path: root/include/configs/mx6sxsabreauto.h
2018-02-08Convert CONFIG_APBH_DMA et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_APBH_DMA CONFIG_APBH_DMA_BURST CONFIG_APBH_DMA_BURST8 Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Stefan Agner <stefan.agner@toradex.com> [trini: Add in MMC as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert CONFIG_NAND_MXS to KconfigStefan Agner
This converts CONFIG_NAND_MXS to Kconfig. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-15Kconfig: USB: Migrate existing USB_EHCI_xxx optionsTom Rini
The following options are migrated over fully now: - USB_EHCI_ATMEL - USB_EHCI_MARVELL - USB_EHCI_MX6 - USB_EHCI_MX7 - USB_EHCI_MSM - USB_EHCI_ZYNQ - USB_EHCI_GENERIC This also requires fixing the depends on USB_EHCI_MARVELL as it's used by Orion5X and Kirkwood as well. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-04-06Remove various unused interrupt related codeTom Rini
With d53ecad92f06 some unused interrupt related code was removed. However all of these options are currently unused. Rather than migrate some of these options to Kconfig we just remove the code in question. The only related code changes here are that in some cases we use CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename and move the value local to the code in question. Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05mx6sxsabreauto: Remove legacy CONFIG_PCA953XTom Rini
When this board was switched to using more DM drivers we didn't disable the legacy PCA953X driver. This in turn learn to a build time warning about implicit functions as i2c.h would not say anything about 'i2c_read' nor 'i2c_write'. But this was not a fatal error as none of the legacy driver would be linked in either. Fixes: e389033f72b5 ("imx: mx6sxsabreauto: enable more dm drivers") Reviewed-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-27imx: mx6sxsabreauto: enable more dm driversPeng Fan
Enable MMC/I2C/GPIO/PMIC/REGULATOR/PCA953X DM drivers for mx6sxsabreauto board. Drop non-DM code. Note: The i.MX DM drivers has such dependency. MXC GPIO -> MXC I2C -> PFUZE/REGULATOR MXC GPIO -> PCA953X MXC GPIO -> FSL_USDHC So the drivers needs to be enabled all to avoid compiling error. The uboot dm tree log: => dm tree Class Probed Name ---------------------------------------- root [ + ] root_driver thermal [ ] |-- imx_thermal simple_bus [ + ] |-- soc simple_bus [ + ] | |-- aips-bus@02000000 simple_bus [ ] | | |-- spba-bus@02000000 gpio [ + ] | | |-- gpio@0209c000 gpio [ + ] | | |-- gpio@020a0000 gpio [ + ] | | |-- gpio@020a4000 gpio [ + ] | | |-- gpio@020a8000 gpio [ + ] | | |-- gpio@020ac000 gpio [ + ] | | |-- gpio@020b0000 gpio [ + ] | | |-- gpio@020b4000 simple_bus [ ] | | |-- anatop@020c8000 simple_bus [ ] | | |-- snvs@020cc000 pinctrl [ + ] | | `-- iomuxc@020e0000 pinconfig [ + ] | | `-- imx6x-sabreauto pinconfig [ + ] | | |-- i2c2grp-1 pinconfig [ + ] | | |-- i2c3grp-2 pinconfig [ ] | | |-- uart1grp pinconfig [ + ] | | |-- usdhc3grp pinconfig [ ] | | |-- usdhc3grp-100mhz pinconfig [ ] | | |-- usdhc3grp-200mhz pinconfig [ + ] | | |-- usdhc4grp pinconfig [ + ] | | `-- vccsd3grp simple_bus [ + ] | |-- aips-bus@02100000 mmc [ + ] | | |-- usdhc@02198000 mmc [ + ] | | |-- usdhc@0219c000 i2c [ + ] | | |-- i2c@021a4000 i2c_generic [ + ] | | | |-- generic_8 i2c_generic [ + ] | | | `-- generic_4e i2c [ + ] | | `-- i2c@021a8000 gpio [ + ] | | |-- gpio@30 gpio [ + ] | | `-- gpio@32 simple_bus [ ] | `-- aips-bus@02200000 simple_bus [ ] | `-- spba-bus@02200000 simple_bus [ + ] `-- regulators regulator [ + ] `-- regulator@0 Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-09-22configs: fsl: Move SPI/SPI-FLASH configs to defconfigJagan Teki
Moved FSL_QSPI/SPI/SPI-FLASH configs from include/configs into respective used defconfigs. - CONFIG_FSL_QSPI - CONFIG_SPI_FLASH - CONFIG_SPI_FLASH_BAR - CONFIG_SPI_FLASH_STMICRO Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2016-07-12mx6sxsabreauto: Avoid hardcoded RAM sizeVanessa Maegima
Instead of passing the total RAM size via PHYS_SDRAM_SIZE option, we should better use imx_ddr_size() function, which automatically determines the RAM size. Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-02imx: mx6sxsabreauto: Add support for mx6sx SABREAUTO boardYe Li
Initial version for mx6sx SABREAUTO board support with features: PMIC, QSPI, NAND flash, SD/MMC, USB, Ethernet, I2C, IO Expander. Signed-off-by: Ye Li <ye.li@nxp.com>
