path: root/include/configs/mx1ads.h
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-06-21mx1ads: Fix build by using new relocation schemeFabio Estevam
2010-10-27Coding Style cleanupWolfgang Denk
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-03-30imx: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2007-07-10include/configs/[g-o]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various m* named board config files.Jon Loeliger
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-10-10Patches by George G. Davis, 24 Aug 2004:wdenk
- Enable ramdisk/initrd tagged param support for omap1610h2_config - Remove static network setup defaults from mx1ads_config
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-06-19Patch by Josef Wagner, 04 Jun 2004:wdenk
- DDR Ram support for PM520 (MPC5200) - support for different flash types (PM520) - USB / IDE / CF-Card / DiskOnChip support for PM520 - 8 bit boot rom support for PM520/CE520 - Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245) - I2C and RTC support for CPC45 - support of new flash type (28F160C3T) for CPC45
2004-06-09* Patch by Yuli Barcohen, 09 Jun 2004:wdenk
Add support for Analogue&Micro Adder87x and the older AdderII board. * Patch by Ming-Len Wu, 09 Jun 2004: Add suppport for MC9328 (Dargonball) CPU and Motorola MX1ADS board
