path: root/include/configs/mxs.h
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-02-08dm: freescale: Drop mxs_auart serial driverSimon Glass
This does not appear to be used, and has not been converted to driver model by the deadline (doc/driver-model/serial-howto.txt). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-12spl, common, serial: build SPL without serial supportHeiko Schocher
This patch enables building SPL without CONFIG_SPL_SERIAL_SUPPORT support. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Ensure we build arch/arm/imx-common on mx28] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-13mxs: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2014-10-29i2c: mxs: Add basic support for i2c frameworkMarek Vasut
This patch just converts the function prototypes used throughout this driver to match those of the i2c framework. There is so far no functional change. This patch does not do the deeper integration of the framework bits. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de>
2014-08-11Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-23arm: mxs: Scrub useless ifdefMarek Vasut
As a result of 0defddc851edfc34bcf3c3379fe74b11dc01a493 , which did a consolidation of the prompt string, this ifdef became empty. Remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Stefano Babic <sbabic@denx.de>
2014-04-28arm: mxs: Enable CONFIG_SYS_GENERIC_BOARDMarek Vasut
2014-03-31ARM: mxs: Add OCOTP driverMarek Vasut
Add yet another OCOTP driver for this i.MX family. This time, it's a driver for the OCOTP variant found in the i.MX23 and i.MX28. This version of OCOTP is too different from the i.MX6 one that I could not use the mxc_ocotp.c driver without making it into a big pile of #ifdef . This driver implements the regular fuse command interface, but due to the IP blocks' limitation, we support only READ and PROG functions. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2014-03-31arm: mxs: Adjust the load address of U-Boot and SPL for HABMarek Vasut
When using HAB, there are additional special requirements on the placement of U-Boot and the U-Boot SPL in memory. To fullfill these, this patch moves the U-Boot binary a little further from the begining of the DRAM, so the HAB CST and IVT can be placed in front of the U-Boot binary. This is necessary, since both the U-Boot and the IVT must be contained in single CST signature. To make things worse, the IVT must be concatenated with one more entry at it's end, that is the length of the entire CST signature, IVT and U-Boot binary in memory. By placing the blocks in this order -- CST, IVT, U-Boot, we can easily align them all and then produce the length field as needed. As for the SPL, on i.MX23/i.MX28, the SPL size is limited to 32 KiB, thus we place the IVT at 0x8000 offset, CST right past IVT and claim the size is correct. The HAB library accepts this setup. Finally, to make sure the vectoring in SPL still works even after moving the SPL from 0x0 to 0x1000, we add a small function which copies the vectoring code and tables to 0x0. This is fine, since the vectoring code is position independent. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-08-21ARM: mxs: Add mx28evk_auart_console targetAndreas Wass
The target uses AUART 3 instead of the DUART for console output. Signed-off-by: Andreas Wass <andreas.wass@dalelven.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de>
2013-07-24ARM: mxs: Consolidate configuration optionsMarek Vasut
Pull all the duplicate configuration options into configs/mxs.h from the board configuration files. This reduces the files greatly and makes them somewhat more readable. Besides, we do no longer have such a horrible duplication of code. Note that the mx23evk grew in size slightly. This is due to the CONFIG_SYS_CBSIZE now being set to 1024 as it is on the rest of MXS systems. This patch also fixes the OCRAM size for i.MX23. The i.MX23 has only 32kB of OCRAM, while i.MX28 has 128kB of OCRAM. I verified the configuration didn't change for each of the boards, but I didn't boot-test it on the boards I do not have. I configured U-Boot for each board using the "make ... <board>_config" command and then ran "cpp -I include -dM include/config.h" , which dumped all the configuration options. I did this both before and after this patch and finally compared the results for each MXS board. Actually, the results do differ slightly, since the configs/mxs.h file now properly includes the correct iomux-mx23.h or iomux-mx28.h , so while comparing, I had to ignore these new defines. These have no impact on U-Boot configuration though. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lauri Hintsala <lauri.hintsala@bluegiga.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
