These boards will now use the ksz90x1 driver instead of the mess in
ksz8xxx. This change is needed before the two drivers can be fully
separated.
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
CONFIG_CMD_SATA
Now that these symbols are in Kconfig, migrate all users. Use imply on
a number of platforms that default to having this enabled. As part of
this we must migrate some straglers for CMD_FAT and DOS_PARTITION.
CONFIG_CMD_HDMIDETECT
Note that we cannot do 'default y if VIDEO' because this option is only
enabled for a small subset of mx6 boards. Also this command is is not a
great implementation (it doesn't use driver model).
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
The following options are migrated over fully now:
- USB_EHCI_ATMEL
- USB_EHCI_MARVELL
- USB_EHCI_MX6
- USB_EHCI_MX7
- USB_EHCI_MSM
- USB_EHCI_ZYNQ
- USB_EHCI_GENERIC
This also requires fixing the depends on USB_EHCI_MARVELL as it's used
by Orion5X and Kirkwood as well.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
CONFIG_CMD_BMODE
[trini: Make this default y and depend on mx5/6/7]
CONFIG_BOARD_EARLY_INIT_F
Signed-off-by: Jagan Teki <jagan@openedev.com>
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_USB_KEYBOARD
[trini: Fixup MPC86* configs]
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
CONFIG_CFB_CONSOLE
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
Move this option to Kconfig and tidy up existing uses.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
novena uses the imx_ddr_size() function to calculate the DDR size in
runtime, so there is no need to define PHYS_SDRAM_SIZE.
Remove the unneeded definition.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Enable support for booting U-Boot image from ext filesystem when either
SD/MMC or SATA support is compiled into the SPL. This will allow easy
transition from loading U-Boot image from ad-hoc offset on the card to
loading U-Boot image from the filesystem. VFAT support is intently not
enabled. The boot order is tweaked so that raw is tested first and if
the raw has no signature, FS boot is attempted.
To install just the SPL on i.MX6 board, perform the following operation
$ dd if=SPL of=/dev/sdX seek=2 bs=512
To install the U-Boot image, copy u-boot.img to the first partition of
the SD/MMC/SATA drive. The partition must be formated to extfs.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Peng Fan <van.freenix@gmail.com>
Novena supports USB keyboard, which is a pluggable device and can be
unplugged. Thus, we need to be able to deregister it's stdio device.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
On Novena, the DRAM SPD is connected to i2c1 while the Utility EEPROM
is connected to i2c3. Now that the EEPROM handling in U-Boot is fixed,
also fix this bit on Novena.
Cc: Sean Cross <xobs@kosagi.com>
Switch Novena to distro bootcmd, so it can be used with debian easily.
Signed-off-by: Vagrant Cascadian <vagrant@aikidev.net>
Tested-by: Vagrant Cascadian <vagrant@aikidev.net>
Simple patch to enable support for extfs filesystem in SPL,
this is useful to those who want to avoid vfat like plague.
The kernel_addr_r should be set to the same value as CONFIG_LOADADDR,
get rid of the duplication.
The driver assumed that I2C1 and I2C2 were always enabled,
and if they were not, then an asynchronous abort was (silently)
raised, to be caught much later on in the Linux kernel.
Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4
are.
To make the change binary-invariant, declare I2C1 and I2C2 in
every include/configs/ file which defines CONFIG_SYS_I2C_MXC.
Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and
CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed
(CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE)
config options.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
According to README.mxc_ocotp the OCOTP is a stanard i.MX6 SoC feature
so centralise the config in mx6_common.h so functionality is standard
across all boards
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Commit a380ce6e9698257c4e8be4c0711b09c90a8febff removed CONFIG_FAT_WRITE
from novena.h , so Novena lost ability to write FAT partitions. Add this
functionality back.
Signed-off-by: Marek Vasut <marex at denx.de>
Cc: Peter Robinson <pbrobinson at gmail.com>
Cc: Stefano Babic <sbabic at denx.de>
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined.
Reviewed-by: Tom Rini <trini at konsulko.com>
Move all standard mx6 MMC configs to mx6_common.
Move all standard filesystem, partition and fdt options to mx6_common.
Move generic miscellaneous options that are standard across most, if not all,
mx6 boards to central mx6_common define to ensure consistent features.
Define common LOADADDR and BOOTDELAY to ensure a consistent experience
across mx6 boards
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common
Define the standard ATAG consfigs in mx6_common.
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO
and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h,
config_cmd_default.h includes are used fairly universally across imx6 boards
so include them in mx6_common.h by default.
We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we
don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere.
