path: root/include/configs/odroid.h
2019-03-11arm: exynos: Remove duplicated "boardname" env settingKrzysztof Kozlowski
Various places in the code set "boardname" env property. It was used for booting from ITB images and choosing proper DTB file name. Instead of duplicating it, use existing U-Boot wide - "board_name". Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2019-02-09Convert CONFIG_BOARD_TYPES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_BOARD_TYPES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2018-12-26Revert "arm: config: fix default console only to specify the device"Seung-Woo Kim
This reverts commit 232ed3ca534708527a9515c7c41bc3542949525c. In exynos boards, ${console} is used to set bootargs but it sets without "console=", so CONFIG_DEFAULT_CONSOLE for these boards is designated with "console=" but it is removed. So revert the commit. References for using ${console} in board/samsung/common/bootscripts/autoboot.cmd board/samsung/common/bootscripts/bootzimg.cmd Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2018-08-17Removed unused references to CONFIG_SERIALxAdam Ford
After creating CONS_INDEX and migrating a bunch of boards to it, there are a bunch of defined references to CONFIG_SERIALx which are not referenced in any C code or #ifdef, so they can now be removed Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-27arm: odroid: Inherit default value for bootdelay from distro_bootcmd.Vagrant Cascadian
The default value with distro_bootcmd is 2 seconds, which is reasonably fast, and provides a consistent experience across platforms supporting distro_bootcmd. The current bootdelay value of 0 seconds is a bit challenging to interrupt when desired. Acked-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2018-07-27arm: odroid: Enable distro_bootcmd support.Vagrant Cascadian
Enable distro_bootcmd for a standardized boot process across multiple platforms. Acked-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2018-07-27arm: odroid: Increase default env size in preparation for distro_bootcmd.Vagrant Cascadian
Adding distro_bootcmd support bumps the default environment size over 4500. Increase to SZ_16K to allow for room to grow in the future. Acked-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2018-07-27arm: odroid: Use standard environment variable names kernel_addr_r, ↵Vagrant Cascadian
ramdisk_addr_r and fdt_addr_r. Replace non-standard variable names kerneladdr, initrdaddr and fdtaddr with kernel_addr_r, ramdisk_addr_r and fdt_addr_r, as documented in u-boot README. Acked-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-02-08Convert CONFIG LIB_HW_RAND to KconfigAdam Ford
config_fallbacks.h had some logic to automatically select LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't already selected. By migrating LIB_HW_RAND to Kconfig, we can remove this check from config_fallbacks.h and put it into Kconfig Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> [trini: Turn into a choice, add NET_RANDOM_ETHADDR] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-17arm: config: fix default console only to specify the deviceDongjin Kim
Since CONFIG_DEFAULT_CONSOLE is already started with "console=", the console argument in CONFIG_EXTRA_ENV_SETTINGS is expanded to "console=console=ttySAC1,115200n8" and this causes the wrong console device. #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" ... #define CONFIG_EXTRA_ENV_SETTINGS \ "console=" CONFIG_DEFAULT_CONSOLE Signed-off-by: Dongjin Kim <tobetter@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-03cmd: Move CONFIG_RANDOM_UUID to KconfigMaxime Ripard
CONFIG_RANDOM_UUID is used by the GPT command to generate random UUID when none are provided. Move that option to Kconfig. Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-28configs: Remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in all boardsBin Meng
Now that EHCD does not use CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS, remove it in all boards' config files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2017-06-19odroid: remove CONFIG_DM_I2C_COMPAT configJaehoon Chung
Remove the CONFIG_DM_I2C_COMPAT config. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-13odroid: Add boot script (boot.scr) supportGuillaume GARDET
Add boot script (boot.scr) support. If no boot script are found, it boots as usual. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Tested-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-13odroid: replace 'fatload' with 'load' to be able to use EXT* partitionsGuillaume GARDET
Replace 'fatload' command by 'load', to be able to use EXT* partitions while keeping FAT partition compatibility. Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Tested-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-05-14odroid: enable driver model pmic/regulator API and MAX77686 driversPrzemyslaw Marczak
This change enables the configs required to init and setup max77686 regulator driver, using the new driver model pmic and regulator API. And also changes the old pmic framework calls to the new ones. This commits enables: - CONFIG_ERRNO_STR - CONFIG_DM_PMIC - CONFIG_DM_PMIC_CMD - CONFIG_DM_PMIC_MAX77686 - CONFIG_DM_REGULATOR - CONFIG_DM_REGULATOR_CMD - CONFIG_DM_REGULATOR_MAX77686 And removes the unused: - CONFIG_DM_I2C_COMPAT - CONFIG_POWER - CONFIG_POWER_I2C - CONFIG_POWER_MAX77686 Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-03-04Odroid U3: use common code for dram reservationPrzemyslaw Marczak
This commit removes the dram reservation from board file, because it is done in a common code. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-19dm: Move CONFIG_I2C_COMPAT to KconfigSimon Glass
Make this option available in Kconfig and clean up the board that uses it. Note there is also an entry in exynos5-common.h but this affects multiple boards and should be dropped as part of the Samsung I2C migration to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29odroid u3: enable dm i2c supportPrzemyslaw Marczak
This patch enables CONFIG_DM_I2C and also CONFIG_DM_I2C_COMPAT. The last one should be removed when the dm pmic framework will be finished. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17arm: odroid: usb: add support for usb host including ethernetSuriyan Ramasami
This change adds support for enabling the USB host features of the board. This includes the USB3503A hub and the SMC LAN9730 ethernet controller as well. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Enable pre-relocation malloc()Simon Glass
Enable this feature to support driver model before relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Rename -dt config files to -commonSimon Glass
We want exynos5250-dt.h to be a board which can support any exynos5250 device. This matches the naming used by Linux. As a first step, rename the existing -dt files to -common to make it clear they are common files, and not specific boards. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-05odroid: kconfig: add odroid_defconfigPrzemyslaw Marczak
This config is valid for two devices: - Odroid X2, - Odroid U3. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
