Enable fastboot command "fastboot flash data"
Custom may need to update data partition in fastboot mode.
This patch enable flash data partition in emmc\sd.
Signed-off-by: Zhang Sanshan <b51434@freescale.com>
Signed-off-by: Ye.Li <B37916@freescale.com>
1. Replace the UDC driver with community's USB gadget d_dnl driver.
2. Integrate the FSL SD/SATA/NAND flash operations, since the GPT and
EFI partitions are not support by i.MX.
3. Add FDT support to community's android image.
4. Change the booti command to boota, due to the booti has been used for
ARM64 image boot.
5. Modify boota implementation to load ramdisk and fdt to their loading
addresses specified in boot.img header, while bootm won't do it for
android image.
6. Modify the android image HAB implementation. Authenticate the boot.img
on the "load_addr" for both SD and NAND.
7. Enable new configuration CONFIG_FSL_FASTBOOT for Freescale's fastboot
with relevant header file "fsl_fastboot.h". While disabling the
configuration, the community fastboot is used.
8. Use community's way to combine cmdline in boot.img and u-boot environment,
not overwrite the cmdline in boot.img
Add udc and fastboot support
We did not use the upstream way.
Currently use CI_UDC and USB_GAGDET of upstream can make fastboot work,
but lack of flash operation, so we still use our way.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
