path: root/include/configs/omap3_beagle.h
2012-09-27SPL: Move the omap SPL framework to common/splTom Rini
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL framework, enable on all of the previously using boards. We move the spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave the NAND one in-place as we plan to replace it later in this series. We use common/spl to avoid linker problems with respect to merging constant strings in objects. Otherwise all strings in common/ will be linked in and kept which grows SPL in size too much. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01dm: Select CONFIG_SPL_GPIO_SUPPORT on OMAPMarek Vasut
This fixes the breakage with SPL on most OMAP boards after the GPIO driver was moved. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01beagle: fix termination of buddy env settingPeter Meerwald
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
2012-07-07omap3_beagle: Add CONFIG_CMD_ASKENVTom Rini
2012-07-07OMAP3 Beagle: Set BOOTDELAY to 3Tom Rini
We change the bootdelay to give users a little bit longer to break in if needed. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15ARM: omap3: Add CONFIG_SPL_BOARD_INIT for CONFIG_SPL_MMC_SUPPORTTom Rini
As originally reported against beagleboard we currently have the following error message reported in SPL: U-Boot SPL 2012.04-00020-gb8310b9-dirty (Apr 25 2012 - 18:49:57) Texas Instruments Revision detection unimplemented OMAP SD/MMC: 0 timed out in wait_for_bb: I2C_STAT=1000 reading u-boot.img .... The reason for above message is that when booting from MMC, I2C needs to be initialized to talk with the TWL4030. On OMAP3 I2C is only initalized in SPL if CONFIG_SPL_BOARD_INIT is set. Cc: Thomas Weber <weber@corscience.de> Cc: Steve Sakoman <sakoman@gmail.com> Original patch for Beagleboard is: Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com> Extended to cover all other boards: Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15ARM: omap3: Set SPL stack size to 8KB, image to 54KB.Tom Rini
With older toolchains it is possible to not fit entirely into the 45KB that we had assigned to SPL. Adjust to allow for 8KB of stack (which should be more than required) and 54KB of text/data. Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Thomas Weber <weber@corscience.de> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Vaibhav Hiremath <hvaibhav@ti.com>
2012-04-16BeagleBoard: Remove userbutton command and use gpio command insteadJoel Fernandes
Remove userbutton command and do the detection in board config file using the gpio command Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
2012-02-12ehci-omap: driver for EHCI host on OMAP3Ilya Yanok
Taken from Beagle code. Tested on mcx board (AM3517-based). Signed-off-by: Ilya Yanok <yanok@emcraft.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12usb: ulpi: Add omap-ulpi-view port supportGovindraj.R
Based on discussion from this thread [1]. Adding omap-view port that helps us in using the generic ulpi framework for any ulpi phy ops using the INSNREG05_ULPI viewport reg available on omap platform. Currently ehci ports are available on omap3/4 platforms so enable the same for beagle and panda, patch is tested on the same boards. Thanks to Igor Grinberg <grinberg@compulab.co.il> for reviewing the omap-ehci patches and suggesting this approach. [1]: http://www.mail-archive.com/u-boot@lists.denx.de/msg76076.html Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-01-26nand_spl_simple: store ecc data on the stackStefano Babic
Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM which is likely to contain already loaded data. The patch saves the oob data and the ecc on the stack replacing the fixed address in RAM. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Scott Wood <scottwood@freescale.com> CC: Tom Rini <tom.rini@gmail.com> CC: Simon Schwarz <simonschwarzcor@googlemail.com> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-06OMAP3: Add SPL support to BeagleboardTom Rini
This introduces 200MHz Micron parts timing information based on x-loader to <asm/arch-omap3/mem.h> and Numonyx MCFG calculation. The memory init logic is also based on what x-loader does in these cases. Note that while previously u-boot would be flashed in with SW ECC in this case it now must be flashed with HW ECC. We also change CONFIG_SYS_TEXT_BASE to 0x80100000. Cc: Dirk Behme <dirk.behme@gmail.com> Beagleboard rev C5, xM rev A: Tested-by: Tom Rini <trini@ti.com> Beagleboard xM rev C: Tested-by: Matt Ranostay <mranostay@gmail.com> Beagleboard rev B7, C2, xM rev B: Tested-by: Matt Porter <mporter@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06BeagleBoard: config: Really switch to ttyO2Koen Kooi
The previous commit changed it to "zero two" instead of the proper "Oh two". This was completely broken! Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Acked-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unusedThomas Weber
This patch removes the definition of stack sizes for irq and fiq if the CONFIG_USE_IRQ is undefined before. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06ARM: OMAP3: Remove unused define SDRC_R_C_BThomas Weber
This patch removes the unused definition of SDRC_R_C_B from the config files. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it> Acked-by: Tom Rini <trini@ti.com>
2011-12-06ARM: OMAP3: Remove unused define CONFIG_OMAP3430Thomas Weber
This patch removes the CONFIG_OMAP3430, because it is unused. Acked-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Luca Ceresoli <luca.ceresoli@comelit.it>
2011-12-06omap: fix cache line size for omap3/omap4 boardsAneesh V
Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2011-11-10BeagleBoard: config: Switch to ttyO2Alexander Holler
This is needed to support the latest kernel versions. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Dirk Behme <dirk.behme@gmail.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap: beagle: Use ubifs instead of jffs2 for nand bootSteve Sakoman
Signed-off-by: Steve Sakoman <steve@sakoman.com> Acked-by: Koen Kooi <k-kooi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12OMAP3 Beagle: Minor config cleanupSandeep Paulraj
This patch removes a hardcoded MAC address Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12omap3: beagle: Fix build warningSanjeev Premi
This patch fixes the warning dure to recent changes to the board configuration: cmd_i2c.o cmd_i2c.c -c cmd_i2c.c:109:1: warning: missing braces around initializer cmd_i2c.c:109:1: warning: (near initialization for 'i2c_no_probes[0]') Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Jason Kridner <jkridner@beagleboard.org> Acked-by: Jason Kridner <jdk@ti.com>
2011-09-04BeagleBoard: config: updated default configurationJason Kridner
* Improved boot env var setting * Made room for a 64MB ramdisk by moving from 0x81600000 to 0x81000000 * Added ramarg, ramroot and ramboot env variables Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: config: Enabled multibus support for I2C in configurationJason Kridner
2011-09-04BeagleBoard: config: add optargs/buddy/cameraJason Kridner
buddy and camera are used to configure peripherals in the kernel at boot time that cannot easily be detected by the kernel. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: config: increase command-line functionalityJason Kridner
Enable the expression evaluator. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: config: make mtest runJason Kridner
Utilize the alternate mtest and define a valid region. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04BeagleBoard: config: enable DSSKoen Kooi
2011-09-04BeagleBoard: config: enable asix driver and dhcpKoen Kooi
2011-09-04BeagleBoard: config: enable networkingKoen Kooi
2011-09-04BeagleBoard: config: decrease bootdelay to 2 secondsKoen Kooi
2011-09-04BeagleBoard: config: use uImage.beagle for tftpJoel A Fernandes
2011-09-04BeagleBoard: config: hardcode MAC for onboard SMSCJoel A Fernandes
2011-09-04BeagleBoard: config: load kernel from MMC ext, not FATKoen Kooi
2011-09-04BeagleBoard: Added userbutton commandJason Kridner
Based on commit f1099c7c43caf5bac3bf6a65aa266fade4747072 Author: Greg Turner <gregturner@ti.com> Date: Tue May 25 09:19:06 2010 -0500 New u-boot command for status of USER button on BeagleBoard-xM Modified bootcmd to check the staus at boot time and set filename of the boot script. * Moved to a BeagleBoard specific file. * Removed changes to default boot command from adding userbutton command. * Made to handle pre-xM boards. * Flipped polarity of the return value to avoid confusion. Success (0) is when the button is pressed. Failure (1) is when the button is NOT pressed. * Used latest revision getting function. * Used latest macros for board revision. * Added xM-C revision definition (optional, since it was default) * updated default configuration with UserButton functionality * Added a separate bootenv variable to load a user defined .txt file * Added an example, showing how a different environment file can be loaded with the user button pressed Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com> Cc: Greg Turner <gregturner@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04beagle: pass expansionboard name in bootargsKoen Kooi
2011-09-04OMAP: Remove omapfb.debug=y from Beagle and Overo env settingsSteve Sakoman
The kernel DSS2 code is mature now, and keeping this setting hurts performance Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04OMAP3/4: Increase console I/O buffer sizeVaibhav Hiremath
Increase the console I/O buffer size (SYS_CBSIZE) to 512 (from 256) required especially for bootargs string, as multiple options (e.g Video settings) are passed to the kernel through bootargs. Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-08-04Removed unused define, CONFIG_ARMV7.Christopher Harvey
Signed-off-by: Christopher Harvey <charvey@matrox.com>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-04-27Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2011-04-27ARMV7: OMAP3: Cleanup extern variables in mem.cLuca Ceresoli
Removed boot_flash_* extern variables. boot_flash_type was totally unused. The other ones were actually constants, so they have been replaced with #defines in the board config files. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27omap3_beagle: enable EHCI and USB storage.Alexander Holler
The reset sequence/configuration for ehci is highly board specific, so this will be done in the source for the board, instead of introducing several CONFIG_* which would be needed to make those few lines in beagle.c usable across different OMAP boards. Signed-off-by: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27OMAP3: BeagleBoard: add xM rev B to ID tableKoen Kooi
Patch was updated by Jason Kridner <jkridner@beagleboard.org>: * Use tabs to match style of other board revisions * Only include board revisions that exist * Default to the same configuration as the latest revision, but without setting 'beaglerev' Signed-off-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27omap3_beagle: enable the use of a plain text fileAlexander Holler
Using the new env import command it is possible to use plain text files instead of script-images. Plain text files are much easier to handle. E.g. If your boot.scr contains the following: ----------------------------------- setenv dvimode 1024x768-16@60 run loaduimage run mmcboot ----------------------------------- you could create a file named uEnv.txt and use that instead of boot.scr: ----------------------------------- dvimode=1024x768-16@60 uenvcmd=run loaduimage; run mmcboot ----------------------------------- The variable uenvcmd (if existent) will be executed (using run) after uEnv.txt was loaded. If uenvcmd doesn't exist the default boot sequence will be started, therefore you could just use ----------------------------------- dvimode=1024x768-16@60 ----------------------------------- as uEnv.txt because loaduimage and mmcboot is part of the default boot sequence Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-27BeagleBoard: Added LED driverJason Kridner
Added LED driver using status_led. USR0 is set to monitor the boot status. USR1 is set to be the green LED. Included adding configuration and command to the default configuration. Signed-off-by: Jason Kridner <jkridner@beagleboard.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-04-25Remove device tree booting dependency on CONFIG_SYS_BOOTMAPSZGrant Likely
The previous patch makes u-boot use the full accessible size of ram as the default boot mapped size if CONFIG_SYS_BOOTMAPSZ is not defined, which means boot_relocate_fdt() can be changed to depend solely on CONFIG_OF_LIBFDT. Signed-off-by: Grant Likely <grant.likely@linaro.org>
