path: root/include/configs/mx6sabre_common.h
2015-10-02mx6sabre_common: Add DFU supportFabio Estevam
Add DFU support. Tested by flashing SPL and u-boot.img into SPI NOR flash with the following commands: => setenv dfu_alt_info ${dfu_alt_info_spl} => run dfuspi On the host PC: $ sudo dfu-util -D SPL -a spl On the target: CTRL+C => setenv dfu_alt_info ${dfu_alt_info_img} => run dfuspi On the host PC: $ sudo dfu-util -D u-boot.img -a u-boot Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-20mx6sabre_common: Add Fastboot supportFabio Estevam
Tested basic fastboot commands, such as: On the mx6qsabresd U-boot prompt: => fastboot 0 On the host PC: $ fastboot getvar bootloader-version -i 0x0525 bootloader-version: U-Boot 2015.10-rc2-23960-g2462cce-dirty finished. total time: 0.000s $ fastboot reboot -i 0x0525 --> board reboots fine. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-13thermal: imx_thermal: rework driver to be reusedAdrian Alonso
Rework imx_thermal driver to be used across i.MX processor that support thermal sensor Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-08-02imx: mx6qpsabreauto: Add MX6QP SABREAUTO CPU3 board supportPeng Fan
1. Add DDR script for mx6qpsabreauto board. 2. On CPU3 board, enet RGMII tx clock is from internal PLL. Set the GPR5[9] and init the enet pll output to 125Mhz. 3. On CPU3 board, SW1ABC=VDDSOC_IN, SW2=VDDARM_IN. Build target: mx6qpsabreauto_config Boot Log: U-Boot 2015.07-rc2-00071-gfd985ff (Jun 29 2015 - 22:10:55 +0800) CPU: Freescale i.MX6QP rev1.0 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C) at 34C Reset cause: POR Board: MX6Q-Sabreauto revA I2C: ready DRAM: 2 GiB PMIC: PFUZE100 ID=0x10 Flash: 32 MiB NAND: 0 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment No panel detected: default to HDMI Display: HDMI (1024x768) In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 Note: In this patch, we still add a new config mx6qpsabreauto_config, since SPL is not supported now, and IMX_CONFIG is needed at build time, so add this config. Future, when SPL is converted, this config can be removed. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Robin Gong <b38343@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-08-02imx: mx6sabresd/sabreauto runtime setting fdt_filePeng Fan
Detect the SOC and board variant at runtime and change the dtb name, but not hardcoding the fdt_file env variable. Take the following patch as a reference. Íd58699b157df75f1aa0b363ea9c21add21a0c "mx6cuboxi: Load the correct 'fdtfile' variable" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2015-07-10imx6: standardise OCOTP and fuse config to mx6_commonPeter Robinson
According to README.mxc_ocotp the OCOTP is a stanard i.MX6 SoC feature so centralise the config in mx6_common.h so functionality is standard across all boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-03-13mx6sabre: Do not enable UMS with SPLFabio Estevam
Since commit ad8aae82b20ac6a ("mx6sabre: Enable User Mass Storage") SPL target does not boot anymore due to the increased spl image size. Only enable USB Mass Storage for the non-SPL target. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13mx6sabre_common.h: remove deprecated mmc open/closemaxin.john@enea.com
Replace "mmc open/close" with "mmc dev" in mx6sabre_common.h as those commands were removed with this commit: 614b2bf1c9bf80dbad24f5e5ce1d115bf24a831d cmd_mmc.c: Drop open/close mmc sub-commands Signed-off-by: Maxin B. John <maxin.john@enea.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-02mx6sabre: Select CMD_EXT4 optionsFabio Estevam
Add EXT4 support. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-02mx6sabre: Enable User Mass StorageFabio Estevam
User Mass Storage is very useful for flashing the on-board eMMC. Add support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-02-13dm: mx6: sabre: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-01mx6sabre_common: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-21mx6: mx6sabre common: Enable i.MX thermal DM driverYe.Li
Enable i.MX thermal DM driver to mx6sabre_common.h file. Since the thermal is used in init_sequence_f, so define the CONFIG_SYS_MALLOC_F_LEN to support DM driver using in pre relocation phase. Additional, thermal driver depends on ocotp, make sure to enable CONFIG_MXC_OCOTP when CONFIG_IMX6_THERMAL is selected. Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
2014-11-13imx: mx6q/dl sabre_common: Move MMC ENV offset to 512KB positionYe.Li
Set the CONFIG_ENV_OFFSET from 384KB to 512KB offset, so we will have larger space for u-boot image. When enabling NAND flash support feature, the u-boot image size has exceeded the 384KB, which causes overlay to the environment variables storage. Signed-off-by: Ye.Li <B37916@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-21mx6sabre_common: Add HDMI config to common codeFabio Estevam
HDMI config options can be placed into the common mx6sabre_common.h file to avoid duplication. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-09-24spi: mxc: fix sf probe when using mxc_spiNikita Kiryanov
MXC SPI driver has a feature whereas a GPIO line can be used to force CS high across multiple transactions. This is set up by embedding the GPIO information in the CS value: cs = (cs | gpio << 8) This merge of cs and gpio data into one value breaks the sf probe command: if the use of gpio is required, invoking "sf probe <cs>" will not work, because the CS argument doesn't have the GPIO information in it. Instead, the user must use "sf probe <cs | gpio << 8>". For example, if bank 2 gpio 30 is used to force cs high on cs 0, bus 0, then instead of typing "sf probe 0" the user now must type "sf probe 15872". This is inconsistent with the description of the sf probe command, and forces the user to be aware of implementaiton details. Fix this by introducing a new board function: board_spi_cs_gpio(), which will accept a naked CS value, and provide the driver with the relevant GPIO, if one is necessary. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Eric Benard <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-04-28mx6sabre_common: Convert to generic boardFabio Estevam
Enable CONFIG_SYS_GENERIC_BOARD, so that we get rid of the following warning on boot: "Warning: Your board does not use generic board. Please read doc/README.generic-board and take action. Boards not upgraded by the late 2014 may break or be removed." Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-11mx6sabre_common: Set default environment to use zImageOtavio Salvador
Change the default environment to use zImage instead of uImage, this requires changes to the default environment to load a file named zImage instead of uImage, and to use the 'bootz' command instead of 'bootm' when booting the kernel. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-01-13mx6sabresd: Add eMMC specific environment to allow U-Boot updateOtavio Salvador
A new 'update_emmc_firmware' target is added to allow for easy U-Boot update in the eMMC as it has secury boot partition and this needs specific handling on how to program the specific partition. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2014-01-03ARM: mx6: Change the FDT loading address to avoid overlapingOtavio Salvador
This patch fixes allow for the DeviceTree and initrd relocation fixing the boot of FSL 3.10.9-1.0.0-alpha kernel. This changes following boards: - mx6sabreauto - mx6sabresd - wandboard - udoo - nitrogen6x - cgtqmx6eval The reasoning, as explained by Hui Liu, is: ,---- | The FDT blob will be placed at DDR physical addr: 0x11000000. When Linux kernel | Boot up, it will decompress the compressed kernel image and place the decompressed | kernel image at the low end of the DDR memory and start running from it. If the | decompressed kernel image is bigger for example than 16M, it may over written the | fdt blob which u-boot loaded to the DDR memory @0x11000000 with fdt_addr=0x11000000 | | To expand the fdt_addr from 0x11000000 to 0x18000000, which can avoid the override | Since we will not likely have one kernel image larger than 128MB. `---- Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-02mx6sabre_common.h: Add CONFIG_CMD_FUSE supportFabio Estevam
Add CONFIG_CMD_FUSE option, so that the fuse API can be used. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-11-28mx6sabresd: Add SPI NOR supportFabio Estevam
mx6sabre board has a m25p32 SPI NOR connected to ECSPI1 port. Add support for it. This patch allows the SPI NOR flash to be succesfully detected: => sf probe SF: Detected M25P32 with page size 256 Bytes, erase size 64 KiB, total 4 MiB Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-13configs: imx: Make CONFIG_SYS_PROMPT uniform across FSL boardsFabio Estevam
There is no real benefit in adding the board name into U-boot's prompt, so remove the custom CONFIG_SYS_PROMPT definitions so that the standard "=> " prompt is used across FSL boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-27mx6qsabresd: Add splash screen support via HDMIPardeep Kumar Singla
Signed-off-by: Pardeep Kumar Singla <b45784@freescale.com>
2013-06-26imx: Add support for the SabreSD shipped with i.MX6DLPierre Aubert
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the support of the i.MX6DL. The config file and the board directory are renamed to remove the reference to the MX6Q. Signed-off-by: Pierre Aubert <p.aubert@staubli.com> CC: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
