path: root/include/configs/mucmc52.h
2010-09-19mpc52xx: Cleanup use of CONFIG_SYS_SRAM_BASE and CONFIG_SYS_SRAM_SIZEHeiko Schocher
cleanup for the uc101 and the mucmc52 board. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-09-25mpc5200, mucmc52, uc101: config cleanupHeiko Schocher
- As these boards are similiar, collect common config options in manroland/common.h and manroland/mpc52xx-common.h for mpc5200 specific common options for this manufacturer. - add OF support - update default environment Signed-off-by: Heiko Schocher <hs@denx.de> Minor edit of commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-09net: removed board-specific CONFIGs from MPC5xxx FEC driverBen Warren
Added new CONFIG options for the three type of MAC-PHY interconnect and applied them all relevant board config files Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-08-27mpc52xx: added support for the MPC5200 based MUC.MC52 board from MAN.Heiko Schocher
