path: root/include/configs/mx51evk.h
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_CFB_CONSOLE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CFB_CONSOLE Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-03-13mx51evk: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-09-22mx51evk: Add generic board supportFabio Estevam
Let's enable CONFIG_SYS_GENERIC_BOARD in order to get rid of warnings related to generic board not being supported. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-09-22mx51evk: Fix CONFIG_SYS_FSL_ESDHC_ADDRFabio Estevam
We should pass the SDHC1 base address into CONFIG_SYS_FSL_ESDHC_ADDR. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-02-11mx51evk: Set default environment to use zImageOtavio Salvador
Change the default environment to use zImage instead of uImage, this requires changes to the default environment to load a file named zImage instead of uImage, and to use the 'bootz' command instead of 'bootm' when booting the kernel. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-11-13configs: imx: Make CONFIG_SYS_PROMPT uniform across FSL boardsFabio Estevam
There is no real benefit in adding the board name into U-boot's prompt, so remove the custom CONFIG_SYS_PROMPT definitions so that the standard "=> " prompt is used across FSL boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-12mx51evk: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-04-28mx51evk: Enable support for iimBenoît Thébaudeau
This allows to test the iim driver in the mainline tree. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-25mx51evk: Do not force the rootfs typeFabio Estevam
Currently mmcrootfstype is set to ext3 type. It is better not to force it in the env vars, because users may prefer a different file system type, so let's get rid of 'mmcrootfstype'. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25mx51evk: Update environment in order to allow booting a dt kernelFabio Estevam
Update the environment as done in other imx boards to allow easy switching between booting a non-dt kernel and a dt kernel. Change CONFIG_LOADADDR to 0x92000000, so that we can have the: - uImage at 0x92000000 - imx51-babbage.dtb at 0x91000000 ,which are adequate locations in RAM to avoid overlapping. Boot tested the following kernels: - 2.6.35 from FSL (11.09 branch) - 3.9-rc7 non-dt - 3.9-rc7 dt Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-01-05mx51evk: Remove unneeded commentFabio Estevam
Looks like the original comment came from a copy and paste from mx31ads.h. It does not have a context on mx51evk anymore, so delete it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-08Merge branch 'master' of git://git.denx.de/u-boot into masterStefano Babic
Conflicts: drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/woodburn_common.h board/woodburn/woodburn.c These boards still use the old old PMIC framework, so they do not merge properly after the power framework was merged into mainline. Fix all conflicts and update woodburn to use Power Framework. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-11-19mx5: Mark lowlevel_init board-specific codeBenoît Thébaudeau
The mx5 lowlevel_init.S contains board-specific code based on the reference design. Let's keep it since it avoids creating new lowlevel_init files and it may be used by many boards. But add a config to make it optional in order not to cause issues on boards not following this part of the reference design. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Matt Sealey <matt@genesi-usa.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-19mx51evk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
One second is enough time for users to react in case they want to stop the booting process. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-11-14power:pmic: Rename CONFIG_PMIC* defines to CONFIG_POWERŁukasz Majewski
Rename all CONFIG_PMIC* defines to CONFIG_POWER* Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-10Merge git://git.denx.de/u-bootStefano Babic
2012-10-27Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-10-26mx51evk: Allow booting a zImage kernelFabio Estevam
Allow booting a zImage kernel. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-10-17configs: mx51evk: Remove CONFIG_HAS_ETH1Fabio Estevam
mx51evk has only one Ethernet port, so remove CONFIG_HAS_ETH1 option. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx5/6: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-23mx51evk: Add CONFIG_REVISION_TAGBenoît Thébaudeau
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG information. If this data is not present, the kernel misconfigures the TZIC, which results in the timer interrupt handler never being called, so the kernel deadlocks while calibrating its delay. Suggested-by: Greg Topmiller <Greg.Topmiller@jdsu.com> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01mx51evk: do not overwrite the consoleFabio Estevam
On this board, the console is always set to the serial line. Do not allow to overwrite it when video is enabled. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-08-09configs: Remove unused symbol CONFIG_DISCOVER_PHYFabio Estevam
CONFIG_DISCOVER_PHY is not used anywhere, so remove it from config files. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Do not hardcode the ipu_clk frequencyFabio Estevam
Do not hardcode the ipu_clk frequency and let the board file pass this value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10video: Rename CONFIG_VIDEO_MX5Fabio Estevam
Rename CONFIG_VIDEO_MX5 as this driver can also be used on mx6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
