path: root/include/configs/omap3_logic.h
2013-01-29Remove unused CONFIG_SYS_I2C_BUS[_SELECT]Michael Jones
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere outside of config files. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-04-19CMD: CONFIG_CMD_SETECPR -> CONFIG_CMD_SETEXPR on omap3_logicMarek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-01-16ARMV7: Add support For Logic OMAP35x/DM37x modulesPeter Barada
This patch adds basic support for OMAP35x/DM37x SOM LV/Torpedo reference boards. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. Signed-off-by: Peter Barada <peter.barada@logicpd.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
