path: root/include/configs/mx53ard.h
2011-09-30mx53ard: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-03mx5: Remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFFJason Liu
CONFIG_L2_OFF is obsolete after the following commit: e47f2db5371047eb9bcd115fee084e6a8a92a239 armv7: rename cache related CONFIG flags Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF Since imx5 does not provide L2 cache operations(Enable/Disable) Simply remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-07-04MX53: Add initial support for MX53ARDFabio Estevam
