path: root/include/configs/omap3_igep00x0.h
2013-11-25Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-11-21mtd: nand: omap: add CONFIG_NAND_OMAP_ECCSCHEME for selection of ecc-schemepekon gupta
This patch adds new CONFIG_NAND_OMAP_ECCSCHEME, replacing other distributed CONFIG_xx used for selecting NAND ecc-schemes. This patch aims at solving following issues. 1) Currently ecc-scheme is tied to SoC platform, which prevents user to select other ecc-schemes also supported in hardware. like; - most of OMAP3 SoC platforms use only 1-bit Hamming ecc-scheme, inspite the fact that they can use higher ecc-schemes like 8-bit ecc-schemes with software based error detection (OMAP_ECC_BCH4_CODE_HW_DETECTION_SW). - most of AM33xx SoC plaforms use 8-bit BCH ecc-scheme for now, but hardware supports BCH16 ecc-scheme also. 2) Different platforms use different CONFIG_xx to select ecc-schemes, which adds confusion for user while migrating platforms. - *CONFIG_NAND_OMAP_ELM* which enables ELM hardware engine, selects only 8-bit BCH ecc-scheme with h/w based error-correction (OMAP_ECC_BCH8_CODE_HW) whereas ELM hardware engine supports other ecc-schemes also like; BCH4, and BCH16 (in future). - *CONFIG_NAND_OMAP_BCH8* selects 8-bit BCH ecc-scheme with s/w based error correction (OMAP_ECC_BCH8_CODE_HW_DETECTION_SW). - *CONFIG_SPL_NAND_SOFTECC* selects 1-bit Hamming ecc-scheme using s/w library Thus adding new *CONFIG_NAND_OMAP_ECCSCHEME* de-couples ecc-scheme dependency on SoC platform and NAND driver. And user can select ecc-scheme independently foreach board. However, selection some hardware based ecc-schemes (OMAP_ECC_BCHx_CODE_HW) still depends on presence of ELM hardware engine on SoC. (Refer doc/README.nand) Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-01OMAP3: igep00x0: rename config file to omap3_igep00x0.hJavier Martinez Canillas
There seems to be a naming convention for the configuration files for boards using the same SoC family. This makes easier to do changes that affect different boards based on the same SoC. Since the IGEPv2 board and the IGEP COM Module use a TI OMAP35xx/DM37xx processor, is better to rename its board config to use this naming scheme. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
