path: root/include/configs/o2dnt-common.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23config: Drop CONFIG_CONSOLE_DEVSimon Glass
This is not really a config. Rename it to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-04-08powerpc: Replace CONFIG_SYS_INIT_RAM_END with CONFIG_SYS_INIT_RAM_SIZEYork Sun
CONFIG_SYS_INIT_RAM_SIZE may be used out of the board header file. Some boards use CONFIG_SYS_INIT_RAM_END for the same purpose. To unify the macros, use CONFIG_SYS_INIT_RAM_SIZE for all. Signed-off-by: York Sun <york.sun@nxp.com> CC: Mario Six <mario.six@gdsys.cc> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-11-07powerpc: o2dnt: convert to generic boardAnatolij Gustschin
2014-10-27Use __stringify() instead of xstr()Anatolij Gustschin
Some boards still use xstr(). Replace remaining occurrences of xstr() by commonly used __stringify(). Signed-off-by: Anatolij Gustschin <agust@denx.de>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-24powerpc: mpc5xxx: remove redundant CONFIG_MPC5xxx definitionMasahiro Yamada
We do not have to define CONFIG_MPC5xxx in board config headers (and start.S) because it is defined in arch/powerpc/cpu/mpc5xxx/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01mpc52xx: add common o2dnt and o2dnt2 support and configurationsAnatolij Gustschin
Add common code for o2dnt and o2dnt2 based boards and add different board configuration files for O2D, O2I, O2DNT2, O2D300, O2MNT and O3DNT boards. Signed-off-by: Anatolij Gustschin <agust@denx.de>
