path: root/include/configs/mx6sxsabresd.h
2017-05-15Kconfig: USB: Migrate existing USB_EHCI_xxx optionsTom Rini
The following options are migrated over fully now: - USB_EHCI_ATMEL - USB_EHCI_MARVELL - USB_EHCI_MX6 - USB_EHCI_MX7 - USB_EHCI_MSM - USB_EHCI_ZYNQ - USB_EHCI_GENERIC This also requires fixing the depends on USB_EHCI_MARVELL as it's used by Orion5X and Kirkwood as well. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_SW_CURSOR to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-convert, find all the cases where this is off] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-12mx6sxsabresd: Avoid hardcoded RAM sizeVanessa Maegima
Instead of passing the total RAM size via PHYS_SDRAM_SIZE option, we should better use imx_ddr_size() function, which automatically determines the RAM size. Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-21imx: mx6sxsabresd: add command and macros for boot m4 corePeng Fan
Introduce macros and command to support booting M4 core for i.MX6SX SabreSD board. Signed-off-by: Ye.Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2016-02-02imx: mx6sxsabresd: Add MCIMX28LCD display supportYe Li
The i.MX6SX SABRESD board supports MCIMX28LCD (800x480x24) at LCDIF1 port, enable this display feature by adding relevant BSP codes and configurations. Signed-off-by: Ye Li <ye.li@nxp.com>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-09-13mx6sxsabresd: Remove CONFIG_SPL_FAT_SUPPORTFabio Estevam
If the SD card does not contain the u-boot.img then we get the following error: U-Boot SPL 2015.10-rc2-23947-g7ad5930 (Sep 08 2015 - 14:10:29) ** Partition 1 not valid on device 0 ** spl_register_fat_device: fat register err - -1 spl_load_image_fat: error reading image u-boot.img, err - -1 Remove CONFIG_SPL_FAT_SUPPORT and let CONFIG_SPL_MMC_SUPPORT do the job. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-13thermal: imx_thermal: rework driver to be reusedAdrian Alonso
Rework imx_thermal driver to be used across i.MX processor that support thermal sensor Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-09-02imx: mx6sxsabresd: enable CONFIG_SPL_FAT_SUPPORTPeng Fan
Enable CONFIG_SPL_FAT_SUPPORT to load u-boot.img from FAT partition. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-07-10imx6: standardise OCOTP and fuse config to mx6_commonPeter Robinson
According to README.mxc_ocotp the OCOTP is a stanard i.MX6 SoC feature so centralise the config in mx6_common.h so functionality is standard across all boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-07-01defconfig: Move CONFIG_SPI_FLASH_BAR from configsJagan Teki
This commit moves: - CONFIG_SPI_FLASH_BAR from include/configs/*.h into configs/*_defconfigs Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2015-03-13mx6sxsabresd: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-02-19dm: mx6: Adjust mx6sxsabresd to use Kconfig for DM_THERMALSimon Glass
Use Kconfig instead of board config for DM and DM_THERMAL. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-22imx: mx6: Change ENV offset to 512K bytes for larger u-boot imageYe.Li
To align with other mx6 boards, change ENV offset from 384KB to 512KB position to fit a larger u-boot image. Signed-off-by: Ye.Li <B37916@freescale.com>
2015-01-22imx:mx6sxsabresd spl support in header filePeng Fan
Add SPL support in mx6sxsabresd header file. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-01-19mx6sxsabresd: Remove unneeded board_late_init()Fabio Estevam
Since commit 1f98e31bc0b2c37a ("imx: mx6sxsabresd: Use the pfuze common init function") board_late_init() became empty, so we can safely remove this unneeded function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-01-09imx:mx6sxsabresd support qspi AHB readPeng Fan
Add CONFIG_SYS_FSL_QSPI_AHB in header file to enable AHB in driver. In order to count the time, add CONFIG_CMD_TIME. Using AHB read can improve the the read speed about 30%. AHB read: => time sf read 0x8f800000 0 100000 SF: 1048576 bytes @ 0x0 Read: OK time: 0.174 seconds => time sf read 0x8f800000 1000000 100000 SF: 1048576 bytes @ 0x1000000 Read: OK time: 0.174 seconds IP read: => time sf read 0x8f800000 0 100000 SF: 1048576 bytes @ 0x0 Read: OK time: 0.227 seconds => time sf read 0x8f800000 1000000 100000 SF: 1048576 bytes @ 0x1000000 Read: OK time: 0.227 seconds Note: Quad read is not supported in driver, now. In my side, using AHB and Quad read can achieve about 16MB/s. Anyway, I have plan to reimplement the driver using DTB and DM, then make the code cleaner and more feature can be added. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-01-07mx6sxsabresd: support qspi flash bigger than 16MBPeng Fan
mx6sxsabresd revb board uses 32MB qspi flash, reva board uses 16MB qspi flash. Currently, the default supported platform is revb board. If want to configure for reva board, just define CONFIG_MX6SX_SABRESD_REVA in mx6sxsabresd.h to support reva qspi flashes whose size is 16MB. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
