path: root/include/configs/mx51evk.h
2014-02-11mx51evk: Set default environment to use zImageOtavio Salvador
Change the default environment to use zImage instead of uImage, this requires changes to the default environment to load a file named zImage instead of uImage, and to use the 'bootz' command instead of 'bootm' when booting the kernel. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-11-13configs: imx: Make CONFIG_SYS_PROMPT uniform across FSL boardsFabio Estevam
There is no real benefit in adding the board name into U-boot's prompt, so remove the custom CONFIG_SYS_PROMPT definitions so that the standard "=> " prompt is used across FSL boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-12mx51evk: Change default environment to cope with OE changesOtavio Salvador
OpenEmbedded has change partitioning layout of generated image so it does not raise warnings during the boot regarding unkown partition being used for U-Boot. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2013-04-28mx51evk: Enable support for iimBenoît Thébaudeau
This allows to test the iim driver in the mainline tree. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-25mx51evk: Do not force the rootfs typeFabio Estevam
Currently mmcrootfstype is set to ext3 type. It is better not to force it in the env vars, because users may prefer a different file system type, so let's get rid of 'mmcrootfstype'. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-25mx51evk: Update environment in order to allow booting a dt kernelFabio Estevam
Update the environment as done in other imx boards to allow easy switching between booting a non-dt kernel and a dt kernel. Change CONFIG_LOADADDR to 0x92000000, so that we can have the: - uImage at 0x92000000 - imx51-babbage.dtb at 0x91000000 ,which are adequate locations in RAM to avoid overlapping. Boot tested the following kernels: - 2.6.35 from FSL (11.09 branch) - 3.9-rc7 non-dt - 3.9-rc7 dt Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-01-05mx51evk: Remove unneeded commentFabio Estevam
Looks like the original comment came from a copy and paste from mx31ads.h. It does not have a context on mx51evk anymore, so delete it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-08Merge branch 'master' of git://git.denx.de/u-boot into masterStefano Babic
Conflicts: drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/woodburn_common.h board/woodburn/woodburn.c These boards still use the old old PMIC framework, so they do not merge properly after the power framework was merged into mainline. Fix all conflicts and update woodburn to use Power Framework. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-11-19mx5: Mark lowlevel_init board-specific codeBenoît Thébaudeau
The mx5 lowlevel_init.S contains board-specific code based on the reference design. Let's keep it since it avoids creating new lowlevel_init files and it may be used by many boards. But add a config to make it optional in order not to cause issues on boards not following this part of the reference design. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Matt Sealey <matt@genesi-usa.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-11-19mx51evk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
One second is enough time for users to react in case they want to stop the booting process. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-11-14power:pmic: Rename CONFIG_PMIC* defines to CONFIG_POWERŁukasz Majewski
Rename all CONFIG_PMIC* defines to CONFIG_POWER* Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-11-10Merge git://git.denx.de/u-bootStefano Babic
2012-10-27Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-10-26mx51evk: Allow booting a zImage kernelFabio Estevam
Allow booting a zImage kernel. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-10-17configs: mx51evk: Remove CONFIG_HAS_ETH1Fabio Estevam
mx51evk has only one Ethernet port, so remove CONFIG_HAS_ETH1 option. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15mx5/6: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-23mx51evk: Add CONFIG_REVISION_TAGBenoît Thébaudeau
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG information. If this data is not present, the kernel misconfigures the TZIC, which results in the timer interrupt handler never being called, so the kernel deadlocks while calibrating its delay. Suggested-by: Greg Topmiller <Greg.Topmiller@jdsu.com> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01mx51evk: do not overwrite the consoleFabio Estevam
On this board, the console is always set to the serial line. Do not allow to overwrite it when video is enabled. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-08-09configs: Remove unused symbol CONFIG_DISCOVER_PHYFabio Estevam
CONFIG_DISCOVER_PHY is not used anywhere, so remove it from config files. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10ipu_common: Do not hardcode the ipu_clk frequencyFabio Estevam
Do not hardcode the ipu_clk frequency and let the board file pass this value. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-10video: Rename CONFIG_VIDEO_MX5Fabio Estevam
Rename CONFIG_VIDEO_MX5 as this driver can also be used on mx6. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-25mx51evk: Add LCD supportFabio Estevam
Add support for CLAA07LC0ACW LCD that connects to the mx51evk board. Configure the board to show the Linux logo on the LCD. Also increase the size of CONFIG_SYS_MALLOC_LEN variable to take into account the framebuffer usage. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-03-27mx51evk: Fix CONFIG_SYS_MEMTEST_ENDFabio Estevam
CONFIG_SYS_MEMTEST_END should be higher than CONFIG_SYS_MEMTEST_START. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-12-11USB: mx51evk: add end enable USB host support on port 1Wolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com>
2011-12-06MX: serial_mxc: cleanup removing nasty #ifdefStefano Babic
The serial driver for iMX SOCs is continuosly changed if a new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port> defines were used only to find the base address for the selected UART. Instead of that, move the base address to the board configuration file and drop all #ifdef from driver. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Helmut Raiger <helmut.raiger@hale.at> CC: John Rigby <jcrigby@gmail.com> CC: Matthias Weisser <weisserm@arcor.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-11-03mx51evk: Remove unused get_board_rev functionFabio Estevam
No board information is passed for MX51EVK, so remove get_board_rev function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03mx51evk: Remove unneeded '1' from mx51evk.hFabio Estevam
Remove unneeded '1' from mx51evk.h. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03mx51evk: Add RTC supportFabio Estevam
MX51EVK has a MC13892 PMIC. Add RTC support. Tested via 'date' command that reads the PMIC RTC registers: MX51EVK U-Boot > date Date: 1970-01-01 (Thursday) Time: 0:40:35 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIMEWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-27MX5: mx51evk: use new pmic driverStefano Babic
Switch to new pmic generic driver. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-09-30mx51evk: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-04MX5: mx51evk: make use of GPIO frameworkStefano Babic
2011-09-03mx5: Remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFFJason Liu
CONFIG_L2_OFF is obsolete after the following commit: e47f2db5371047eb9bcd115fee084e6a8a92a239 armv7: rename cache related CONFIG flags Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF Since imx5 does not provide L2 cache operations(Enable/Disable) Simply remove CONFIG_L2_OFF and CONFIG_SYS_L2CACHE_OFF Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-05-23mx5: Fix CONFIG_OF_LIBFDT redefined warningShawn Guo
With the following commit, CONFIG_OF_LIBFDT is redefined. 2fa8ca98c37d5b1bb0328b19ddb7e9d162cd9683 Add CONFIG_OF_LIBFDT to more boards. Remove the duplicated definition to fix CONFIG_OF_LIBFDT redefined warning. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2011-05-23mx5: Remove unnecessary CONFIG_SYS_BOOTMAPSZ definitionShawn Guo
Since the following commit, definition CONFIG_SYS_BOOTMAPSZ is not needed any more. ed59e58786cae9f8afcb575649afc65985beed4d Remove device tree booting dependency on CONFIG_SYS_BOOTMAPSZ Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2011-04-28Add CONFIG_OF_LIBFDT to more boards.Grant Likely
The following boards gain device tree support with this patch: ca9x4_ct_vxp - Versatile Express i.mx5 boards: efikamx mx51evk mx53evk OMAP boards: devkit8000 igep0020 igep0030 omap3_overo omap3_pandora omap4_sdp3430 omap3_zoom1 omap3_zoom2 omap4_panda omap4_sdp4430 Tegra boards: Harmony Signed-off-by: Grant Likely <grant.likely@linaro.org>
2011-04-27MX5: Enable flat-device-tree support on mx51/53 evk boardLiu Hui-R64343
device tree for uboot arm support has already been enabled in the master branch. This patch enable device tree support for mx51/53 evk board for DT test. Signed-off-by: Jason Liu <r64343@freescale.com>
2011-04-27MX51: drop config.mk from mx51evkStefano Babic
The config.mk file in board directory is now obsolete and should be removed. Add option for the IMX image into boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02MX5: Add initial support for MX53 processorLiu Hui-R64343
Add initial support for Freescale MX53 processor, - Add the iomux support and the pin definition, - Add the regs definition, clean up some unused def from mx51, - Add the low level init support, make use the freq input of setup_pll macro Signed-off-by: Jason Liu <r64343@freescale.com>
2011-02-02MX51EVK: UART does not print out the early informationLiu Hui-R64343
The early bootup information is not print out due to the UART pin iomux not set up correctly before board_init Add the board_early_init_f function and enable the CONFIG_BOARD_EARLY_INIT_F. Move the UART pin setting from board_init to board_early_init_f function. This patch also move the FEC pin iomux setup to the board_early_init_f. Signed-off-by: Jason Liu <r64343@freescale.com>
