path: root/include/configs/mx23_olinuxino.h
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-24ARM: mxs: Consolidate configuration optionsMarek Vasut
Pull all the duplicate configuration options into configs/mxs.h from the board configuration files. This reduces the files greatly and makes them somewhat more readable. Besides, we do no longer have such a horrible duplication of code. Note that the mx23evk grew in size slightly. This is due to the CONFIG_SYS_CBSIZE now being set to 1024 as it is on the rest of MXS systems. This patch also fixes the OCRAM size for i.MX23. The i.MX23 has only 32kB of OCRAM, while i.MX28 has 128kB of OCRAM. I verified the configuration didn't change for each of the boards, but I didn't boot-test it on the boards I do not have. I configured U-Boot for each board using the "make ... <board>_config" command and then ran "cpp -I include -dM include/config.h" , which dumped all the configuration options. I did this both before and after this patch and finally compared the results for each MXS board. Actually, the results do differ slightly, since the configs/mxs.h file now properly includes the correct iomux-mx23.h or iomux-mx28.h , so while comparing, I had to ignore these new defines. These have no impact on U-Boot configuration though. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Lauri Hintsala <lauri.hintsala@bluegiga.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-04-03mx23_olinuxino: Fix netboot consoleAlexandre Pereira da Silva
The netargs variable was referencing the non-existing variable console_mainline. Change that to console variable instead. Signed-off-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-04-03mx23_olinuxino: Change definitions to use spaces instead of tabsOtavio Salvador
Change all "#define/ifdef<TAB>" sequences into "#define/ifdef<SPACE>". Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-03-07mx23_olinuxino: Add ethernet supportOtavio Salvador
This adds support to the LAN9512 chip included in the board and extend the environment to easy netboot use. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-03-07mx23_olinuxino: Enable USB supportOtavio Salvador
This enabled USB support for the mx23_olinuxino board. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-03-07mx23_olinuxino: Add support for status LEDOtavio Salvador
This allow user to know if the bootloader is running, even without a serial console. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-01-28mx23_olinuxino: Add default environmentOtavio Salvador
This adds a default environment with support for MMC booting. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-01-28mxs: mmc: mx23_olinuxino: Add MMC supportMarek Vasut
Add support for the MMC attached to SSP1. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-21mxs: Add MX23 olinuxino board supportMarek Vasut
This patch adds support for MX23-based Olinuxino board. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
