Every omap3 board config file declared the global variable gpmc_cfg.
This changes moves the declaration to a better location in the
arch dependent header file cpu.h.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
A number of config files define the V_PROMPT macro for the
command-line prompt, only to immediately use that macro to define
CONFIG_SYS_PROMPT, making V_PROMPT entirely superfluous.
Added USB host and device config for host (MSC, Keyboard) and
device (ACM) functionalities.
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
Micron DDR timings based on:
http://www.sakoman.net/cgi-bin/gitweb.cgi?p=x-load-omap3.git;a=blob;f=include/asm/arch-omap3/mem.h;h=e6fbfe3947f5d0d85fea776e30821d4017316d86;hb=HEAD
Introduce Micron DDR timings and provide
CONFIG_OMAP3_INFINEON_DDR and CONFIG_OMAP3_MICRON_DDR config
options to allow for platform files to setup their timings as
per the type of DDR selected
Reported-by: Steve Sakoman in http://www.nabble.com/forum/Permalink.jtp?root=25779518&post=25959734&page=y
Signed-off-by: Nishanth Menon <nm@ti.com>
This patch removes dependency on the sizes.h header file
and removes all references to SZ_xx.
This changes fixes an early i2c error.
It appears that I2C is working because once a read or write
error is detected, the omap24xx_i2c driver calls i2c_init
inside its error handling check.
While it is ok to attempt error handling this way, the boards
must not depend on this side effect to initialize it's i2c.
Instead of explicitly calling i2c_init for every board, use
the generic arm initialization in lib_arm/board.c. By defining
the config variable CONFIG_HARD_I2C, the omap3 i2c initialization
is included in the init_sequence table.
Run tested on Beagle.
Compile tested on the omap3's
Acked-by: Dirk Behme <dirk.behme@googlemail.com>
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Embedd chip select configuration into struct for gpmc config
instead of having it completely separated as suggested by
Wolfgang Denk on
http://lists.denx.de/pipermail/u-boot/2009-May/052247.html
Because twl4030 now has its own device files, move and rename
twl4030_mmc_config.
twl4030_mmc_config initializes the twl4030 power setting to
the mmc device. Because it is in the twl4030 power domain, move
it out of drivers/mmc/omap3_mmc.c and into drivers/power/twl4030.c.
The function was renamed to twl4030_power_mmc_init because all
the functions in this file are to have the format
twl4030_power_<device>_<action>
In this case the suffix is mmc_init so
device : mmc
action : init
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Heiko Schocher <hs@denx.de>
All in-tree boards that use this controller have CONFIG_NET_MULTI added
Also:
- changed CONFIG_DRIVER_SMC911X* to CONFIG_SMC911X*
- cleaned up line lengths
- modified all boards that override weak function in this driver
- added
Tested-by: Mike Frysinger <vapier@gentoo.org>
Commit 8d2effea added a warning for configurations that use NAND
without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but
failed to fix the affected boards.
This patch covers the non-PPC boards that were missed in the previous
patch (commit 170c1972).
The current configuration doesn't define default
bootfile; leading to this warning at execution:
OMAP3_EVM # dhcp
DHCP client bound to address 192.168.1.11
*** Warning: no boot file name; using 'AC18BE16.img'
TFTP from server 0.0.0.0; our IP address is 192.168.1.11;
sending through gateway 192.168.1.1
Filename 'AC18BE16.img'.
Load address: 0x82000000
Loading: *
TFTP error: 'File not found' (1)
Signed-off-by: Sanjeev Premi <premi@ti.com>
Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
Remove remaining legacy NAND defines for Beagle, EVM, Overo and Pandora.
Use the functions print_cpuinfo() and checkboard() to
display the cpu and board specific information.
These functions reuse content from the existing function
display_board_info() - which has been removed.
Also, updated the existig OMAP3 configurations to
define:
- CONFIG_DISPLAY_CPUINFO
- CONFIG_DISPLAY_BOARDINFO
In recent U-Boot mmcinit changed to mmc init.
Signed-off-by: Steve Sakoman <steve@sakoman.com>
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
Divisor field is called PTV not PVT.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Add EVM board support.
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
