path: root/include/configs/nios2-generic.h
2012-11-10nios2: remove asm/status_led.hThomas Chou
The file has a wrong inline keyword of __led_toggle(), which causes compilation error. And its content is defined in common status_led.h. So define CONFIG_BOARD_SPECIFIC_LED in board config files and remove this header file. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2012-07-16nios2: move gd and bd into BSSThomas Chou
As suggested by Graeme Russ, move gd and bd data structrures to BSS instead of calculating the locations around the stack and heap. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-02-24nios2 - adjust gbl data off to account for bd_infoAlex Hornung
* Adjust the GBL_DATA_OFFSET to account for the fact that we'll be using the space between that offset and the start of the malloc region to allocate both a gd structure and a board info structure. * This fixes a memory corruption bug due to overlap of the malloc region and the bd_info structure. Signed-off-by: Alex Hornung <alex@alexhornung.com> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-10-28board/nios2-generic: Use altera_pio driver and remove board specific driverJoachim Foerster
Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-07-26Timer: Allow reset_timer() only for systems with low resolution timersGraeme Russ
2010-05-28nios2: add gpio support to nios2-generic boardThomas Chou
This patch adds gpio support of Altera PIO component to the nios2-generic board. Though it drives only gpio_led at the moment, it supports bidirectional port to control bit-banging I2C, NAND flash busy status or button switches, etc. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Tested-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-24nios2: add nios2-generic boardThomas Chou
This is a generic approach to port u-boot for nios2 boards. You may find the usage of this approach on the nioswiki, http://nioswiki.com/DasUBoot A fpga parameter file, which contains base address information and drivers declaration, is generated from Altera's hardware system description sopc file using tools. The example fpga parameter file is compatible with EP1C20, EP1S10 and EP1S40 boards. So these boards can be removed after this commit. Though epcs controller is removed to cut the dependency of altera_spi driver. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
