path: root/include/configs/mx35pdk.h
2012-12-26mx35pdk: Allow booting of a device tree kernelFabio Estevam
Select CONFIG_OF_LIBFDT, so that a dt kernel can be launched. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-08Merge branch 'master' of git://git.denx.de/u-boot into masterStefano Babic
Conflicts: drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/woodburn_common.h board/woodburn/woodburn.c These boards still use the old old PMIC framework, so they do not merge properly after the power framework was merged into mainline. Fix all conflicts and update woodburn to use Power Framework. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-11-19mx35pdk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
One second is enough time for users to react in case they want to stop the booting process. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-11-16mx35pdk: Add support for OTGBenoît Thébaudeau
Add support for the OTG port on the mx35pdk Personality board. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Tested-by: Stefano Babic <sbabic@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de>
2012-11-14power:pmic: Rename CONFIG_PMIC* defines to CONFIG_POWERŁukasz Majewski
Rename all CONFIG_PMIC* defines to CONFIG_POWER* Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-26mx35pdk: Allow booting a zImage kernelFabio Estevam
Allow booting a zImage kernel. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-26pmic_fsl: Introduce FSL_PMIC_I2C_LENGTHFabio Estevam
Introduce FSL_PMIC_I2C_LENGTH to configure the number of bytes that are used to communicate with the PMIC via I2C. Instead of hardcoding the value, pass the number via a configurable option per PMIC type. This will be useful for adding support for PMIC MC34704 from Freescale, which uses only one byte in its I2C protocol. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15COMMON: Use __stringify() instead of xstr()Marek Vasut
Kill multiple occurances and redeclaration of xstr in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-09-21Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-09-17mxc nand: Let driver detect IP revisionBenoît Thébaudeau
There is no reason to have board configs to select the NFC IP revision. Just let the driver detect it. BTW, remove broken NFC IP revision configs from board config files. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-10MX35: mx35pdk: add support for MMCStefano Babic
Add support for SD card and change the default environment due to increased u-boot size. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-09-06mx35: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX35 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-08-09configs: Remove unused symbol CONFIG_DISCOVER_PHYFabio Estevam
CONFIG_DISCOVER_PHY is not used anywhere, so remove it from config files. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-07-11mxc_i2c: specify i2c base address in config fileTroy Kisky
The following platforms had their config files changed flea3, imx31_phycore, mx35pdk, mx53ard, mx53evk, mx53smd and mx53loco. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-07-07mx35pdk: Remove CONFIG_SYS_I2C_SLAVE definitionFabio Estevam
According to include/i2c.h: "/* * Many boards/controllers/drivers don't support an I2C slave interface so * provide a default slave address for them for use in common code. A real * value for CONFIG_SYS_I2C_SLAVE should be defined for any board which does * support a slave interface. */ #ifndef CONFIG_SYS_I2C_SLAVE #define CONFIG_SYS_I2C_SLAVE 0xfe #endif " As the mxc_i2c driver does not support slave mode, there is no need to define CONFIG_SYS_I2C_SLAVE in i.MX board file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_VSPRINTFTom Rini
This define does not control anything, remove it. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-16MX35: mx35pdk: wrong board revisionStefano Babic
The board revision is detected accessing to the pmic, that is not available before relocation (I2C). This generates the following error: CPU: Freescale i.MX35 rev 2.0 at 532 MHz. Reset cause: WDOG <reg num> = 7 is invalid. Should be less than 0 Board: MX35 PDK 1.0 The revision number is wrong, as a default value is printed (tested on a mx35pdk Rev. 2.0). Move the output in the board_late_init(), when pmic can be accessed. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-04-16mx35: mx35pdk: fix when cache functions are linkedStefano Babic
2011-12-06MX: serial_mxc: cleanup removing nasty #ifdefStefano Babic
The serial driver for iMX SOCs is continuosly changed if a new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port> defines were used only to find the base address for the selected UART. Instead of that, move the base address to the board configuration file and drop all #ifdef from driver. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Helmut Raiger <helmut.raiger@hale.at> CC: John Rigby <jcrigby@gmail.com> CC: Matthias Weisser <weisserm@arcor.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-11-03mx35pdk: Add RTC supportFabio Estevam
MX35PDK has an MC13892 PMIC. Add RTC support. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Stefano Babic <sbabic@denx.de>
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-27MX35: mx35pdk: use new pmic driverStefano Babic
Switch to new pmic generic driver. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-09-04MX35: mx35pdk: make use of GPIO frameworkStefano Babic
2011-09-04MX35: MX35PDK: support additional RAM on CSD1Stefano Babic
Modules on mx35pdk have additional 128MB memory connected to CSD1. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-02Add support for Freescale's mx35pdk board.Stefano Babic
The patch adds suupport for the Freescale's mx35pdk board (known as well as mx35_3stack). The board boots from the NOR flash. Following devices are supported: - two ethernet devices (FEC and SMC911x on debug board) - I2C - PMIC (MC13892) via I2C interface - UART - NOR flash (64MB) - NAND flash (2GB) - basic access to mc9sdz60 registers via I2C interface Signed-off-by: Stefano Babic <sbabic@denx.de>
