path: root/include/configs/mx53ard.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-10-17i2c: update config using mxc driver to new subsystemtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-07-12mx53ard: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-06-06ARM: imx: Fix incorrect usage of CONFIG_SYS_MMC_ENV_PARTFabio Estevam
When running the "save" command several times on a mx6qsabresd we see: U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed U-Boot > save Saving Environment to MMC... Writing to MMC(1)... done U-Boot > save Saving Environment to MMC... MMC partition switch failed This issue is caused by the incorrect usage of CONFIG_SYS_MMC_ENV_PART. CONFIG_SYS_MMC_ENV_PART should be used to specify the mmc partition that stores the environment variables. On some imx boards it is been incorrectly used to pass the partition of kernel and dtb files for the 'mmcpart' script variable. Remove the CONFIG_SYS_MMC_ENV_PART usage and configure the 'mmcpart' variable directly. Reported-by: Jason Liu <r64343@freescale.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2013-04-26mx53ard: Rework default environment to support FDT, MMC and netbootOtavio Salvador
This reworks the environment settings to be aligned with the other i.MX boards. The loadaddr has been changed to allow the Freescale kernel and mainline kernel to work without environment changes. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-25mx5: Select CONFIG_REVISION_TAGFabio Estevam
FSL 2.6.35 kernel expects that revision tag is passed by the bootloader. Select CONFIG_REVISION_TAG so that mx53 boards can work properly with 2.6.35. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2013-04-12imx: mx53ard: Add support for NAND FlashBenoît Thébaudeau
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard. eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this board, which satisfies the 30-ns NF R/W cycle requirement. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-10-15mx5/6: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-08-09configs: Remove unused symbol CONFIG_DISCOVER_PHYFabio Estevam
CONFIG_DISCOVER_PHY is not used anywhere, so remove it from config files. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-11mxc_i2c: specify i2c base address in config fileTroy Kisky
The following platforms had their config files changed flea3, imx31_phycore, mx35pdk, mx53ard, mx53evk, mx53smd and mx53loco. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-07-07mx53ard: Remove CONFIG_SYS_I2C_SLAVE definitionFabio Estevam
According to include/i2c.h: "/* * Many boards/controllers/drivers don't support an I2C slave interface so * provide a default slave address for them for use in common code. A real * value for CONFIG_SYS_I2C_SLAVE should be defined for any board which does * support a slave interface. */ #ifndef CONFIG_SYS_I2C_SLAVE #define CONFIG_SYS_I2C_SLAVE 0xfe #endif " As the mxc_i2c driver does not support slave mode, there is no need to define CONFIG_SYS_I2C_SLAVE in i.MX board file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-07mx53ard: Remove unused CONFIG_MII_GASKETFabio Estevam
CONFIG_MII_GASKET is not defined anywhere, so remove it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-12-06MX: serial_mxc: cleanup removing nasty #ifdefStefano Babic
The serial driver for iMX SOCs is continuosly changed if a new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port> defines were used only to find the base address for the selected UART. Instead of that, move the base address to the board configuration file and drop all #ifdef from driver. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Helmut Raiger <helmut.raiger@hale.at> CC: John Rigby <jcrigby@gmail.com> CC: Matthias Weisser <weisserm@arcor.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-11-04mx53ard: Remove unused get_board_rev functionFabio Estevam
No board information is passed for MX53ARD, so remove get_board_rev function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIMEWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-30mx53ard: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-03mx5: Remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFFJason Liu
CONFIG_L2_OFF is obsolete after the following commit: e47f2db5371047eb9bcd115fee084e6a8a92a239 armv7: rename cache related CONFIG flags Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF Since imx5 does not provide L2 cache operations(Enable/Disable) Simply remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-07-04MX53: Add initial support for MX53ARDFabio Estevam
