These config targets were added well before the Kconfig migration began
as a way to demonstrate how to make these platforms work with cut down
features. At this point in time they no longer serve a good purpose so
remove them.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Tested on my OMAP3 uEVM.
Add option to set shell prompt string from menuconfig and migrate
boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the
entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the
CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT
right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus
CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h
files. This results in a streamlined default value across platforms, and
includes the following files: spear-common, sunxi-common, mv-common,
ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were
not updated in their respective defconfig files under the assumption that
since they did not explicitly define a value, they're fine with whatever
the default is.
- On the other hand, boards that relied on a value defined in some
<boards>_common.h file such as woodburn_common, rpi-common,
bur_am335x_common, ls2085a_common, siemens_am33x_common, and
omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for
assigning a value for CONFIG_SYS_PROMPT.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
[trini: Add spring, sniper, smartweb to conversion]
USB-related options are usually prefixed with CONFIG_USB and platform-specific
adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so
this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for
consistency.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Enable the OMAP3 specific errata code for 454179, 430973, 621766
and while at it, remove legacy non-revision checked errata logic.
Signed-off-by: Nishanth Menon <nm@ti.com>
Tested-by: Matt Porter <mporter@konsulko.com>
Currently in some cases SDRAM init requires global_data to be available
and soon this will not be available prior to board_init_f(). Adjust the
code paths in these cases to be correct. In some cases we had the SPL
stack be in DDR as we might have large stacks (due to Falcon Mode +
Environment). In these cases switch to CONFIG_SPL_STACK_R. In other
cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these
cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also
in SRAM) so drop those lines.
Tested on Beagleboard, Beagleboard xM
Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard
Tested-by: Tom Rini <trini@konsulko.com>
Becuase the board select menu in arch/arm/Kconfig is too big,
move the OMAP3 board select menu to omap3/Kconfig.
Move also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="omap3
Reviewed-by: Tom Rini <trini@ti.com>
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig.
Remove the redundant definition in config headers.
We are about to switch to Kconfig in the next commit.
But there are something to get done beforehand.
In Kconfig, include/generated/autoconf.h defines boolean
CONFIG macros as 1.
CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1.
Otherwise, when switching to Kconfig, the build log
would be sprinkled with warning messages like this:
warning: "CONFIG_SPL" redefined [enabled by default]
PISMO_xx macros were used to define 'Platform Independent Storage MOdule'
related GPMC configurations. This patch
- Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided
by current u-boot infrastructure.
- Removes unused redundant macros, which are no longer required after
merging of common platform code in following commit
commit a0a37183bd75e74608bc78c8d0e2a34454f95a91
ARM: omap: merge GPMC initialization code for all platform
| Macro | Reason for removal |
| PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE |
| PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE |
| PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE |
| PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so |
| | configuring GPMC chip-select for smallest allowable |
| | segment (GPMC_SIZE_16M) is enough. |
| PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of |
| | 128MB (GPMC_SIZE_128M) |
| PISMO1_NOR | Unused Macros |
| PISMO1_NAND | |
| PISMO2_CS0 | |
| PISMO2_CS1 | |
| PISMO1_ONENAND | |
| PISMO2_NAND_CS0 | |
| PISMO2_NAND_CS1 | |
| PISMO1_NOR_BASE | |
| PISMO1_NAND_BASE| |
| PISMO2_CS0_BASE | |
Signed-off-by: Pekon Gupta <pekon@ti.com>
bus-width
GPMC controller needs to be configured based on bus-width of the NAND device
connected to it. Also, dynamic detection of NAND bus-width from on-chip ONFI
parameters is not possible in following situations:
SPL: SPL NAND drivers does not support ONFI parameter reading.
U-boot: GPMC controller iniitalization is done in omap_gpmc.c:board_nand_init()
which is called before probing for devices, hence any ONFI parameter
information is not available during GPMC initialization.
Thus, OMAP NAND driver expected board developers to explicitely write GPMC
configurations specific to NAND device attached on board in board files itself.
But this was troublesome for board manufacturers as they need to dive into
lengthy platform & SoC documents to find details of GPMC registers and
appropriate configurations to get NAND device working.
This patch instead adds existing CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config
hich indicates that connected NAND device has x16 bus-width. And then based on
this config GPMC driver itself initializes itself based on NAND bus-width. This
keeps board developers free from knowing GPMC controller specific internals.
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI
params or nand_id[] table. And based on that it defines ECC layout.
This patch
1) removes following board configs used for defining NAND ECC layout
- GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND)
- GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND)
- GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND)
- GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND)
2) removes unused #defines in common omap_gpmc.h depending on above configs
Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5
- add omap24xx driver to new multibus/multiadpater support
- adapted all config files, which uses this driver
Tested on the am335x based siemens boards rut, dxr2 and pxm2
posted here:
http://patchwork.ozlabs.org/patch/263211/
Tested-by: Tom Rini <trini@ti.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tom Rix <Tom.Rix@windriver.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Cc: Luca Ceresoli <luca.ceresoli@comelit.it>
Cc: Ilya Yanok <yanok@emcraft.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Pali Rohár <pali.rohar@gmail.com>
Cc: Peter Barada <peter.barada@logicpd.com>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Michael Jones <michael.jones@matrix-vision.de>
Cc: Raphael Assenat <raph@8d.com>
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
Adding a new CONFIG_OMAP_COMMON which is included by all boards
that needs to build cpu/armv7/omap-common folder.
[trini: Fixup common/cmd_io.c]
"CONFIG_SYS_I2C_BUS" and "CONFIG_SYS_I2C_BUS_SELECT" don't appear anywhere
outside of config files.
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL
framework, enable on all of the previously using boards. We move the
spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave
the NAND one in-place as we plan to replace it later in this series.
We use common/spl to avoid linker problems with respect to merging
constant strings in objects. Otherwise all strings in common/ will be
linked in and kept which grows SPL in size too much.
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present
in most ARM board config files.
IRQs are only enabled for 1 config, so remove the unused config options
for IRQ and FIQ stack size as well.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
Cc: Tom Rini <trini@ti.com>
Acked-by: Tom Rini <trini@ti.com>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
As originally reported against beagleboard we currently have the
following error message reported in SPL:
U-Boot SPL 2012.04-00020-gb8310b9-dirty (Apr 25 2012 - 18:49:57)
Texas Instruments Revision detection unimplemented
OMAP SD/MMC: 0
timed out in wait_for_bb: I2C_STAT=1000
reading u-boot.img
The reason for above message is that when booting from MMC, I2C needs to
be initialized to talk with the TWL4030. On OMAP3 I2C is only
initalized in SPL if CONFIG_SPL_BOARD_INIT is set.
Original patch for Beagleboard is:
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
Extended to cover all other boards:
With older toolchains it is possible to not fit entirely into the 45KB
that we had assigned to SPL. Adjust to allow for 8KB of stack (which
should be more than required) and 54KB of text/data.
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
CONFIG_NET_MULTI is not used anymore, so remove it from board files.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Kumar Gala <kumar.gala@freescale.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Heiko Schocher <hs@denx.de>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Tested-by: Marek Vasut <marek.vasut@gmail.com>
Tested-by: Heiko Schocher <hs@denx.de>
Add Hynix 200MHz timing information to <asm/arch-omap3/mem.h>.
This also changes CONFIG_SYS_TEXT_BASE to 0x80100000.
This patch removes the definition of stack sizes for
irq and fiq if the CONFIG_USE_IRQ is undefined before.
Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Signed-off-by: Thomas Weber <weber@corscience.de>
Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
This patch removes the unused definition of SDRC_R_C_B
from the config files.
This patch removes the CONFIG_OMAP3430, because it is unused.
Signed-off-by: Aneesh V <aneesh@ti.com>
Fix these errors when building with recently added
omap3_evm_quick_nand_config:
env_nowhere.o: In function `env_relocate_spec':
/home/premi/u-boot/common/env_nowhere.c:40: multiple definition
of `env_relocate_spec'
env_nand.o:/home/premi/u-boot/common/env_nand.c:416: first defi
ned here
env_nowhere.o: In function `env_get_char_spec':
/home/premi/u-boot/common/env_nowhere.c:44: multiple definition
of `env_get_char_spec'
env_nand.o:/home/premi/u-boot/common/env_nand.c:77: first defin
ed here
env_nowhere.o: In function `env_init':
/home/premi/u-boot/common/env_nowhere.c:54: multiple definition
of `env_init'
env_nand.o:/home/premi/u-boot/common/env_nand.c:144: first defi
ned here
of `env_ptr'
ed here
Signed-off-by: Sanjeev Premi <premi@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This patch moves common config options to a new
file. Common options can now be included in other
board configs for this evm.
