According to include/i2c.h:
* Many boards/controllers/drivers don't support an I2C slave interface so
* provide a default slave address for them for use in common code. A real
* value for CONFIG_SYS_I2C_SLAVE should be defined for any board which does
* support a slave interface.
#ifndef CONFIG_SYS_I2C_SLAVE
#define CONFIG_SYS_I2C_SLAVE 0xfe
#endif
As the mxc_i2c driver does not support slave mode, there is no need
to define CONFIG_SYS_I2C_SLAVE in i.MX board file.
Cc: Jason Liu <r64343@freescale.com>
Original code was assuming that the fuse revision version for all mx53loco boards
based on Dialog PMIC was the same, which is not the case.
Force the revision of all Dialog-based boards to 0.
This fixes a kernel crash when PMIC is accessed in the 2.6.35 kernel
for Dialog rev E boards.
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
Add support for CLAA07LC0ACW LCD that connects to the mx53loco board.
Configure the board to show the Linux logo on the LCD.
Also increase the size of CONFIG_SYS_MALLOC_LEN variable to take into account
the framebuffer usage.
Acked-by: Jason Liu <r64343@freescale.com>
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG information.
The kernel uses this data to distinguish between Dialog versus mc34708 based boards,
and also to distinguish between revA and revB of the mc34708 based boards.
Suggested-by: Yu Li <yk@magniel.com>
Add mc34708 support and set mx53 core frequency at its maximum value of 1GHz.
There are two types of mx53loco boards: initial boards were built with a Dialog
DA9053 PMIC and more recent version is based on a Freescale MC34708 PMIC.
Add DA9053 PMIC support and adjust the required voltages and clocks for running
the CPU at 1GHz.
Tested on both versions of mx53loco boards.
In the case of a MC34708-based board the CPU operating voltage remains at 800MHz.
Acked-by : Stefano Babic <sbabic@denx.de>
Print CPU information within board_late_init().
This is in preparation for adding 1GHz support, which requires programming a PMIC
via I2C. As I2C is only available after relocation, print the CPU information
later at board_late_init(), so that the CPU frequency can be printed correctly.
CC: Jason Liu <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linaro.org>
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Cc: Remy Bohmer <linux@bohmer.net>
Cc: Wolfgang Grandegger <wg@denx.de>
The serial driver for iMX SOCs is continuosly changed if a
new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port>
defines were used only to find the base address for the selected UART.
Instead of that, move the base address to the board configuration
file and drop all #ifdef from driver.
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Wolfgang Denk <wd@denx.de>
CC: Fabio Estevam <fabio.estevam@freescale.com>
CC: Helmut Raiger <helmut.raiger@hale.at>
CC: John Rigby <jcrigby@gmail.com>
CC: Matthias Weisser <weisserm@arcor.de>
No board information is passed for MX53LOCO, so remove get_board_rev function.
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Let common code set the machine ID.
CONFIG_L2_OFF is obsolete after the following commit:
e47f2db5371047eb9bcd115fee084e6a8a92a239
armv7: rename cache related CONFIG flags
Replace the cache related CONFIG flags with more meaningful
names. Following are the changes:
CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF
Since imx5 does not provide L2 cache operations(Enable/Disable)
Simply remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF
Signed-off-by: Jason Liu <jason.hui@linaro.org>
Cc:Stefano Babic <sbabic@denx.de>
commit ed59e58 (Remove device tree booting dependency on CONFIG_SYS_BOOTMAPSZ) made the
definition of CONFIG_SYS_BOOTMAPSZ unnecessary.
This patch add initial support for freescale MX53LOCO board.
Network(FEC),SD/MMC,UART have been supported by this patch
