path: root/include/configs/mx53evk.h
2011-09-30mx53evk: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-09-03mx5: Remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFFJason Liu
CONFIG_L2_OFF is obsolete after the following commit: e47f2db5371047eb9bcd115fee084e6a8a92a239 armv7: rename cache related CONFIG flags Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF Since imx5 does not provide L2 cache operations(Enable/Disable) Simply remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-05-23mx5: Fix CONFIG_OF_LIBFDT redefined warningShawn Guo
With the following commit, CONFIG_OF_LIBFDT is redefined. 2fa8ca98c37d5b1bb0328b19ddb7e9d162cd9683 Add CONFIG_OF_LIBFDT to more boards. Remove the duplicated definition to fix CONFIG_OF_LIBFDT redefined warning. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2011-05-23mx5: Remove unnecessary CONFIG_SYS_BOOTMAPSZ definitionShawn Guo
Since the following commit, definition CONFIG_SYS_BOOTMAPSZ is not needed any more. ed59e58786cae9f8afcb575649afc65985beed4d Remove device tree booting dependency on CONFIG_SYS_BOOTMAPSZ Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2011-04-28Add CONFIG_OF_LIBFDT to more boards.Grant Likely
The following boards gain device tree support with this patch: ca9x4_ct_vxp - Versatile Express i.mx5 boards: efikamx mx51evk mx53evk OMAP boards: devkit8000 igep0020 igep0030 omap3_overo omap3_pandora omap4_sdp3430 omap3_zoom1 omap3_zoom2 omap4_panda omap4_sdp4430 Tegra boards: Harmony Signed-off-by: Grant Likely <grant.likely@linaro.org>
2011-04-27MX5: Enable flat-device-tree support on mx51/53 evk boardLiu Hui-R64343
device tree for uboot arm support has already been enabled in the master branch. This patch enable device tree support for mx51/53 evk board for DT test. Signed-off-by: Jason Liu <r64343@freescale.com>
2011-02-02MX5:MX53: add initial support for MX53EVK boardLiu Hui-R64343
Add initial support for MX53EVK board support. FEC, SD/MMC, UART, I2C, have been supported. Signed-off-by: Jason Liu <r64343@freescale.com>
