As this is used in the environment, reference it directly rather than as
a CONFIG value.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Adrian Alonso <adrian.alonso@nxp.com>
CONFIG_PCI_SCAN_SHOW
CONFIG_PCIE_IMX
CONFIG_USB_MAX_CONTROLLER_COUNT
With the exception of how PowerPC handles SPL and TPL (which has its own
issues), we cannot safely hide options under CONFIG_SPL_BUILD. Largely
remove the places that have this test today.
CONFIG_EHCI_HCD_INIT_AFTER_RESET
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
IMX_FEC_BASE is not used in these boards, so drop it.
Reviewed-by: Fabio Estevam <festevam@denx.de>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
With DM_MMC, CONFIG_SYS_FSL_USDHC_NUM is not needed.
This option is not implemented anymore. Drop it.
With all boards now using DM_ETH we determine the value for
CONFIG_FEC_XCV_TYPE at run time, except in the case of the default
fall-back. Set the fallback directly now.
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_ETHPRIME
This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME
similar to other options that are not always set and control environment
variables.
CONFIG_VIDEO_LOGO
Note that this option depends on CONFIG_DM_VIDEO now, since cfb_console is
deprecated. The only relevant code is now in splash.c
Drop the check for DM_VIDEO in that file.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_FEC_MXC
Move CONFIG_VIDEO_MXS from board headers to Kconfig
and drop it from obsolete cfb_console driver.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SYS_I2C_MXC
CONFIG_SYS_I2C_MXC_I2C1
CONFIG_SYS_I2C_MXC_I2C2
CONFIG_SYS_I2C_MXC_I2C3
CONFIG_SYS_I2C_MXC_I2C4
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
Done via moveconfig.py
Done with:
./tools/moveconfig.py BMP_16BPP BMP_24BPP BMP_32BPP
Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
CONFIG_SPLASH_SCREEN
CONFIG_SPLASH_SCREEN_ALIGN
CONFIG_SPLASHIMAGE_GUARD
CONFIG_SPLASH_SOURCE
CONFIG_SYS_MMC_ENV_DEV
CONFIG_SYS_MMC_ENV_PART
Note that with this conversion we now have consistent behavior with
respect to ensuring that we have always selected the correct MMC
device and hardware partition.
CONFIG_MXC_UART
Acked-by: Peng Fan <peng.fan@nxp.com>
Move this uncommon header out of the common header.
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
Some of these options are not used by the driver anymore and some of them
are obsolete as the information is gathered from the dt.
So, remove the unused config options now.
Signed-off-by: Frieder Schrempf <frieder.schrempf@kontron.de>
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Signed-off-by: Kuldeep Singh <kuldeep.singh@nxp.com>
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
After the DM conversion the boot SD card is now device 3.
Adjust it so that we can boot the kernel again.
While at it avoid a hardcoded mmc dev inside the finduuid script.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
To support DM QSPI driver
- Add spi0 and spi1 alias for qspi1 and qspi2.
- Add -u-boot.dtsi to modify n25q256a@0 and n25q256a@1 compatible string
to "spi-flash" and add "num-cs" property.
- Enable DM SPI/QSPI relavent configurations
- Remove iomux settings of qspi2 in board codes which is not needed
for DM driver.
- Add sf default settings. So running "sf probe" can detect the flash
Signed-off-by: Ye Li <ye.li@nxp.com>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
The u-boot-dtb.imx size is about 519KB, so 8 * 64KB conflicts
with u-boot-dtb.imx. Enlarge the offset to 14 * 64KB to fix it.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Enable I2C/MMC/GPIO/REGUALTOR/PMIC/USB DM drivers.
There are some dependency, such as when DM MMC enabled, USB compile error.
Also the i.MX I2C MMC DM driver does not support legacy GPIO interface.
So enable them all together.
Currently only imx6sx-sdb.dtb is loaded, but if revA board is used the
correct dtb is imx6sx-sdb-reva.dtb, so make this possible.
While at it, remove an extra 'mmc dev'.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
mx6sxsabresd can run different kernel versions, such as NXP 4.1 or mainline.
Currently the rootfs location is passed via mmcblk number and the
problem with this approach is that the mmcblk number for the SD
card changes depending on the kernel version.
In order to avoid such issue, use the UUID method to specify the
rootfs location.
Reviewed-by: Stefano Babic <sbabic@denx.de>
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
CONFIG_CMD_PCI
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
The following options are migrated over fully now:
- USB_EHCI_ATMEL
- USB_EHCI_MARVELL
- USB_EHCI_MX6
- USB_EHCI_MX7
- USB_EHCI_MSM
- USB_EHCI_ZYNQ
- USB_EHCI_GENERIC
This also requires fixing the depends on USB_EHCI_MARVELL as it's used
by Orion5X and Kirkwood as well.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
CONFIG_CMD_BMP
[trini: Add depends on LCD || DM_VIDEO || VIDEO]
