path: root/include/configs/mx6qarm2.h
2012-01-16i.mx6q: arm2: Add the enet function supportJason Liu
This enable the network function on the i.mx6q armadillo2 board(arm2), thus we can use tftp to load image from network. Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Jason Liu <jason.hui@linaro.org> Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
2011-12-09i.mx: i.mx6q: add the initial support for i.mx6q ARM2 boardJason Liu
Add the initial support for Freescale i.MX6Q Armadillo2 board Support: MMC boot from slot 0/1, debug UART(UART4), usdhc. There is two MMC slots on the boards: mmc dev 0 -> connect USDHC3 -> the lower slot on the board, mmc dev 1 -> connect USDHC4 -> the upper slot on the board, Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
