path: root/include/configs/mx31pdk.h
2015-03-13mx31pdk: Use the default CONFIG_SYS_PBSIZEFabio Estevam
Entering the maximum number of characters defined by CONFIG_SYS_CBSIZE into the console and hitting enter afterwards, causes a hang in the system because CONFIG_SYS_PBSIZE is not capable of storing the extra characters of the error message: "Unknown command '' - try 'help'". Use the default CONFIG_SYS_PBSIZE definition from config_fallbacks.h to solve this problem. Cc: Magnus Lilja <lilja.magnus@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Magnus Lilja <lilja.magnus@gmail.com>
2014-11-20ARM: remove CONFIG_ARM1136 definesMasahiro Yamada
CONFIG_CPU_ARM1136 was introduced into Kconfig by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). This commit removes all the defines of CONFIG_ARM1136 and replaces the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM1136. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-11Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-08-08i.MX31 PDK: Enable generic board for i.MX31 PDKMagnus Lilja
Enable CONFIG_SYS_GENERIC_BOARD for the i.MX31 PDK board. Tested on actual hardware. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-07-30include: remove CONFIG_SPL/CONFIG_TPL definition in config headersMasahiro Yamada
Now CONFIG_SPL and CONFIG_TPL are defined in Kconfig. Remove the redundant definition in config headers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30include: define CONFIG_SPL and CONFIG_TPL as 1Masahiro Yamada
We are about to switch to Kconfig in the next commit. But there are something to get done beforehand. In Kconfig, include/generated/autoconf.h defines boolean CONFIG macros as 1. CONFIG_SPL and CONFIG_TPL, if defined, must be set to 1. Otherwise, when switching to Kconfig, the build log would be sprinkled with warning messages like this: warning: "CONFIG_SPL" redefined [enabled by default] Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-11-13configs: imx: Make CONFIG_SYS_PROMPT uniform across FSL boardsFabio Estevam
There is no real benefit in adding the board name into U-boot's prompt, so remove the custom CONFIG_SYS_PROMPT definitions so that the standard "=> " prompt is used across FSL boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-05-01mx31pdk: add CONFIG_SPL_LIBGENERIC_SUPPORTAndreas Bießmann
In order to use the generic hang() later on pull libgeneric in SPL. This has no impact on the SPL size. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-04-12mx31pdk: Remove watchdog supportFabio Estevam
The conversion of mx31pdk to SPL NAND fixed the boot issue, but we start seeing resets in loop, which prevents us from reaching the U-boot prompt. Until the proper fix can be identified, disable watchdog, so that mx31pdk can be functional again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2013-04-12nand: mxc: Switch NAND SPL to generic SPLBenoît Thébaudeau
This also fixes support for mx31pdk and tx25, which had been broken by commit e05e5de7fae5bec79617e113916dac6631251156. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Acked-by: Scott Wood <scottwood@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-01-13mx31/mx35/mx51/mx53/mx6: add watchdogTroy Kisky
Use a common watchdog driver for all these cpus. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-12-10Merge branch 'master' of git://git.denx.de/u-boot into resolveMinkyu Kang
Conflicts: README board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-11-19mx31pdk: Configure CONFIG_BOOTDELAY to one secondFabio Estevam
One second is enough time for users to react in case they want to stop the booting process. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-11-14power:pmic: Rename CONFIG_PMIC* defines to CONFIG_POWERŁukasz Majewski
Rename all CONFIG_PMIC* defines to CONFIG_POWER* Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx31: Fix PDR0_CSI_PODFBenoît Thébaudeau
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0 register is actually composed of two bit-fields: one pre-divider and one post-divider. This patch fixes the CCM access macros and the code using them accordingly. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-06mx31: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX31 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Helmut Raiger <helmut.raiger@hale.at>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15mx31pdk: Allow booting a zImage kernelFabio Estevam
Allow booting a zImage kernel. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-03-27mx31pdk: Fix CONFIG_SYS_MEMTEST_ENDFabio Estevam
CONFIG_SYS_MEMTEST_END should be higher than CONFIG_SYS_MEMTEST_START. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-12-06MX: serial_mxc: cleanup removing nasty #ifdefStefano Babic
The serial driver for iMX SOCs is continuosly changed if a new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port> defines were used only to find the base address for the selected UART. Instead of that, move the base address to the board configuration file and drop all #ifdef from driver. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Wolfgang Denk <wd@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Helmut Raiger <helmut.raiger@hale.at> CC: John Rigby <jcrigby@gmail.com> CC: Matthias Weisser <weisserm@arcor.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-11-03rtc: Make mc13783-rtc driver genericFabio Estevam
Rename mc13783-rtc so that it can be used for both MC13783 and MC13892 PMICs. efikamx board, for example, does use a MC13892 PMIC, but the RTC selection is currently made as: #define CONFIG_RTC_MC13783 ,which is not very obvious. Let the MC13783 and MC13892 RTC be selected by: #define CONFIG_RTC_MC13XXX Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-28Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: Add Calxeda Highbank platform dkb: make mmc command as default enabled Marvell: dkb: add mmc support ARM: pantheon: add mmc definition davinci: remove config.mk file from the sources ARM:AM33XX: Add support for TI AM335X EVM ARM:AM33XX: Added timer support ARM:AM33XX: Add emif/ddr support ARM:AM33XX: Add clock definitions ARM:AM33XX: Added support for AM33xx omap3/emif4: fix registers definition davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM davinci: emac: add support for more than 1 PHYs davinci: emac: add new features to autonegotiate for EMAC da850evm: Move LPSC configuration to board_early_init_f() omap4_panda: Build in cmd_gpio support on panda omap: Don't use gpio_free to change direction to input mmc: omap: Allow OMAP_HSMMC[23]_BASE to be unset OMAP3: overo : Add environment variable optargs to bootargs OMAP3: overo: Move ethernet CS4 configuration to execute based on board id OMAP3: overo : Use ttyO2 instead of ttyS2. da830: add support for NAND boot mode dm36x: revert cache disable patch dm644X: revert cache disable patch devkit8000: Add malloc space omap: spl: fix build break due to changes in FAT OMAP3 SPL: Provide weak omap_rev_string omap: beagle: Use ubifs instead of jffs2 for nand boot omap: overo: Disable pull-ups on camera PCLK, HS and VS signals omap: overo: Configure mux for gpio10 SPL: Add DMA library omap3: Add interface for omap3 DMA omap3: Add DMA register accessors omap3: Add Base register for DMA arm, davinci: add missing LSPC define for MMC/SD1 U-Boot/SPL: omap4: Make ddr pre-calculated timings as default. DaVinci: correct MDSTAT.STATE mask omap4: splitting padconfs into common, 4430 and 4460 omap4: adding revision detection for 4460 ES1.1 omap4: replacing OMAP4_CONTROL with OMAP4430_CONTROL gplug: fixed build error as a result of code cleanup patch kirkwood_spi: add dummy spi_init() gpio: mvmfp: reduce include platform file ARM: orion5x: reduce dependence of including platform file serial: reduce include platform file for marvell chip ARM: kirkwood: reduce dependence of including platform file ARM: armada100: reduce dependence of including platform file ARM: pantheon: reduce dependence of including platform file Armada100: Add env storage support for Marvell gplugD Armada100: Add SPI flash support for Marvell gplugD Armada100: Add SPI support for Marvell gplugD SPI: Add SPI driver support for Marvell Armada100 dreamplug: initial board support. imx: fix coding style misc: pmic: drop old Freescale's pmic driver MX31: mx31pdk: use new pmic driver MX31: mx31ads: use new pmic driver MX31: mx31_litekit: use new pmic driver MX5: mx53evk: use new pmic driver MX5: mx51evk: use new pmic driver MX35: mx35pdk: use new pmic driver misc: pmic: addI2C support to pmic_fsl driver misc: pmic: use I2C_SET_BUS in pmic I2C MX5: efikamx/efikasb: use new pmic driver MX3: qong: use new pmic driver RTC: Switch mc13783 to generic pmic code MX5: vision2: use new pmic driver misc: pmic: Freescale PMIC switches to generic PMIC driver misc:pmic:samsung Enable PMIC driver at GONI target misc:pmic:max8998 MAX8998 support at a new PMIC driver. misc:pmic:core New generic PMIC driver mx31pdk: Remove unneeded config mx31: provide readable WEIM CS accessor MX51: vision2: Set global macros I2C: Add i2c_get/set_speed() to mxc_i2c.c ARM: Update mach-types devkit8000: Add config to enable SPL MMC boot devkit8000: protect board_mmc_init arm, post: add missing post_time_ms for arm cosmetic, post: Codingstyle cleanup arm, logbuffer: make it compileclean tegra2: Enable MMC for Seaboard tegra2: Add more pinmux functions tegra2: Rename PIN_ to PINGRP_ tegra2: Add more clock functions tegra2: Clean up board code a little tegra2: Rename CLOCK_PLL_ID to CLOCK_ID
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-27MX31: mx31pdk: use new pmic driverStefano Babic
Switch to new pmic generic driver. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30mx31pdk: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30mx31pdk: Change the prompt as per other i.MX boardsFabio Estevam
Change the prompt as done in other i.MX boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-07MX31: mx31pdk: make use of GPIO frameworkStefano Babic
2011-07-14mx31pdk: cosmetic: Fix line over 80 charactersFabio Estevam
2011-06-21mx31pdk: Add DHCP commandFabio Estevam
2011-05-23mx31pdk: Clean up mx31pdk.h fileFabio Estevam
No need to use '#define SYMBOL 1' to make it active. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2011-05-11MX31: mx31pdk: Add watchdog supportFabio Estevam
2011-04-27IMX: MX31: Cleanup include files and drop nasty #ifdef in driversStefano Babic
As exception among the i.MX processors, the i.MX31 has headers without general names (mx31-regs.h, mx31.h instead of imx-regs.h and clock.h). This requires several nasty #ifdef in the drivers to include the correct header. The patch cleans up the driver and renames the header files as for the other i.MX processors. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-02-21mx31pdk: Make the full boot log visibleFabio Estevam
Use board_early_init_f so that the full boot log output can be displayed. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-02-21mx31pdk: Use the new relocation schemeFabio Estevam
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-30MXC: Correct SPI_CPOL setting in SPI driverStefano Babic
The handling of the SPI_CPOL bit inside the SPI driver was wrong. As reported by the manual, the meaning of the SSPOL inside the configuration register is the same as reported by SPI specification (0 if low in idle, 1 is high on idle). The driver inverts this logic. Because this patch sets the logic as specified, it is required to clear the CPOL bit in the configuration file to adapt to the correct logic. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: David Jander <david.jander@protonic.nl>
2010-05-05MX: RTC13783 uses general function to access PMICStefano Babic
The RTC is part of the Freescale's PMIC controller. Use general function to access to PMIC internal registers. Signed-off-by: Stefano Babic <sbabic@denx.de> Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
2010-01-19MX31: Activate NAND environment on i.MX31 PDK board.Magnus Lilja
2009-07-22Convert SMC911X Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC911X* to CONFIG_SMC911X* - cleaned up line lengths - modified all boards that override weak function in this driver - added Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Mike Frysinger <vapier@gentoo.org>
2009-07-06MX31: Add NAND SPL boot support to i.MX31 PDK board.Magnus Lilja
2009-07-06MX31: Add basic support for Freescale i.MX31 PDK board.Magnus Lilja
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board). This patch assumes that some other program performs the actual NAND boot. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Acked-by: Fabio Estevam <fabioestevam@yahoo.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
