path: root/include/configs/omap3_evm_quick_nand.h
2012-01-26nand_spl_simple: store ecc data on the stackStefano Babic
Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM which is likely to contain already loaded data. The patch saves the oob data and the ecc on the stack replacing the fixed address in RAM. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Scott Wood <scottwood@freescale.com> CC: Tom Rini <tom.rini@gmail.com> CC: Simon Schwarz <simonschwarzcor@googlemail.com> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06OMAP3: Add SPL support to omap3_evmTom Rini
Add Hynix 200MHz timing information to <asm/arch-omap3/mem.h>. This also changes CONFIG_SYS_TEXT_BASE to 0x80100000. Signed-off-by: Tom Rini <trini@ti.com>
2011-11-03omap3evm: Add (quick) configuration for NAND onlySanjeev Premi
Add an optimized board configuration that only supports boot from NAND. Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
