According to the README:
"- CONFIG_SYS_SPD_BUS_NUM
If SPD EEPROM is on an I2C bus other than the first
one, specify here. Note that the value must resolve
to something your driver can deal with."
There is no SPD EEPROM on the imx boards, so ged rid of this option.
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
[trini: Fixup common/cmd_io.c]
OpenEmbedded has change partitioning layout of generated image so it
does not raise warnings during the boot regarding unkown partition
being used for U-Boot.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
When running the "save" command several times on a mx6qsabresd we see:
U-Boot > save
Saving Environment to MMC...
Writing to MMC(1)... done
U-Boot > save
MMC partition switch failed
U-Boot > save
U-Boot > save
U-Boot > save
U-Boot > save
This issue is caused by the incorrect usage of CONFIG_SYS_MMC_ENV_PART.
CONFIG_SYS_MMC_ENV_PART should be used to specify the mmc partition that stores
the environment variables.
On some imx boards it is been incorrectly used to pass the partition of kernel
and dtb files for the 'mmcpart' script variable.
Remove the CONFIG_SYS_MMC_ENV_PART usage and configure the 'mmcpart' variable
directly.
Reported-by: Jason Liu <r64343@freescale.com>
Acked-by: Jason Liu <r64343@freescale.com>
This reworks the environment settings to be aligned with the other
i.MX boards. The loadaddr has been changed to allow the Freescale
kernel and mainline kernel to work without environment changes.
FSL 2.6.35 kernel expects that revision tag is passed by the bootloader.
Select CONFIG_REVISION_TAG so that mx53 boards can work properly with 2.6.35.
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB
pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard.
eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this
board, which satisfies the 30-ns NF R/W cycle requirement.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Fix usage of 'mmc rescan' by many configs. Proper use is
'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan
the device. 'mmc rescan' itself does not take any arguments.
Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of
duplicated definitions.
Cc: Jason Liu <r64343@freescale.com>
Cc: Matt Sealey <matt@genesi-usa.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present
in most ARM board config files.
IRQs are only enabled for 1 config, so remove the unused config options
for IRQ and FIQ stack size as well.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
CONFIG_DISCOVER_PHY is not used anywhere, so remove it from config files.
The following platforms had their config files changed
flea3, imx31_phycore, mx35pdk, mx53ard, mx53evk, mx53smd
and mx53loco.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
According to include/i2c.h:
* Many boards/controllers/drivers don't support an I2C slave interface so
* provide a default slave address for them for use in common code. A real
* value for CONFIG_SYS_I2C_SLAVE should be defined for any board which does
* support a slave interface.
#ifndef CONFIG_SYS_I2C_SLAVE
#define CONFIG_SYS_I2C_SLAVE 0xfe
#endif
As the mxc_i2c driver does not support slave mode, there is no need
to define CONFIG_SYS_I2C_SLAVE in i.MX board file.
CONFIG_MII_GASKET is not defined anywhere, so remove it.
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
The serial driver for iMX SOCs is continuosly changed if a
new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port>
defines were used only to find the base address for the selected UART.
Instead of that, move the base address to the board configuration
file and drop all #ifdef from driver.
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Wolfgang Denk <wd@denx.de>
CC: Fabio Estevam <fabio.estevam@freescale.com>
CC: Helmut Raiger <helmut.raiger@hale.at>
CC: John Rigby <jcrigby@gmail.com>
CC: Matthias Weisser <weisserm@arcor.de>
CC: Jason Liu <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linaro.org>
No board information is passed for MX53ARD, so remove get_board_rev function.
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Let common code set the machine ID.
CONFIG_L2_OFF is obsolete after the following commit:
e47f2db5371047eb9bcd115fee084e6a8a92a239
armv7: rename cache related CONFIG flags
Replace the cache related CONFIG flags with more meaningful
names. Following are the changes:
CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF
Since imx5 does not provide L2 cache operations(Enable/Disable)
Simply remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF
Signed-off-by: Jason Liu <jason.hui@linaro.org>
Cc:Stefano Babic <sbabic@denx.de>
