path: root/include/configs/omap1610inn.h
2011-06-21omap1610inn: fix build breaksAneesh V
Provide SDRAM base address and use SRAM for initial stack Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-12-13LAN91C96: Enable NET_MULTI LAN driverNishanth Menon
This modification is NOT tested on any of the platforms modified as I dont have them. please help by testing+building+fixing Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-30OMAP: rename timer divisorLadislav Michl
Divisor field is called PTV not PVT. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
2007-07-09include/configs/[m-z]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various o* named board config files.Jon Loeliger
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-07-11* Patch by George G. Davis, 06 Jul 2004:wdenk
- update mach-types.h to latest arm.linux.org.uk master list - Set correct OMAP1610 bi_arch_number for build target * Patch by Curt Brune, 06 Jul 2004: evb4510: add support for timer interrupt; cleanup
2004-06-09Patch by Kurt Stremerch, 28 May 2004:wdenk
Add support for Exys XSEngine board Some code cleanup.
2004-06-09* Patch by Imre Deak, 26 May 2004:wdenk
On OMAP1610 platforms check if booting from RAM(CS0) or flash(CS3). Set flash base accordingly, and decide whether to do or skip board specific setup steps. * Patch by Josef Baumgartner, 26 May 2004: Add missing define in include/asm-m68k/global_data.h
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-08-29* Patch by George G. Davis, 19 Aug 2003:wdenk
fix TI Innovator/OMAP1510 pin configs * Patches by Kshitij, 18 Aug 2003 - add support for arm926ejs cpu core - add support for TI OMAP 1610 Innovator Board
