path: root/include/configs/mx53smd.h
2012-03-27mx53smd: Fix CONFIG_SYS_MEMTEST_ENDFabio Estevam
CONFIG_SYS_MEMTEST_END should be higher than CONFIG_SYS_MEMTEST_START. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-12-06MX: serial_mxc: cleanup removing nasty #ifdefStefano Babic
The serial driver for iMX SOCs is continuosly changed if a new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port> defines were used only to find the base address for the selected UART. Instead of that, move the base address to the board configuration file and drop all #ifdef from driver. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Helmut Raiger <helmut.raiger@hale.at> CC: John Rigby <jcrigby@gmail.com> CC: Matthias Weisser <weisserm@arcor.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-11-04mx53smd: Remove unused get_board_rev functionFabio Estevam
No board information is passed for MX53SMD, so remove get_board_rev function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIMEWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-30mx53smd: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-03mx5: Remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFFJason Liu
CONFIG_L2_OFF is obsolete after the following commit: e47f2db5371047eb9bcd115fee084e6a8a92a239 armv7: rename cache related CONFIG flags Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF Since imx5 does not provide L2 cache operations(Enable/Disable) Simply remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-05-23MX53: Remove CONFIG_SYS_BOOTMAPSZ from mx53 config files.Fabio Estevam
commit ed59e58 (Remove device tree booting dependency on CONFIG_SYS_BOOTMAPSZ) made the definition of CONFIG_SYS_BOOTMAPSZ unnecessary. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-05-23MX53: Add initial support for MX53SMD board.Fabio Estevam
