path: root/include/configs/mx6qsabreauto.h
2016-10-23config: Drop CONFIG_CONSOLE_DEVSimon Glass
This is not really a config. Rename it to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-07-12mx6qsabreauto: Avoid hardcoded RAM sizeVanessa Maegima
Instead of passing the total RAM size via PHYS_SDRAM_SIZE option, we should better use imx_ddr_size() function, which automatically determines the RAM size. Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-08-02imx: mx6sabresd/sabreauto runtime setting fdt_filePeng Fan
Detect the SOC and board variant at runtime and change the dtb name, but not hardcoding the fdt_file env variable. Take the following patch as a reference. Íd58699b157df75f1aa0b363ea9c21add21a0c "mx6cuboxi: Load the correct 'fdtfile' variable" Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
2014-11-20imx: imx6q/dlsabreauto: Add PMIC Pfuze100 supportYe.Li
Add the pfuze100 initialization in power_init_board for imx6q/dl sabreauto board. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-11-20mx6qsabreauto: Add parallel NOR flash supportFabio Estevam
mx6sabreauto boards come with 32 MiB of parallel NOR flash. Add support for it: U-Boot 2015.01-rc1-18107-g1543636-dirty (Nov 14 2014 - 11:11:04) CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: POR Board: MX6Q-Sabreauto revA I2C: ready DRAM: 2 GiB Flash: 32 MiB NAND: 0 MiB Due to pin conflict with I2C3, only define configure I2C3 IOMUX when flash is not used. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-13imx: mx6q/dlsabreauto: And NAND flash supportYe.Li
The i.MX6Q/DL sabreauto board has one NAND socket, set the CONFIG_NAND_MXS and relevant NAND configurations to enable the MXS NAND flash driver. Add board level codes to set IOMUX and clock for GPMI-NAND and BCH module. Signed-off-by: Ye.Li <B37916@freescale.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-03imx: mx6 sabreauto: Add board support for USB EHCIYe.Li
On mx6 sabreauto board, there are two USB ports: 0: OTG 1: HOST The EHCI driver is enabled for this board, but the IOMUX and VBUS power control is not implemented, which cause both USB port failed to work. This patch fix the problem by adding the board support codes. Since the power control uses the GPIO pin from port expander MAX7310, the PCA953X driver is enabled for accessing the MAX7310. The ID pin of OTG Port needs to configure the GPR1 bit 13 for selecting its daisy chain. Add a new function "imx_iomux_set_gpr_register" to handle GPR register setting. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-10-21mx6sabre_common: Add HDMI config to common codeFabio Estevam
HDMI config options can be placed into the common mx6sabre_common.h file to avoid duplication. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-21mx6qsabreauto: Add HDMI supportFabio Estevam
Let HDMI splash screen support work by default. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-09-09mx6qsabreauto: Remove imx6q-sabreauto.dtsFabio Estevam
Commit fa9c021632473 ("mx6: add example DTB for mx6qsabreauto") introduced 'imx6q-sabreauto.dts' but it adds no real value as the dts file only contains the 'model' and 'compatible' strings. After this commit the final binary is also changed from 'u-boot.imx' to 'u-boot-dtb.imx', which may confuse users. So revert it until a more complete and useful device tree could be provided. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2014-05-28mx6sabreauto: Add the mx6dual-lite variantFabio Estevam
Tested by booting a mainline kernel via TFTP. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-04-02mx6: add example DTB for mx6qsabreautoStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-21Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2013-10-20usb: ehci-mx6: add support for otg portTroy Kisky
Previously, only host1 was supported using an index of 0. Now, otg has index 0, host1 is 1, host2 is 2, host3 is 3. Since OTG requires usbmode to be set after reset, I added CONFIG_EHCI_HCD_INIT_AFTER_RESET to nitrogen6x.h and mx6qsabreauto.h. I also added a weak function board_ehci_power to handle turning power on/off for otg. Type is type of device connected (USB stick vs Host.) Init is type of device desired. Only power up port if type == init == USB_INIT_HOST. Only return error if type != init. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-17i2c: update config using mxc driver to new subsystemtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-06-26imx: Add support for the SabreSD shipped with i.MX6DLPierre Aubert
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the support of the i.MX6DL. The config file and the board directory are renamed to remove the reference to the MX6Q. Signed-off-by: Pierre Aubert <p.aubert@staubli.com> CC: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-06-06ARM: imx: Fix incorrect usage of CONFIG_SYS_MMC_ENV_PARTFabio Estevam
When running the "save" command several times on a mx6qsabresd we see: U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed This issue is caused by the incorrect usage of CONFIG_SYS_MMC_ENV_PART. CONFIG_SYS_MMC_ENV_PART should be used to specify the mmc partition that stores the environment variables. On some imx boards it is been incorrectly used to pass the partition of kernel and dtb files for the 'mmcpart' script variable. Remove the CONFIG_SYS_MMC_ENV_PART usage and configure the 'mmcpart' variable directly. Reported-by: Jason Liu <r64343@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2013-06-03mx6qsabreauto: Add i2c to mx6qsabreauto boardRenato Frias
Add i2c2 and 3 to mx6qsabreauto board, i2c3 is multiplexed use gpio to set steering. Signed-off-by: Renato Frias <b13784@freescale.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-01-28mx6qsabre_common: Let mmc partition be board specificFabio Estevam
commit 49ea0ff5 (49ea0ff5) introduced CONFIG_SYS_MMC_ENV_PART into mx6qsabresd.h to store the mmc partition, but in order for it to have effect we should place it into 'mmcpart' variable. Also add CONFIG_SYS_MMC_ENV_PART into mx6qsabreauto.h. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-28mx6qsabreauto: enable USB host interfaceKnut Wohlrab
The USB host interface is routed to plug USB1/J30 on the mother board. Signed-off-by: Knut Wohlrab <knut.wohlrab@de.bosch.com>
2013-01-13mx6qsabre{auto, sd}: Add support to dynamically choose between fdt use or notOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-05mx6qsabresd: add usdhc2 and usdhc4 supportShawn Guo
The on-board number of available usdhc devices is something board specific. The patch moves CONFIG_SYS_FSL_USDHC_NUM out of mx6qsabre_common.h and adds usdhc2 and usdhc4 support for mx6qsabresd board. To keep the default mmc device for environment same as before (usdhc3), it moves CONFIG_SYS_MMC_ENV_DEV out of mx6qsabre_common.h and changes it to 1 for mx6qsabresd. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-10-16mx6qsabreauto: Change mmcroot so it works out of boxOtavio Salvador
The mmcroot setting vary between mx6qsabreauto and mx6qsabresd so we move this to the board configuration file. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx6qsabreauto: Use ttymxc3 as consoleOtavio Salvador
The mx6qsabreauto console is different than mx6qsabresd so the console configuration is now set in the board file. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2012-10-15mx6q: Add basic support for mx6qsabreautoFabio Estevam
mx6qsabreauto is a board based on mx6q SoC with the following features: - 2GB of DDR3 - 2 USB ports - 1 HDMI output port - SPI NOR - 2 LVDS LCD ports - Gigabit Ethernet - Camera - eMMC and SD card slot - Multichannel Audio - CAN - SATA - NAND - PCIE - Video Input Add very basic support for it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
