path: root/include/configs/nsa310s.h
2015-11-29arm: kirkwood: add ZyXEL NSA310S deviceGerald Kerma
This patch add ZyXEL NSA310S 1-Bay Media Server The ZyXEL NSA310S device is a Kirkwood based NAS: - SoC: Marvell 88F6702 1000Mhz - SDRAM memory: 256MB DDR2 400Mhz - Gigabit ethernet: PHY Marvell 88E1318 - Flash memory: 128MB - 1 Power button - 1 Power LED (blue) - 4 Status LED (green) - 1 Copy/Sync button - 1 Reset button - 1 SATA II port - 2 USB 2.0 ports (front and back) - Smart fan Signed-off-by: Gerald Kerma <dreagle@doukki.net> Signed-off-by: Tony Dinh <mibodhi@gmail.com> Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
