path: root/include/configs/mx6_common.h
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-05-22Convert CONFIG_CMD_FUSE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_FUSE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_DEKBLOB to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DEKBLOB Note: This option does not seem to actually be enabled by any board. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply under SECURE_BOOT for mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-03-09ARM: Migrate errata to KconfigTom Rini
This moves all of the current ARM errata from various header files and in to Kconfig. This allows for a minor amount of cleanup as we had some instances where both a general common header file was enabling errata as well as the board config. We now just select these once at the higher level in Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-04crypto: Move CONFIG_SYS_FSL_SEC_LE and _BE to KconfigYork Sun
Use Kconfig option to set little- or big-endian access to secure boot and trust architecture. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-04crypto: Move SYS_FSL_SEC_COMPAT into driver KconfigYork Sun
Instead of define CONFIG_SYS_FSL_SEC_COMPAT in header files for PowerPC and ARM SoCs, move it to Kconfig under the driver. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-02arm: imx: add HAB authentication of image to SPL bootSven Ebenfeld
When using HAB as secure boot mechanism on Wandboard, the chain of trust breaks immediately after the SPL. As this is not checking the authenticity of the loaded image before jumping to it. The HAB status output will not be implemented in SPL as it adds a lot of strings that are only required in debug cases. With those it exceeds the maximum size of the available OCRAM (69 KiB). The SPL MISC driver support must be enabled, so that the driver can use OTP fuse to check if HAB is enabled. Cc: sbabic@denx.de v2-Changes: None Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com>
2016-12-16mx6_common: correct loadaddr and text base for i.MX6SLLPeng Fan
Correct loadaddr and text base for i.MX6SLL Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2016-10-17mx6_common: add secure boot supportGary Bisson
Selecting the proper options to enable the build of the HAB tools. Note, this support is disabled by default, one will have to select the SECURE_BOOT configuration through menuconfig to enable it. See doc/README.mxc_hab for more details. Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
2016-06-13autoboot: follow-up cleanup after CONFIG_BOOTDELAY movesMasahiro Yamada
Tidy up garbage left by commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-24imx: mx6/7 enlarge CONFIG_SYS_BOOTM_LEN to 16MPeng Fan
Support uncompressing zImage which is larger than 8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Volodymyr Riazantsev <volodymyr.riazantsev@globallogic.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-08-02mx6_common: Fix LOADADDR and SYS_TEXT_BASE for i.MX6ULPeng Fan
DRAM space starts from 0x80000000 for i.MX6UL, so need to fix LOADADDR, SYS_TEXT_BASE. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx: mx6ul remove errata for i.MX6ULPeng Fan
Since i.MX6UL use A7 core, but not A9 core, we do not need the erratas for i.MX6UL. Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-07-10imx6: standardise OCOTP and fuse config to mx6_commonPeter Robinson
According to README.mxc_ocotp the OCOTP is a stanard i.MX6 SoC feature so centralise the config in mx6_common.h so functionality is standard across all boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-07-03Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Conflicts: configs/tbs2910_defconfig configs/tqma6q_mba6_mmc_defconfig configs/tqma6q_mba6_spi_defconfig configs/tqma6s_mba6_mmc_defconfig configs/tqma6s_mba6_spi_defconfig include/configs/mx6_common.h Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-27Drop duplicate CONFIG_SYS_NO_FLASH from mx6_commonPeter Robinson
It's defind earlier in the file Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-06-08mx6_common: Fix LOADADDR and SYS_TEXT_BASE for MX6SL and MX6SXFabio Estevam
Commit 8183058188cd2d942 ("imx6: centralise common boot options in mx6_common.h") broke boot on mx6sl and mx6sx by assuming that all mx6 SoCs use the same LOADADDR/SYS_TEXT_BASE range, which is not correct. DDR on mx6sx/mx6sl starts at 0x80000000. Adjust LOADADDR/SYS_TEXT_BASE to the proper values for mx6sx/mx6sl, so that these SoCs can boot again. Also, TQMA6 requires a custom CONFIG_SYS_TEXT_BASE value, so move its setting prior to the inclusion of mx6_common.h. Signed-off-by: Fabio Estevam <fabio.estevam at freescale.com>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-03-13mx6_common: Do not select esdhc DDR mode for all boardsFabio Estevam
CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE should be selected only by boards that really have a DDR-capable eMMC, so remove this option from common code to avoid regressions. Reported-by: Stefan Roese <sr@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Volodymyr Riazantsev <volodymyr.riazantsev@globallogic.com> Tested-by: Stefan Roese <sr@denx.de>
2015-02-24mmc: fsl_esdhc: Add support for DDR modeVolodymyr Riazantsev
Add support of the DDR mode for eSDHC driver. Enable it for i.MX6 SoC family only. Signed-off-by: Volodymyr Riazantsev <volodymyr.riazantsev@globallogic.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-03imx: mx6: Enable high frequency clock source for GPTYe.Li
Set the CONFIG_MXC_GPT_HCLK configuration in mx6_common.h, so that 24Mhz OSC clock source will be selected for GPT on all MX6 platforms. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-08-20mx6: add support of multi-processor commandGabriel Huau
This allows u-boot to load different OS or Bare Metal application on different cores of the i.MX6 SoC. For example: running Android on cpu0 and a RT OS like QNX/FreeRTOS on cpu1. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr> Acked-by: Stefano Babic <sbabic@denx.de>
2014-06-17mx6: drop ARM errata 742230Shawn Guo
Commit e9fd66defd7e (ARM: mx6: define CONFIG_ARM_ERRATA_742230) enables errata 742230 for imx6, because it helps remove one reboot issue. However, this errata does not really apply on imx6, because Cortex-A9 on imx6 is r2p10 while the errata only applies to revisions r1p0..r2p2. At a later time, commit f71cbfe3ca5d (ARM: Add workaround for Cortex-A9 errata 794072) adds support of errata 794072, which applies to all Cortex-A9 revisions. As the workaround for both errata are exactly same, it makes a lot more sense to select 794072 instead of 742230 for imx6. Since we already enable 794072 for imx6, it's time to drop errata 742230 to avoid confusion. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Acked-by: Nitin Garg <nitin.garg@freescale.com>
