com>
Cc: huang lin <hl@rock-chips.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Xu Ziyuan <xzy.xu@rock-chips.com>
Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com>
Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bernhard Nortmann <bernhard.nortmann@web.de>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Carlos Hernandez <ceh@ti.com>
Cc: Gong Qianyu <Qianyu.Gong@freescale.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Chin Liang See <clsee@altera.com>
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2
means the autoboot with no delay, with no abort check even if
CONFIG_ZERO_BOOTDELAY_CHECK is defined.
To sum up, the autoboot behaves as follows:
[1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y
autoboot with no delay, but you can abort it by key input
[2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n
autoboot with no delay, with no check for abort
[3] CONFIG_BOOTDELAY=-1
disable autoboot
[4] CONFIG_BOOTDELAY=-2
As you notice, [2] and [4] come to the same result, which means we
do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the
cases only by CONFIG_BOOTDELAY, like this:
[2] CONFIG_BOOTDELAY=-1
disable autoboot
[3] CONFIG_BOOTDELAY=-2
This commit converts the logic as follow:
--> CONFIG_BOOTDELAY=-2
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Christian Riesch <christian.riesch@omicronenergy.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Spelling corrections for (among other things):
* environment
* override
* variable
* ftd (should be "fdt", for flattened device tree)
* embedded
* FTDI
* emulation
* controller
While the OMAP3 has 64KiB of SRAM, per the TRM the download area is only
from 0x40200000 to 0x4020F000 and exceeding that will cause failure to
boot. Further, we need to make sure that we don't run into
SRAM_SCRATCH_SPACE_ADDR as once SPL is running we will write values
there and would corrupt our running image.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. Definitions were added to
defconfig files in a way that "make savedefconfig" generates exactly
the same file as used defconfig.
Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use
2 mA (as minimal allowed by Kconfig).
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
Logic PD makes four different system on modules. This patch will auto
detect the board type and identify the corresponding device tree image.
V2:
Added 'default:' case to switch statement
Since board_late_init() is defined as int, we now return 0
Signed-off-by: Derald Woods <woods.technical@gmail.com>
With the recent addition of UBI support, this patch will add the preset
parameters to allow for mouting an UBIFS from the 'fs' partition in NAND.
-V2: ubi.mtd=fs instead of ubi.mtd=4
Based on the work done by Overo, this seems to help some compilers
that have a hard time fitting all the code into the allocated space.
UBIFS is the preferred FS, and YAFFS isn't officially included in
Linux. Removing this feature reduces the code size.
The interface automatically converts one 32-bit word into two 16 words.
The README said it is permissible to use this flag in that scenario.
Android Fastboot requires USB. The TWL4030 PMIC on omap3_logic handles USB traffic.
This patch sets up the USB gadget and Android Fastboot to match what is done in the
omap3_beagle project.
