path: root/include/configs/o2dnt.h
2005-12-06Change port configuration for O2DNT (CODEC1 on PSC1)Marian Balakowicz
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-11-27Increase IPB and PCI clocks for O2DNT board.Marian Balakowicz
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-10-13Support passing of OF flat trees to the kernel.Wolfgang Denk
Patch by Pantelis Antoniou, 04 Sep 2005
2005-08-19Add new board specific commands for TQM5200/STK52XXWolfgang Denk
- Sound commands (beep, wav, sound) - Test commands (led, can, backlight, rs232) Patch by Martin Krause, 02 May 2005
2005-08-16Disable SNTP for O2DNT board.
2005-08-16CONFIG_PCI_SCAN_SHOW disabled for O2DNT.
2005-08-12FRAM memory access optimization.
2005-08-11O2DNT FRAM write delay disabled.
2005-08-11O2DNT: added hardware flash protect support, macros cleanup.
2005-08-09O2DNT platform specific code.
