Convert mx25 to use the commmon timer code.
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
[trini: Fixup common/cmd_io.c]
The mx25pdk board supports the i.MX25 DryIce RTC (imxdi), so enable it. This
allows to compile-test the imxdi driver in the mainline tree.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
Select CONFIG_OF_LIBFDT so that a device tree kernel can be launched.
Make the necessary adaptions for the new PMIC framework, so that mx25pdk can
be built again.
One second is enough time for users to react in case they want to stop the
booting process.
Allow booting a zImage kernel.
mx25pdk has a Ethernet port that is connected to its internal FEC controller.
In order to power up the Ethernet PHY (DP83640) it is necessary to communicate
with the MC34704 PMIC via I2C.
Make the FEC ethernet port functional
mx25pdk has a SD/MMC slot connected to esdhc1.
Add support for it and allow the environment variables to be saved into SD/MMC.
It is necessary to include CONFIG_MX25 as several i.mx drivers handle the SoC
differences based on the this config option.
Use internal RAM for stack pointer as it is done in other i.MX boards.
Define default SoC input clock frequencies for i.MX25 in order to get rid of
duplicated definitions.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Matthias Weisser <weisserm@arcor.de>
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present
in most ARM board config files.
IRQs are only enabled for 1 config, so remove the unused config options
for IRQ and FIQ stack size as well.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
This define does not control anything, remove it.
The serial driver for iMX SOCs is continuosly changed if a
new SOC or not yet used port is used. CONFIG_SYS_<SOC>_<UART Port>
defines were used only to find the base address for the selected UART.
Instead of that, move the base address to the board configuration
file and drop all #ifdef from driver.
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Wolfgang Denk <wd@denx.de>
CC: Fabio Estevam <fabio.estevam@freescale.com>
CC: Helmut Raiger <helmut.raiger@hale.at>
CC: John Rigby <jcrigby@gmail.com>
CC: Matthias Weisser <weisserm@arcor.de>
CC: Jason Liu <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linaro.org>
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Let common code set the machine ID.
Add the initial support for MX25PDK booting from SD card via internal boot.
