path: root/include/configs/nhk8815.h
2011-04-27nhk8815: add support for relocationAlessandro Rubini
This patch defines all the needed symbols in the header file and removes the now-unused config.mk in board directory. Changes to board C file as requested. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-25arm nomadik: activate defrag choose 4k transfer block sizeAlessandro Rubini
This chooses 4kB data size for both TFTP and NFS, as an example about how to use support for IP fragments. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-29arm nomadik: add i2cAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-06arm nomadik: use 1000 as HZ value and rewrite timer codeAlessandro Rubini
This sets CONFIG_SYS_HZ to 1000 as required, and completely rewrites timer code, which is now both correct and much smaller. Unused functions like udelay_masked() have been removed as no driver uses them, even the ones that are not currently active for this board. mtu.h is copied literally from the kernel sources. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-06arm nomadik: allow Nand and OneNand to coexistsAlessandro Rubini
The evaluation kit has both Nand and OneNand, both drivers are there and the two configurations only select a different default for the jffs partition. This adds the OneNand driver and cleans up storage. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-07-06arm nomadik: cleanup resetAlessandro Rubini
There is only one public release of the Nomadik chip, so the ifdef in reset code as well as a define in the config file are not needed Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-07-06arm nomadik: rename board to nhk8815Alessandro Rubini
This is an error in my side in the initial submission: nobody calls it ""nmdk8815", it's "nomadik hardware kit", nhk8815, instead. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
